cletus Posted October 11, 2015 Share Posted October 11, 2015 ^correct, needs cert. Quote Link to comment Share on other sites More sharing options...
shavenYak Posted October 11, 2015 Share Posted October 11, 2015 what about 4AF -> 4AG but with carbs. Still need cert due to power incease? Quote Link to comment Share on other sites More sharing options...
Bling Posted October 11, 2015 Share Posted October 11, 2015 Going by your list, yes? No 95HP 4ages that I know of. It may even fail on head design too, not sure what factors they take into account mind you. G head likely weighs more than F too. 4AF is all good anyway, enjoy that economy Quote Link to comment Share on other sites More sharing options...
cletus Posted October 11, 2015 Share Posted October 11, 2015 what about 4AF -> 4AG but with carbs. Still need cert due to power incease? yep. head casting not the same as well. Quote Link to comment Share on other sites More sharing options...
sr2 Posted October 12, 2015 Share Posted October 12, 2015 If you're going to butt heads with someone, who dedicates a lot of time to answer a million questions to do with certs, then perhaps just don't post. Thread is for questions, not arguments etc. Just my uncerted opinion. Despite being something of a newbee to this MB I get the impression cletus is a big boy who relishes a robust debate can more than well take care of himself. One of the fundamental cornerstones of the country we live in is the right to hold and express one's opinion. As most know the cert process has a number of "grey areas' that all parties involved struggle with; to suggest that all cert questions have a simple answer is naive, to suggest that one shouldn't question those answers is draconian. 2 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted October 12, 2015 Share Posted October 12, 2015 You have to realise there's 191 pages here. I don't think anyone could love debate that much. I could be wrong though. 2 Quote Link to comment Share on other sites More sharing options...
mjrstar Posted October 12, 2015 Share Posted October 12, 2015 so.. plastic windows I need to buy a bit to do the rear window on my mx5, the LVV document gives me this: f) Plastic Windows: fitted to a vehicle may be detailed on an Authority Card provided the following requirements are met: (i) The plastic windows are only fitted to the side and/or rear (not the front screen), and (ii) The material is of an approved polycarbonate type, being Lexan MR10 or Cyrolon AR2 or a LVVTA accepted rigid plastic material, and (iii) They are mounted securely to the vehicle, and (iv) They comply with the requirements of this Schedule. so... where do I get the stuff I need at a sharp price, and how do I prove it's the legit material? cheers Quote Link to comment Share on other sites More sharing options...
smokin'joe Posted October 12, 2015 Share Posted October 12, 2015 square metre rate at a glazier might be spendy, but buying a full sheet is fucking stupid unless you can use it all. full sheet will do 2 cars. glazier will etch and supply producer statement Quote Link to comment Share on other sites More sharing options...
sr2 Posted October 13, 2015 Share Posted October 13, 2015 You have to realise there's 191 pages here. I don't think anyone could love debate that much. I could be wrong though. LOL; good point! Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted October 13, 2015 Share Posted October 13, 2015 Hiiiii! How long does it normally take for the cert plates to show up? Is 6 weeks a bit slow? 1 Quote Link to comment Share on other sites More sharing options...
Mitch.W Posted October 13, 2015 Share Posted October 13, 2015 It usually depends on how busy they are but mine have only taken ~2 weeks so far. 6 weeks seems an awfully long wait. Quote Link to comment Share on other sites More sharing options...
R100 Posted October 13, 2015 Share Posted October 13, 2015 Hiiiii! How long does it normally take for the cert plates to show up? Is 6 weeks a bit slow? Who did your cert check if you dont mind me asking. Quote Link to comment Share on other sites More sharing options...
Beaver Posted October 13, 2015 Share Posted October 13, 2015 It usually depends on how busy they are but mine have only taken ~2 weeks so far. 6 weeks seems an awfully long wait. Mine was less thnt a week Quote Link to comment Share on other sites More sharing options...
cletus Posted October 13, 2015 Share Posted October 13, 2015 so.. plastic windows I need to buy a bit to do the rear window on my mx5, the LVV document gives me this: f) Plastic Windows: fitted to a vehicle may be detailed on an Authority Card provided the following requirements are met: (i) The plastic windows are only fitted to the side and/or rear (not the front screen), and (ii) The material is of an approved polycarbonate type, being Lexan MR10 or Cyrolon AR2 or a LVVTA accepted rigid plastic material, and (iii) They are mounted securely to the vehicle, and (iv) They comply with the requirements of this Schedule. so... where do I get the stuff I need at a sharp price, and how do I prove it's the legit material? cheers FW: Plastic glazing Each piece of plastic glazing needs to be marked by the glazier. I suggest “ANSI-Z26.1-1983” is engraved on. Here are the makes of glazing we know to be ok: Polycarbonates (more flexible than acrylic, better): Lexan MR series Cyrolon AR series Tuffak CM-2 Makrolon AR Palgard (not Palsun which is not abrasion resistant) Acrylic: Lucite SAR series – but this breaks into shards so is not recommended. The key point is that the glazing needs to be abrasion resistant. This is the detail from our regulations on this: 15.7 Alternative rigid plastic glazing materials 15.7.1 Side and rear glazing fitted to a low volume vehicle may be made from a rigid plastic material, provided that each piece of glazing: (a) meets the technical requirements of item 4, test numbers 2,10, 13,16,17,19,20,21,and 24 of the ANSI-Z26.1-1983 Standard, and any subsequent amendments; and ( is attached to the vehicle in such a way so as to: (i) be protected against any sliding abrasion that will affect the driver’s vision through the glazing; and (ii) where the glazing is fixed, is able to be forcibly removed in the event of an emergency; and © is permanently and indelibly marked with the approved LVVTA alternative standard marking. this is a copy of an email i was sent about it. Also it was mentioned that we should see the windows with the plastic protective stuff on it before its peeled off, so we know its installed the right way round, ie the abrasion resistant side out the last bit is from the HCM so thats why its different to what you posted Quote Link to comment Share on other sites More sharing options...
cletus Posted October 13, 2015 Share Posted October 13, 2015 Hiiiii! How long does it normally take for the cert plates to show up? Is 6 weeks a bit slow? yeah thats a bit long. I usually tell people 7-10 working days after the car has passed, and that gives me a couple of days to allow for sending it/getting back to the car to fit it i admit, some take longer than that, but its due to me being busy. they dont get held up in wellington unless theres an issue with the vehicle or lack of information on the certifiers part. Have you rung him? Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted October 13, 2015 Share Posted October 13, 2015 Yeh, he told me 2-3 weeks, but didn't want to pester him. I'll ring him tomorrow. I text him last week (as he seemed to be a texting kinda guy) and got no reply. He probably had second thoughts about unleashing the hilux on NZ's roads, lols. Quote Link to comment Share on other sites More sharing options...
mjrstar Posted October 13, 2015 Share Posted October 13, 2015 My last couple of certs were less than 10 days, also cheers for the info above.. might try mulfords a chunk of plastic.. Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted October 13, 2015 Share Posted October 13, 2015 I rang the man, he must have held back the paper work and sent it in a batch. He reckons the plate will be back early next week, and then he's going to send it to the local VTNZ to attach it to the car, and they charge about $30 to stick it on, so that's all gravy. Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted October 14, 2015 Share Posted October 14, 2015 I rang the man, he must have held back the paper work and sent it in a batch. He reckons the plate will be back early next week, and then he's going to send it to the local VTNZ to attach it to the car, and they charge about $30 to stick it on, so that's all gravy. They let me fit my own plate. Quote Link to comment Share on other sites More sharing options...
Nominal Posted October 14, 2015 Share Posted October 14, 2015 They let me fit my own plate. I wouldn't advertise it - there is a process to follow. http://www.lvvta.org.nz/documents/infosheets/LVVTA_Info_06-2007_Delegation_of_LVV_Cert_Plate_Attachment.pdf 1 Quote Link to comment Share on other sites More sharing options...
