The worst part about all this is when you posted things about datsuns etc , I thought this tricky fellow has got a gtr!
But then I didn't write it in the internet before you told us!
Now I just look like an idiot don't I!
Well I would if I mentioned it, if I don't say anything then nobody will know. Good
Anyway, you should put a 2jz in it
  • Haha 2
  • Replies 291
I thought the same thing, then thought the Datsun name was long gone by then. Won't fall for that trick again. lol
2 hours ago, sheepers said:
the back story is that Dick has owned this car for at least 20 years. he was drag racing it in the early 2000's and got it into the 10s back then.
he pulled it apart to do a "full resto" and the EVO 1 drag car took over his life. hes subsequently come to the realisation that hes never going to finish it so here i am.
side sharn, the R32 GTR parts car i bought in 2006 to build my IRS celica came from the same guy.
I thought it looked familiar.
Has it still got the rb30? I did some lush work on the exhaust to make it fit the taller engine :geek:
This will be fun to follow.
I have had a couple of these through my workshop, plus some of the lesser models, where I've done pre-vin welding work. They do love to rust it seems. Some of the chassis rail/sill/floor damage from forklifts is crazy given the value of them. Fella reckoned the prices sailed when they became eligible to be imported into the US as classics?  Its funny working on them - just very typical nissan construction of the time.
Have you done any front jacking points on the inner sil.
Just did my workmates one a few months ago. Had to cut a piece of the floor out to get at the inner sil without taking the outer off
That does ring a bell actually. I do remember how the rust on several just tracks along the inner sill above the floor and quite a lot has to be removed to get to the inner bits. Here's some pics from two different gtrs. The rust was just the tip of iceberg.
@sidewaysickness does your sister still have her gtr?
2 hours ago, cletus said:
How good would it be to adapt a barra/turbo ls to the factory driveline and make a billion hp reliably , you could use the tears of upset gtr purists as coolant
there seem to be a number of billion HP rb2#/rb3# in existance already, source HRB's instagram lol
That last pic is exactly where my workmates one was gone. Seems to be real common. Like the sil isn't strong enough to lift off the all seem to be crumpled up too. I added extra suport to make the jacking point usable on his
Very thin steel too eh!
With what seems to be a token this amount of grey primer:roll:
I think its from leaking windscreens and the water runs along under that seam.
I have had an Rx7 Fd in and that had faired not much better either in the same place.
