  • Replies 291
7 hours ago, Vintage Grumble said:
HEARING YOUR OWN EAR HOLE SIZZLE IS FUCKING NOT GREAT.
I once had a mig blob fuse onto my eyeball after a day under a car at work doing a rust job. After my eye involuntarily weeped for a few hours over dinner my flatmates forced me to walk across the road to the hospital and have it seen to. The doctor used a Dremel to grind it off, thankfully no permanent damage..
  • Sad 6
 Wtf man. I thought twirling the filler rod straight up the nose gas welding was bad. Eyeballs is another level again
  • Haha 1
On 16/05/2025 at 18:46, cletus said:
one thing to think of with mig welding, especially with a mig welder is the hot blobs can fall on the floor
if the floor is painted, this can leave burn marks in the paint!
just something to keep in mind, friend
Plz sir, tell us more about mig welding with a mig welder. Are those hot blobs of mig welder weld from the mig welder?
  • Haha 2
11 minutes ago, Dudley said:
If you’ve gone this far you may aswell strip all the old underseal and epoxy the fresh steel underneath?
i probably should clarify that i have given it a once over with the wire wheel and the underseal and primer that's still on the car is really well stuck, the 3500PSI waterblaster didn't take it off so im calling that stuck.
i think id just be making work for no reason stripping off whats still there.
11 hours ago, 87creepin said:
That’s the right order of doing things
What a beautiful shed. So much room for activities.
though with a painted floor it could be a showroom.
Stop being provocative, he clearly doesnt like having a painted floor.
Although he hasnt told us what sort of carpet he's going to put down instead
Great work Sheepers this car is going to be absolutely ace. I look forward to seeing it some time.
I fear with his newly acquired mig welder his hearty shag pile may catch fire
  • Haha 5
yea true.
but on the plus side it would act as a sort of paint stripper so that's good right?
i am very much relying on the Epotech 408 to work its magic and "seal" all the old stuff underneath it. it seems to have the ability to do this in small doses so lets roll the dice and try again.......
14 hours ago, 87creepin said:
 painted floor showroom.
damm straight, painted floors are for showrooms and areas where no one does any real work.
  • Thanks 2
21 hours ago, Dudley said:
Be shit to primer and seal over that old underseal and then it reacts cause thats a bad day,
Epoxy doesn’t really react with much though does it?
Well wasnt expecting this when i opened the thread, not sure how i missed it till now also.
Very cool!
Good to see shes getting a tidy up before motor gets in , will be ace!
Sheepskin rugs - with 570°C burn temp they would be mint with a Mig
