2 hours ago, Bearded Baldy said:
Amateur, if it is long enough to tuck into your collar, you tuck it in!
When i rocked a goatee i had a very very close call with my lathe one night. Started tucking my earmuff band under my chin after that.
Good tip.
Maybe I should start wearing pants around the shop. Wouldn't be fun getting my pubes ripped out by my spinny tools.
  • Haha 4
  • Replies 291
@xsspeedĀ wrote in the wrong thread because hes a noob and cant read the rules,
"did you use the same brand sealer or a different one?"
Ā
Ā
i didn't use the same brand of bullshit doesn't work sealer, that would be asking for trouble.
i used another one that i don't know the name of but it was made in Greece.
  • Haha 1
On 24/04/2025 at 09:09, sheepers said:
Ā
Ā
On 24/04/2025 at 09:15, xsspeed said:
Sorry I thought it was in other projects
Weird rules….. I mean, I get why it’s the rules and keeps the thread ā€œpureā€, but it’s weird’ cause it’s only on OS and only in one area….. and I’ve not got deletion rights so I can’t fix it when I forget/get carried away and screw up…. Grizzle over.Ā
Ā
I’ve always liked these 4WD Datsuns (even settle for some of the 2WD ones). ā€˜Cause they look nice and make great noises…..
Tend to be ridiculous money and/or fall-apart rust here.
Think I recall someone posting about this in the paint thread,but you are having good success with epoxy inside panels /seams instead of copper weld through? And just exposing the steel at the plug weld?Ā
yea that's pretty much it.
the epoxy burns back a small amount but so do the copper primers.
tbh it was a pain in the arse doing this with the TIG but the MIG doesn't seem to give a fuck and just blazes through any paint that you haven't removed.Ā
i will, in my experimenting with MIG welding, try the weld thru primers again but the epoxy is a far superior paint and sticks like shit to a blanket. i wouldn't recommend huffing the fumes it gives off but you do you.Ā
Ā
15 hours ago, sheepers said:
Something that I did learn really quickly is that hot bits of metal rain down on you constantly and you get burnt to shit if your just wearing a t shirt
Ā
Ā
Welcome to the world of the rest of us poors/plebs who don't have access to a tig. I'm sure you'll enjoy your hot metal glue gun
I have found with mig welding you need to up your wire speed quite a bit when overhead welding. If you have it at 8.5 and getting a shower of molten metal then go to 9.5-10. You always seem to get some but it should help. Never used a tig myself.
12 hours ago, westy said:
Wait till you get a nice big blob down the tongue of your boot
Dance man dance šŸ˜€ (know that dance!)
12 hours ago, Dudley said:
Wait till you get a blob down ya earhole
Especially when lying prone under the car and reflexes cause you beat your head on the ground and car floor alternately. Ā Most upsetting. Ā Then years later you get a savage bollocking from the ENT consultant when you explain the true origins of the small (4mm) ā€œball bearingā€ he’s just found in your earwax…..😬
Fun times!
  • Haha 5
Copper weld thru primer isn’t a recommended repair method anymore,
the copper and steel mixing causes corrosion
  • Thanks 2
