Sambo Posted September 6, 2015 Share Posted September 6, 2015 So I just spent a few hours pulling the head off the Z24 in my Navara. I thought the head gasket had blown (apparently they delaminate on Z24s quite regularly), but no such luck. This is the exhaust side of the engine: So yeah, someone has drilled and tapped a new hole under the proper exhaust manifold stud, scoring the top of the block in the process, then spot welded some threaded rod in there. Was gunked up with some sort of gasket goo. Is it worth having this head fixed? My thought is no, but finding Z24/2 engines at a decent price is pretty difficult. Also the block, can that be machined out? 4 Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted September 6, 2015 Share Posted September 6, 2015 WTF, I'm gonna say most engine builders are gonna steer you towards a new block/head combo for economic reasons tbh. Thats cray cray. I'm still confused to be honest. 2 Quote Link to comment Share on other sites More sharing options...
Sambo Posted September 6, 2015 Author Share Posted September 6, 2015 Yeah, I tossed up between posting here and fabrication fuck ups. I've just spied a cheap engine on trademe. Fingers crossed. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted September 6, 2015 Share Posted September 6, 2015 This needs to feature in the mechanical fuck ups thread tbh. Head may be fixable with a weld and skim but its the block id be more worried about she looks pretty chooched 2 Quote Link to comment Share on other sites More sharing options...
beachlander Posted September 6, 2015 Share Posted September 6, 2015 Thats some next level shit. Quote Link to comment Share on other sites More sharing options...
Valiant Posted September 6, 2015 Share Posted September 6, 2015 welding the head and resurfacing it seems quite reasonable. The block though, how deep is the mark? It could possibly be machined away and reassembled with a copper spacer plate. Or not for massive compression and bad cam timing. Take it to an Engine Reconditioner, see what they think. 2 Quote Link to comment Share on other sites More sharing options...
igor Posted September 6, 2015 Share Posted September 6, 2015 I think somebody's head is a bit fucked but not necessarily the one off the engine. What kind of nut job would do this? 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 6, 2015 Share Posted September 6, 2015 They can weld anything thees days, I am sure it could be built up and the head could be skimmed at a fraction of the price of another head 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 6, 2015 Share Posted September 6, 2015 Could you jam a rag in that cylinder and hit it with the mig and file it flat? 2 Quote Link to comment Share on other sites More sharing options...
BLIZZO Posted September 6, 2015 Share Posted September 6, 2015 haha its like peedubs' pug 309 racecar except his was a retarded drill and tap into an oil gallery /ling Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted September 6, 2015 Share Posted September 6, 2015 that shit is fucked 2 Quote Link to comment Share on other sites More sharing options...
Bangbug Posted September 6, 2015 Share Posted September 6, 2015 Is that into the sleeve n all? Fuck me. Anywho I'd say the head is saveable at least Just had my head welded and skimmed and block decked for $190 + gst Go see Dan at east city reconditioners, he's old school Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted September 6, 2015 Share Posted September 6, 2015 Fixable for a price. The block could be either a new sleeve or bodge it with a mig welder and file but it'll need fixing again sooner or later, and will need a new sleeve next rebuild. Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted September 6, 2015 Share Posted September 6, 2015 I have seen some Oldschool repairs done (on TV and the net)that would fill the block damage pretty easily. From.memory it was like a chain of holes that you tapped pins into then cut off and filed flat 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 6, 2015 Share Posted September 6, 2015 I have seen some Oldschool repairs done (on TV and the net)that would fill the block damage pretty easily. From.memory it was like a chain of holes that you tapped pins into then cut off and filed flat I have seen those plug repairs used on cracks and stuff, you drill and tap a hole then thread in a cast iron bolt witch snaps off then the 2nd one is drilled into the side of that and so on. Quote Link to comment Share on other sites More sharing options...
evil_si Posted September 6, 2015 Share Posted September 6, 2015 Its fucked, if it were mine id look at an epoxy metal like Wurth FE2, belzona or devcon The wurth shit is probably the cheapest at $40 a kit Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted September 6, 2015 Share Posted September 6, 2015 Weld the head up no worries. Block tho.... Could stainless filler wire tig it up. Not steel filler. Will go too hard to file/ face easy with steel. Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted September 6, 2015 Share Posted September 6, 2015 The ceramic belzona might do it! I think 1111 may be a bit too soft? Quote Link to comment Share on other sites More sharing options...
Mof Posted September 6, 2015 Share Posted September 6, 2015 That's definitely going to need a new sleeve in the block. They've drilled right through the protrusion of the sleeve that seals the gasket to the head! If its dry liner they can be fucking tight to get out. Block should be ok though just built up again with knead it or similar. Head is shagged. What's up with the white valve in cylinder 2? Looks like it's been hot Where's hemi? Quote Link to comment Share on other sites More sharing options...
Hemi Posted September 6, 2015 Share Posted September 6, 2015 Yeah looks like the mark in the block goes right through the fire ring. gonna be worse then an M series like that Quote Link to comment Share on other sites More sharing options...
