Carsnz123 Posted July 25, 2021 Posted July 25, 2021 On 23/07/2021 at 07:41, tortron said: I change my bikes oil every 1000km or rebuild, which ever comes first Ah yes, honda bike service intervals. Oil every 1000k and filter every 3000k. Gets spendy when you're using it every day. Quote
Carsnz123 Posted July 25, 2021 Posted July 25, 2021 On 21/07/2021 at 22:56, chasinthemirage said: Semi ling but not really worth starting a thread, has anyone mucked around with the Holden 3.8 motors? Pretty keen on another fun car but priced out of VL's, VN SS' etc. Seen a few people in Aussie with turbo 3.8's, anyone done it? Just want a fun street car that I could do the odd skid in/take to the drags occasionally. Thinking 255's, LSD and a turbo (just want it to do hektik doses tbh). Sound plausible or nah? Also inb4 V6's are yuck. Buick turbocharged those engines in the 80s with good results. Or get a superchizzled one and swap whiny boi for spoolie boi. Look up what the yanks do with the buick V6. It's madness 1 Quote
tortron Posted July 25, 2021 Posted July 25, 2021 They have been twin turboed in L200s to great success Quote
SOHC Posted July 29, 2021 Posted July 29, 2021 Where would I find some springs like this? They are not a matching pair Quote
Bling Posted July 29, 2021 Posted July 29, 2021 Chamberlains in CHCH can probably make them, worth a call anyway. 1 Quote
kyteler Posted July 30, 2021 Posted July 30, 2021 14 minutes ago, SOHC said: Where can I buy 5/8 UNC studs? Give @danger a call. He's a 5ft 8 stud. /Repco 3 1 2 Quote
SOHC Posted July 30, 2021 Posted July 30, 2021 13 minutes ago, kyteler said: Give @danger a call. He's a 5ft 8 stud. /Repco He’s 5/8 tall? You could keep him in a match box 2 Quote
RUNAMUCK Posted July 31, 2021 Posted July 31, 2021 Rubber grommets/bungs etc.. Wheres a good place to buy em? I visited the local rubber merchants (who I fucking despise intensely) this morning. Everything in their inventory is imperial. Less than zero use on my build. What's everyone's go to? Quote
tortron Posted July 31, 2021 Posted July 31, 2021 I got a boxed assortment off trademe, pretty decent. I assume they are alispec but I wanted them nao Was like 15 bucks or something Quote
RUNAMUCK Posted July 31, 2021 Posted July 31, 2021 I literally only required like 5 grommets. I dont want anything other than exactly the ones I need. Yes I want them Naow. Quote
tortron Posted July 31, 2021 Posted July 31, 2021 You will pay 15 at supercheap for a 5 pa k so buy the box Quote
datlow Posted July 31, 2021 Posted July 31, 2021 @RUNAMUCK My go to for lots of things is comac, zero human interaction and stuff just turns up on the courier etc https://www.comac.co.nz/rubber-grommets 5 1 Quote
h4nd Posted July 31, 2021 Posted July 31, 2021 22 hours ago, RUNAMUCK said: Rubber grommets/bungs etc.. Wheres a good place to buy em? I visited the local rubber merchants (who I fucking despise intensely) this morning. Everything in their inventory is imperial. Less than zero use on my build. What's everyone's go to? What sizes you need? I take it Para failed to provide the necessary? Jaycar have a few (6mm wire: https://www.jaycar.co.nz/9-5mm-rubber-grommets-cable-dia-6mm-pk-8/p/HP0702) And you can raid my junk bin, or on Monday try electrical suppliers like ideal: https://www.google.com/maps/place/Ideal+Electrical+-+Christchurch+Sydenham/@-43.5488826,172.6370553,15z/data=!4m9!1m2!2m1!1selectrical+supply!3m5!1s0x0:0x8af6f693f78e208f!8m2!3d-43.5417008!4d172.6309181!15sChFlbGVjdHJpY2FsIHN1cHBseVoTIhFlbGVjdHJpY2FsIHN1cHBseZIBF2VsZWN0cmljYWxfc3VwcGx5X3N0b3Jl or Redcliffe: https://www.google.com/maps/place/Radcliffe+Electrical/@-43.5338968,172.6347574,15z/data=!4m9!1m2!2m1!1sradcliffe+electrical!3m5!1s0x0:0xd55b399a3a24c6a8!8m2!3d-43.5355638!4d172.6485419!15sChRyYWRjbGlmZmUgZWxlY3RyaWNhbCIDiAEBkgEVZWxlY3RyaWNhbF93aG9sZXNhbGVy Quote
JustHarry Posted August 1, 2021 Posted August 1, 2021 On 31/07/2021 at 16:45, datlow said: @RUNAMUCK My go to for lots of things is comac, zero human interaction and stuff just turns up on the courier etc https://www.comac.co.nz/rubber-grommets @RUNAMUCK +1 for comac. We use them at work. Almost always have what we need. No human interaction is a bonus 3 1 Quote
waspman Posted August 2, 2021 Posted August 2, 2021 On 31/07/2021 at 13:06, RUNAMUCK said: I literally only required like 5 grommets. I dont want anything other than exactly the ones I need. Yes I want them Naow. What size do you need?, I have some that fit about a 30mm hole plus I might still have some that fit about a 10mm hole, did have some big ones but not sure if I can find them, they are ex factory early Mazda ones. Edit, I read you wanted bungs, also have grommet, they are about 20mm od Quote
RUNAMUCK Posted August 2, 2021 Posted August 2, 2021 25 minutes ago, waspman said: What size do you need?, I have some that fit about a 30mm hole plus I might still have some that fit about a 10mm hole, did have some big ones but not sure if I can find them, they are ex factory early Mazda ones. Edit, I read you wanted bungs, also have grommet, they are about 20mm od Another person closer to home has said they'll check their stash. I'll report back once I hear back. Quote
RUNAMUCK Posted August 4, 2021 Posted August 4, 2021 On 02/08/2021 at 22:06, RUNAMUCK said: Another person closer to home has said they'll check their stash. I'll report back once I hear back. Thanks OS! A box of grommets was just delivered. Not sure who you are? Not latex rubber/silicone for a change. (Which is the norm for mystery packages from OS users) 2 3 Quote
