Everything posted by waspman
waspman replied to h4nd's topic in Other Projects
Found another sign covered in paint, this one was much harder to remove the paint from The whole sign was covered in paint, I believe it was used when testing a spray gun for painting. Tried a few different thinners/turps etc, ended up using some old paint stripper to soften the black paint and then scrub with commercial thinners, unfortunately the fine black outline on the lettering has been lost but it certainly looks better than before. still looks a bit shit but will ok for shed art.- 1282 replies
- 21
These are some shit images on a white ute, I have some of a yellow version with mag wheels that looks heaps better, just can't find them
You could always add in the Karere stripes, this was the factory supplied diagram on how to apply them, from memory they also rolled white steel rims
The panels are a little sunburnt but it has come up pretty good really want to hook up some LED lights but have no idea of where to start, might go to Jaycar and see what they suggest just need to get some rivnuts so I can screw the top back on, all the fastenings were corroded/snapped and the internal flouro tube setup had already been gutted. Not sure how to mount it in the garage but will sort something.- 1282 replies
- 33
This is not something I have built, more like something saved. Came across an old car dealer lightbox that had been painted over many years ago It was in pieces so I paint stripped the aluminum frame, everything was covered in a thick coat or two of cream coloured house paint. Inside of the lightbox looked good Noticed when cleaning up after paint stripping that the ancient can of thinners I had softened the paint quite noticeably, not knowing how to remove the old house paint without damaging the plastic sign I decided to test a small piece, to my surprise it softened the paint nicely allowing me to gently scrap the paint off After quite a few hours over a few weekends it was time to reassemble -
That is very cool, would you consider making them for sale? -
Kimjon's 50cc (then later ... 150cc and 400cc...then 1000cc) of awesomeness!
waspman replied to Kimjon's topic in Two Wheels
Looks good, 3 speed 90 with the large engine door? Or asthmatic 50? I have the early model 90, 1965, 3 speed with small door so engine upgrade options are almost nil. I used to have an SS90, that was a fun scoot - one I should never have sold -
Great read, it triggered a memory of my late father wearing a watch with an orange face, Mum didn't remember it until I showed her a google pic of what i recalled, caught up with her tonight and she had found it, turns out its a Seiko 6139-6002 from around '73, aka a Seiko Pogue, it seems to work except for the chronograph buttons. Thanks for posting about your watch efforts, from that I now have something very personal that I can wear to remind me of the grumpy old bastard, while I would love to have the ability to open it up i might leave this one to the experts!
When using clear hose with water be aware that any light will allow bacteria to grow and possibly turn the clear hose a little green, easy option is to cover the hose with some dark tape, then if there is some growth you won't see it...
@Mourning Cupcake if you need the rubber stoppers that act as a bumper on the wellside flick me a pm as I have a bunch of original Mazda ones
What size do you need?, I have some that fit about a 30mm hole plus I might still have some that fit about a 10mm hole, did have some big ones but not sure if I can find them, they are ex factory early Mazda ones. Edit, I read you wanted bungs, also have grommet, they are about 20mm od
As above, fix the rust and roll it old man spec, the vinyl roof and wheels are perfect.
Thanks, in the scrap bin they go!
Have found these Toyota shims, quick Google says kingpin shims? Are these something that people require?
Check out the SIP guys on YouTube They do some cool looking trips in europe -
Nice work, Where did you source the brake fluid reservoir from I could do with one of those
Make sure you enter before you go, they like to "select" cars, not just have cars turn up, plus be ready for an early start - like being there at 8am and can't get your car until 4pm
Could be the Veglia (vague liar) speedo, had that issue on one of mine and a little silicone spray into the back of the speedo did the trick
Replace the plastic hose with the proper rubber fuel hose as the pvc will go hard and either crack with the good vibrations or most likely be a bitch to remove next time, I would make sure you run a filter in that line, this will save you cleaning the carb on the side of the road in the pissing rain... I found this out the hard way!
There is also the Twin Rivers car show on the 25th at the A&P showgrounds as well
There is one of these in the UK that has been attached to a lambretta as a sidecar, I had a magazine somewhere with an article on it, looked pretty well done.
I believe that this could be one of the first Mazda's brought into NZ by Champion motors in Christchurch(who was part of Amuri motors?), do you have the original paperwork/ownership papers for it? I believe one of the senior staff owned the car.
Is anyone going to this?
