Nominal Posted September 14, 2019 Posted September 14, 2019 Weld a bolt to it, heat will help loosen it up. 4 Quote
SOHC Posted September 14, 2019 Posted September 14, 2019 weld a big washer that fits over it on then a big nut and fill the center with weld and as above the heat will sort it out, the washer allows you to be heavy handed with the MIG 4 Quote
Nominal Posted September 14, 2019 Posted September 14, 2019 Been doing rusty screws this way lately 1 Quote
a.craw4d Posted September 14, 2019 Posted September 14, 2019 32 minutes ago, Adoom said: Weld a handle on it. This^. Just weld a simple piece of flatbar to it and undo with an adjustable crescent. Works every time. Quote
Yowzer Posted September 14, 2019 Posted September 14, 2019 Found this on a car recently / fab fuck ups 5 1 1 Quote
SOHC Posted September 14, 2019 Posted September 14, 2019 If someone is horrible to you you can make them a sump plug from the end of a candle 1 1 1 Quote
Get it done Posted September 14, 2019 Posted September 14, 2019 What has been said , the welding process will shrink the plug , an bar will allow you to turn it . just make sure you let it cool first Quote
oldrx7 Posted September 15, 2019 Posted September 15, 2019 cheers all, welder is at the in-laws so that’s next weekends job now. Quote
Adoom Posted September 15, 2019 Posted September 15, 2019 28 minutes ago, oldrx7 said: cheers all, welder is at the in-laws so that’s next weekends job now. Who needs a welder? Sorry, couldn't find it in English. 1 Quote
Bling Posted September 21, 2019 Posted September 21, 2019 I've always welded nuts on, perfect hole in the middle to fill with weld. Could potentially cut some flats on that one though and put the next sized down socket on it. If needed before you get the welder. 1 Quote
Steelies Posted September 23, 2019 Posted September 23, 2019 1995 Suzuki super carry van. Gluey windscreen seal, or poppy outy windscreen seal? Planning work on one but unsure on seal type. I presume it's oldschool style non glue but would rather not encounter surprise if I can help it. Go! Quote
oldrx7 Posted September 24, 2019 Posted September 24, 2019 On 21/09/2019 at 13:14, Bling said: I've always welded nuts on, perfect hole in the middle to fill with weld. Could potentially cut some flats on that one though and put the next sized down socket on it. If needed before you get the welder. Tried that before ending up with the welder - using the angle grinder and file, the nut would always end up rounding off again. However, success was had on Sunday arvo 4 Quote
Adoom Posted September 24, 2019 Posted September 24, 2019 That I would say is an EXCELLENT handle! 2 1 Quote
tortron Posted October 8, 2019 Posted October 8, 2019 How dry do you guys suppose mig co2/argon mix is? Quote
Ghostchips Posted October 8, 2019 Posted October 8, 2019 Does anyone here know how a 'coil on plug' can sense when a spark has occurred & use that sensor wire thing? Quote
kws Posted October 15, 2019 Posted October 15, 2019 Is it better to run a 9v coil and ballast resistor, or a 12v coil direct? Quote
SOHC Posted October 15, 2019 Posted October 15, 2019 I cannot find a LH door mirror for an 04 Mitsubishi colt 4 door hatch thing, there are none on eBay, anyone got a link to a good place? Quote
tortron Posted October 15, 2019 Posted October 15, 2019 22 minutes ago, SOHC said: I cannot find a LH door mirror for an 04 Mitsubishi colt 4 door hatch thing, there are none on eBay, anyone got a link to a good place? Try mitsubishi z30 Also some at pickapart Quote
