  • Replies 71
The problem with the A pillar rust is it starts between the gutter and the pillar. You really need to remove the gutter to get at it properly or it will always keep growing
Yeah thought about removing them, looks easy enough, just need a new spot weld drill
  • 5 months later...
Im liking the progress and where this project is heading.
when you swap the lsd diff centre over could you do a bit of a story on that as interested to see how that goes
Cheers!
It’s most likely going to be done at a diff shop, but I’ll try and get as much info as I can
i just wanted to come and say i like this. Thats all... i have nothing else of value to add to this post/build, you're doing a killer job!
  • 4 months later...
22 hours ago, CUL8R said:
Man that is some super tidy work indeed
Do you do that for a job as well?
Cheers man! Nope I am a fabricator, started new job last week building hotrods though! Did do a couple years part time during high school at a car painters though, so that helps a little, otherwise just it’s just practise and hoping for the best haha
  • 3 months later...
On 27/02/2021 at 08:46, Jo_Rolla said:
Car is looking amazing. Got any details on the brake upgrade? I've been looking for one that will still fit 13s. How much did it push your offset out?
Peugeot 106 rotors, need drilling to match the hub pcd and some machining needs done to the hub. Hub is in the same place as factory, but needs at least a 12mm spacer so the wheel face clears the calliper. I have a spare set of the brackets that are needed if you’re interested
  • 3 months later...
Just binge-read through pretty much your whole build, very jealous of your skills! looks like its going to be awesome once its done. Keep it up!
On 26/05/2021 at 23:16, enzee said:
Where have you sourced the windscreen seal filler strip from? Basis https://basisnz.co.nz/products/sku217-405?_pos=6&_sid=fe4b1df7d&_ss=r
Be interested to see how it works out as I've got a couple of screens to do
I finally got some samples from basis and this one https://basisnz.co.nz/products/sku217-007 works perfectly!
Cheers man, pretty excited to get it back on the road!
