SOHC Posted October 16, 2019 Share Posted October 16, 2019 1 hour ago, tortron said: Try mitsubishi z30 Also some at pickapart Are yes thank you Z30 brings up alot more stuff Quote Link to comment Share on other sites More sharing options...
NickJ Posted October 16, 2019 Share Posted October 16, 2019 On 09/10/2019 at 10:23, Ghostchips said: Does anyone here know how a 'coil on plug' can sense when a spark has occurred & use that sensor wire thing? Had a look but can't find the paper I read on it, google "sparkplug ionisation current" and that might lead you down the correct rabbit hole 1 Quote Link to comment Share on other sites More sharing options...
kws Posted October 16, 2019 Share Posted October 16, 2019 11 hours ago, SOHC said: I cannot find a LH door mirror for an 04 Mitsubishi colt 4 door hatch thing, there are none on eBay, anyone got a link to a good place? Complete mirror, or just glass? Glass should be available from Mitsi dealer pretty cheap, maybe even whole mirror. NZ/JDM models are Z21 to Z27 depending on spec. If you let me know rego I can check P&A. Quote Link to comment Share on other sites More sharing options...
kws Posted October 16, 2019 Share Posted October 16, 2019 3 hours ago, NickJ said: Had a look but can't find the paper I read on it, google "sparkplug ionisation current" and that might lead you down the correct rabbit hole Isnt that knock sensing? Quote Link to comment Share on other sites More sharing options...
NickJ Posted October 16, 2019 Share Posted October 16, 2019 8 hours ago, kws said: Isnt that knock sensing? Quite possibly, there were a few fancy tricks hiding in there, I just can't remember the details Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 16, 2019 Share Posted October 16, 2019 9 hours ago, kws said: Complete mirror, or just glass? Glass should be available from Mitsi dealer pretty cheap, maybe even whole mirror. NZ/JDM models are Z21 to Z27 depending on spec. If you let me know rego I can check P&A. Thank you, it’s the whole mirror, but I think it could be fixed with a new glass and outer cover, I think the wreckers might have one. Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted October 16, 2019 Share Posted October 16, 2019 10 hours ago, kws said: Isnt that knock sensing? Not entirely, but you could use it for knock sensing.https://www.vehicular.isy.liu.se/Publications/Lic/02_LIC_962_IA.pdf As i read this i have no idea how to couple a high voltage coil to it or to a sensitive analogue input i'd likely use without frying something. The marvels of modern technology. Quote Link to comment Share on other sites More sharing options...
NickJ Posted October 17, 2019 Share Posted October 17, 2019 Got shown this over the weekend, surprised I don't recall seeing it before, as its right confusing and cool at the same time. 2 Quote Link to comment Share on other sites More sharing options...
Guest Posted October 21, 2019 Share Posted October 21, 2019 Yes that is cool and makes so much sense. Will have to watch it again, cheers! Quote Link to comment Share on other sites More sharing options...
Bling Posted October 23, 2019 Share Posted October 23, 2019 Ball joint grease, does it matter what you use? Internet says complex lithium, local mechanic uses general grease. I have general grease, but want to be sure they'll last. What say you OS? Much easier for me to just use what I have as I only have one grease gun. The grease I have is probably budget stuff too. So i'd potentially buy new grease anyway, but keen to know which type. Quote Link to comment Share on other sites More sharing options...
oldrx7 Posted October 23, 2019 Share Posted October 23, 2019 I've always used the general grease / whatever grease is in the gun, never had problems, but then again I've never owned a car more than 2-3 years after replacing them. 1 Quote Link to comment Share on other sites More sharing options...
Ashkellybarr Posted October 23, 2019 Share Posted October 23, 2019 39 minutes ago, Bling said: Ball joint grease, does it matter what you use? I wouldn’t get to fussy. Be more focused on the boot sealing well to make sure nothing gets in there. we’re had some guys at work put the wrong grease in robots that spec high grade lithium. Meant to get changed once a year or every 10khrs... a lot out there go waaaay past that with the wrong grease and tbh we’ve never had an issue 1 Quote Link to comment Share on other sites More sharing options...
kws Posted November 5, 2019 Share Posted November 5, 2019 On 15/10/2019 at 22:07, kws said: Is it better to run a 9v coil and ballast resistor, or a 12v coil direct? Bump? Quote Link to comment Share on other sites More sharing options...
Yowzer Posted November 5, 2019 Share Posted November 5, 2019 I've always converted my points cars to 12V coils. No idea if one is better than the other, but modern coils can pack a lot more punch than they used to. Quote Link to comment Share on other sites More sharing options...
kws Posted November 6, 2019 Share Posted November 6, 2019 I have both here, So I guess there is no advantage to keeping the old ballast system and just run the 12v coil. Quote Link to comment Share on other sites More sharing options...
Roman Posted November 7, 2019 Author Share Posted November 7, 2019 I need to remake some radiator hoses, has anyone used the mackay flex hoses? Are they as strong as normal ones? Quote Link to comment Share on other sites More sharing options...
ajg193 Posted November 7, 2019 Share Posted November 7, 2019 Anyone have techstream working with an aurion? Flatmate got a dodgy chinese techstream and it detects the car is a GSV with 2GR-FE but only lists camrys and lexi as options. Picking camry of the date range and OTHER doesn't get any data from the ECUs @AllTorque, you a toyota master? Quote Link to comment Share on other sites More sharing options...
AllTorque Posted November 7, 2019 Share Posted November 7, 2019 Aurion badge is only used in Australia and NZ. Everywhere else they are V6 Camry. Our cars are Aussie built, so you want to find the TMCA option. Try every option, something should connect. Maybe ES350. Does the Techstream connect to other cars? 1 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted November 7, 2019 Share Posted November 7, 2019 We've got it to connect and show stuff but as soon as we click data list the software crashes. Same behavior in xp and windows 7. We will need to find someone else with a modern Toyota to test it on some time Active tests crash too Nothing wrong with the car, we just want to play with data view Quote Link to comment Share on other sites More sharing options...
Bling Posted November 7, 2019 Share Posted November 7, 2019 What type of bolts would you use on critical car parts? High tensile 8.8 suitable? Any particular coating to avoid / go for? One example is steering connection to rack, thread has seen much better days. Quote Link to comment Share on other sites More sharing options...
