Seedy Al Posted December 12, 2017 Share Posted December 12, 2017 2 minutes ago, 00quattro00 said: Coils Chamberlain Auto Springs Ltd 1 Quote Link to comment Share on other sites More sharing options...
Transom Posted December 12, 2017 Share Posted December 12, 2017 Just now, Seedy Al said: Also, A+++++ for citric acid cost me a total of 2 dollars besides the 6 dollar tub I bought which i now can use for all sorts Once machined this will be blinging Yup use citric acid from supermarket for cooling system flush cos all the branded rad flush s have... active ingredient -citric acid ... 1 Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted December 12, 2017 Share Posted December 12, 2017 Looking for some help with a shop press. It's a 55 ton American built Carolina press. Two stage Manual pump. I had been able to pressurise the system and lower the ram,.but unable to release the pressure. Yesterday I drained the fluid and released the pressure( covering my self in hydrologic fluid in the processes. Fluid was full of water as it had been stored outside, and a petcock was missing off the top. Has any one ever rebuilt the pump unit on a big press? I'm hoping it's just o-rings and a good clean? Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted December 12, 2017 Share Posted December 12, 2017 This is it here http://www.carolinaequipment.com/04_Presses Quote Link to comment Share on other sites More sharing options...
Mof Posted December 12, 2017 Share Posted December 12, 2017 1 hour ago, Carsnz123 said: I've had leaves made by Bellamy and East in CHCH. Good bunch of guys with oldschool kit. All the springs I have got from them have been crap. Quote Link to comment Share on other sites More sharing options...
Alfashark Posted December 12, 2017 Share Posted December 12, 2017 1 hour ago, 00quattro00 said: Coils Call Archers or whatever they'e called in Rotorua. Ask for Phil Y and tell him I sent you. Quote Link to comment Share on other sites More sharing options...
peteretep Posted December 12, 2017 Share Posted December 12, 2017 2 hours ago, Seedy Al said: Also, A+++++ for citric acid cost me a total of 2 dollars besides the 6 dollar tub I bought which i now can use for all sorts Once machined this will be blinging shit thats awesome 3 Quote Link to comment Share on other sites More sharing options...
peteretep Posted December 12, 2017 Share Posted December 12, 2017 1 hour ago, Mr Vapour said: Looking for some help with a shop press. It's a 55 ton American built Carolina press. Two stage Manual pump. I had been able to pressurise the system and lower the ram,.but unable to release the pressure. Yesterday I drained the fluid and released the pressure( covering my self in hydrologic fluid in the processes. Fluid was full of water as it had been stored outside, and a petcock was missing off the top. Has any one ever rebuilt the pump unit on a big press? I'm hoping it's just o-rings and a good clean? The valve to release the pressure is a needle valve of some kind im guessing, I would check there first. And some internal or external springs return the ram to home position? they are all good? Could be that valve is releasing but nothing is actually pushing/pulling the ram home Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted December 12, 2017 Share Posted December 12, 2017 6 hours ago, peteretep said: The valve to release the pressure is a needle valve of some kind im guessing, I would check there first. And some internal or external springs return the ram to home position? they are all good? Could be that valve is releasing but nothing is actually pushing/pulling the ram home Yeah springs are all good. The front had clear instructions stating not to turn the release more than once or it will disable the press. Some one had already played b4 I got it so was prob already in disabled mode? Needle also has damaged o-ring Quote Link to comment Share on other sites More sharing options...
peteretep Posted December 12, 2017 Share Posted December 12, 2017 Hmm, I think to re-enable it, you would just turn it back in? Or remove the whole needle and oil would leak out everywhere. It sounds worthwhile investigating that disable function though. Possibly an o-ring/débris has become stuck somewhere. Hydraulics are pretty powerful though so would have to be stuck in there pretty good. When you say it’s stuck. Do you mean it is absolutely stuck, or maybe it retracts really slowly? Quote Link to comment Share on other sites More sharing options...
Carsnz123 Posted December 12, 2017 Share Posted December 12, 2017 8 hours ago, Mof said: All the springs I have got from them have been crap. Rully? First time I've heard bad things about them. Been told a few yarns about chamberlains having questionable quality at times. Quote Link to comment Share on other sites More sharing options...
sentra Posted December 12, 2017 Share Posted December 12, 2017 jack the pump with the relief open and see if it builds pressure or shoots a booger out and fixes it 4 Quote Link to comment Share on other sites More sharing options...
Alfashark Posted December 13, 2017 Share Posted December 13, 2017 16 hours ago, Alfashark said: Call Archers or whatever they'e called in Rotorua. Ask for Phil Y and tell him I sent you. Further to this, if he still draws a blank, tell him Doug's brother in law sent you. Quote Link to comment Share on other sites More sharing options...
chasinthemirage Posted December 19, 2017 Share Posted December 19, 2017 Does anyone know of anywhere that sells fuel injector seal sets? Haven't had any luck on google except for one place in Aussie. The seals I need are for the RB30ET injectors. Could possibly match them at DSL etc but would rather just purchase a set if possible. Edit: Already spoken to Appco/BNT who don't have listings. Quote Link to comment Share on other sites More sharing options...
Adoom Posted December 19, 2017 Share Posted December 19, 2017 19 minutes ago, chasinthemirage said: Does anyone know of anywhere that sells fuel injector seal sets? Haven't had any luck on google except for one place in Aussie. The seals I need are for the RB30ET injectors. Could possibly match them at DSL etc but would rather just purchase a set if possible. Edit: Already spoken to Appco/BNT who don't have listings. o-rings? http://www.nzefi.com/product/fuel-injector-service-kit-nissan-r32-rb20det-rb25de-rb26dett/ Or these guys. http://www.cdlautoparts.co.nz/media/product_range/cedele/EFI Injector Components Catalogue - April 2012.pdf 2 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted December 19, 2017 Share Posted December 19, 2017 Have you checked Nissan? 1 Quote Link to comment Share on other sites More sharing options...
Mof Posted December 19, 2017 Share Posted December 19, 2017 I would go dsl way before appco/bnt 1 Quote Link to comment Share on other sites More sharing options...
chasinthemirage Posted December 19, 2017 Share Posted December 19, 2017 1 hour ago, Adoom said: o-rings? http://www.nzefi.com/product/fuel-injector-service-kit-nissan-r32-rb20det-rb25de-rb26dett/ Or these guys. http://www.cdlautoparts.co.nz/media/product_range/cedele/EFI Injector Components Catalogue - April 2012.pdf I have a feeling that there's something different with the 20/25 injectors but I'll have to double check. The cdl catalogue looks promising though. 11 minutes ago, AllTorque said: Have you checked Nissan? No I haven't bothered with Nissan, figured it'd be too old for them to have anything available anymore. Quote Link to comment Share on other sites More sharing options...
kyteler Posted December 19, 2017 Share Posted December 19, 2017 Don't be too sure about that, give @Brdflu a yodel. 3 Quote Link to comment Share on other sites More sharing options...
chasinthemirage Posted December 19, 2017 Share Posted December 19, 2017 He's on the phone according to the receptionist so I shall pester him via email. Quote Link to comment Share on other sites More sharing options...
