ajg193 Posted November 21, 2017 Share Posted November 21, 2017 Soften the steel. Heat it up and cool it slowly so it doesn't get hard again, then you should be able to drill it out. Quote Link to comment Share on other sites More sharing options...
kws Posted November 21, 2017 Share Posted November 21, 2017 I was going to try that but found one random silver drill bit in my cabinet, which managed to cut 3/4 of the way through before snapping. Off to bunnings to buy some more Guess the repco ones arent worth the rubbish bin. Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted November 21, 2017 Share Posted November 21, 2017 1 hour ago, ajg193 said: Soften the steel. Heat it up and cool it slowly so it doesn't get hard again, then you should be able to drill it out. I've found rusty looking, magnetic steel that no matter how much it was annealed it would not even be scratched by anything, not even cobalt drill bits (which would go through stainless like butter). Doubt they'd be that stuff. but IDK what it was. 3 Quote Link to comment Share on other sites More sharing options...
fletch Posted November 21, 2017 Share Posted November 21, 2017 s14 non turbo rear calipers on hyundai sonata 3L v6 discs fit hilux diff nicely 2 Quote Link to comment Share on other sites More sharing options...
Bling Posted November 22, 2017 Share Posted November 22, 2017 On 11/19/2017 at 18:19, xsspeed said: do i bother with anything other than 15w40 castrol gtx modern engine for my 1988 twenny debt? What is the factory required specs? I used to put that in my 20v / 16v as they both used oil. I run synthetic in things now as they don't drink it. I guess it would come down to engine condition too. I run 5w30 fully synthetic in dailies here, but neither are '88ish. Grabbed a 20L drum on spesh as I got sick of storing more than one oil. Totally turning into a Ling post... but my main point was that I used that oil because it was cheap and the engines were pretty worn. So it comes down to factory specs / engine condition IMO. I spent a while sifting through the oil threads on here, Speeno seems to know his stuff on oil. Quote Link to comment Share on other sites More sharing options...
SOHC Posted November 22, 2017 Share Posted November 22, 2017 Where would I find an AC Delco D203 ignition condenser in Auckland? Quote Link to comment Share on other sites More sharing options...
datlow Posted November 22, 2017 Share Posted November 22, 2017 Ling/fyi citroens (bx anyway) have handbrake calipers mounted to the front wheels for max reverse handies 4 Quote Link to comment Share on other sites More sharing options...
datlow Posted November 22, 2017 Share Posted November 22, 2017 On 21 November 2017 at 17:45, kws said: I was going to try that but found one random silver drill bit in my cabinet, which managed to cut 3/4 of the way through before snapping. Off to bunnings to buy some more Guess the repco ones arent worth the rubbish bin. Engineering supply shops blackwoods etc hss jobber drill bits, cheap and good can buy singular in all sizes https://www.nzsafetyblackwoods.co.nz/en/evacut-drill-jobber-blackjet-hss6-00mm-each--04125244 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted November 22, 2017 Share Posted November 22, 2017 blackwoods are the most useless cunts on the earth 1 Quote Link to comment Share on other sites More sharing options...
datlow Posted November 22, 2017 Share Posted November 22, 2017 Yes, yes they are but we have an account there and just order of there book with there part numbers to minimise fuck ups Quote Link to comment Share on other sites More sharing options...
kws Posted November 22, 2017 Share Posted November 22, 2017 I ended up grabbing a set of Evacut HSS bits from Bunnings and they worked a treat. Clearly the Repco ones are chinesium, and softer than cheese. I even managed to actually pretzel one. Never done that before, usually they snap, not bend 90 degrees Quote Link to comment Share on other sites More sharing options...
Yowzer Posted November 22, 2017 Share Posted November 22, 2017 1 hour ago, SOHC said: blackwoods are the most useless cunts on the earth Never had this experience tbh, all dealings with them have been top notch. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted November 22, 2017 Share Posted November 22, 2017 1 minute ago, kws said: I ended up grabbing a set of Evacut HSS bits from Bunnings and they worked a treat. Clearly the Repco ones are chinesium, and softer than cheese. I even managed to actually pretzel one. Never done that before, usually they snap, not bend 90 degrees I've yet to break any of my evacut bits. In saying that I'm not a hard bastard on them, keep them sharp and plenty of CDT when drilling anything hard but they've lasted well regardless. Quote Link to comment Share on other sites More sharing options...
datlow Posted November 22, 2017 Share Posted November 22, 2017 8 hours ago, Firetruck said: Never had this experience tbh, all dealings with them have been top notch. hamilton blackwoods and bay engineers were great wellington ones are absolutely useless have started using mana bearings in welly a bit theyre A+ parts over night etc 2 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted November 22, 2017 Share Posted November 22, 2017 All comes down to who you employ dunnit? 1 Quote Link to comment Share on other sites More sharing options...
Roman Posted November 22, 2017 Author Share Posted November 22, 2017 Just finished a big wiring mission, and MAF sensor just constantly outputs 1.6 volts. I swap in Altezza MAF instead and it works. Decide that my other one is faulty. Think about it some more. Check with a multimeter. Toyota decided to switch the order of the signal and 12v supply pins between the two. Y U DO DIS 2 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted November 23, 2017 Share Posted November 23, 2017 The best one is when you go to check the resistance of something and continuously get infinite. After 10 minutes of trouble shooting you notice the multimeter is in hold mode. 5 1 Quote Link to comment Share on other sites More sharing options...
frushez Posted December 2, 2017 Share Posted December 2, 2017 shit question: should a 1JZ IACV be able to be pressed off/on by hand? i feel like mine's jammed but googles being shit Quote Link to comment Share on other sites More sharing options...
xsspeed Posted December 2, 2017 Share Posted December 2, 2017 Pics of type? Is it a rotary valve? Should be able to move the valve but you need a stick to poke those Quote Link to comment Share on other sites More sharing options...
xsspeed Posted December 2, 2017 Share Posted December 2, 2017 Oh NM i see on google it looks like its a diaphragm/piston type, I cant help Quote Link to comment Share on other sites More sharing options...
