66gt Posted October 29, 2017 Posted October 29, 2017 On 06/09/2015 at 21:09, The Bronze said: Show and tell... Vinyled parcel tray. Will probably blind me being too light, but fuckit, live once. Guts out Oh, hello quiet... New chocolate Autodec carpet. Pretty average fit so far, too big over the hump, shitty seams. one gave way in the fucking unfolding... Split Seam: Will leave it laid out for a day or so and see if it sits down a bit. Yes, it has underfelt. Good at 10 feet though... Did the first two stages of the fuel tank POR kit, still trying to dry the thing out, slow process. Hopefully some more heatgunning and air blown through this week and it'll be dry enough for the last stage. Autodec carpets are shit. I bought a set for my Cortina and ended up gettting an upholstery mate to remake them. I reckon Stevie Wonder is Autodecs carpet maker. 1 1 1 Quote
chasinthemirage Posted October 30, 2017 Posted October 30, 2017 Man this thing is lush. Do want. Quote
Nominal Posted December 3, 2017 Posted December 3, 2017 Bummer about the gas tank. You might be able to get a radiator place to solder it up. I've fixed a couple this way (no naked flame with an electric iron). Quote
kyteler Posted December 5, 2017 Posted December 5, 2017 Hylomar mate. Blue stuff should do it. Can get it from Repco, etc. I've used it to seal thermostat housings, water pumps, diesel drain bungs, etc. It's fuel/oil resistant so should be the go. Basically a non-setting goop. I'll likely use it soon on my D21 to fix the complete lack of a fuel pump gasket that I discovered when I filled the thing right up. Quote
The Bronze Posted December 5, 2017 Posted December 5, 2017 Joy, I have this on the shelf from head gasketing the EB. Win. I also have aviation sealant. I just want the c*&ting thing done. Quote
peteretep Posted December 5, 2017 Posted December 5, 2017 you should also ring up rarespares and tell them what wallies they are. Bad repro parts are such a pain in the arse 2 Quote
The Bronze Posted December 5, 2017 Posted December 5, 2017 Have done before. Zero fucks response. Quote
1963 AP5 Posted December 6, 2017 Posted December 6, 2017 What diameter is the sender seal? This type of problem is common with old Valiant's and you can get a special reproduction seal that is a little thicker than original to sort it out. The Valiant ones are 3 inches diameter, if the Falcon ones are the same size (or very close) you may be able to use one of these. https://www.pentastarparts.com.au/store/index.php?l=product_detail&p=1931 1 Quote
sheepers Posted December 23, 2017 Posted December 23, 2017 use a straight edge (like a bit of 4x2 or a bit of angle iron) and hold it against the wheel so it's as flat as you can get it. mark on the floor directly in front of the tyre and another mark at the end of your straight edge (like 2 meters away or something) aim for about 10mm smaller at the 2m away mark. that should get it so you can drive it without any drama Quote
cletus Posted December 23, 2017 Posted December 23, 2017 Looks good on the whitewalls, was thinking about a set for mine 1 Quote
yetchh Posted December 24, 2017 Posted December 24, 2017 On 05/12/2017 at 23:15, The Bronze said: Have done before. Zero fucks response. Hey bro, have you heard of gt Ford performance in Melbourne? Bit more spendy than rs but their shit is millions better (most of it anyway) http://www.falcongt.com.au/Shop/ It's where I used to get all my shiz... 1 Quote
piazzanoob Posted December 24, 2017 Posted December 24, 2017 Ive had to do this a couple of times now with customers who wont pay for a wheel alignment after we have replaced steering or suspension components. get yourself out a measuring tape and put one end of the tape in the middle grove of the tyre and run it across to the other front tyre into the same middle grove. so lets say the measurement is 2.300mm for example so now that you have measured the front face on the front tyres now measure from the back face of the front tyres in the same middle tread grove as previously. and lets say the back measurement is 2.400mm so the vehicle has 100,mm of toe out. so set the steering wheel straight. also do this while the car is resting on the ground. not jacked up. and adjust the tie rods until the measurement is the same on both faces or close enough. doing this should get it quite close and fairly straight. but wont be that accurate if your caster and camber is also upto shit. this pic gives you a better idea best of luck! 1 Quote
66gt Posted December 24, 2017 Posted December 24, 2017 Who the fuck would be too tight to get a wheel alignment after suspension componentry replacement. You diagram is excellent and good enough to get it to an alignment shop 2 1 Quote
Mof Posted December 25, 2017 Posted December 25, 2017 I don't trust the tyre tread Jack up the wheels, spin the wheel and put the pointy end of a screwdriver against the tread. Leaves a nice dark line that is straight. Put the car on the ground and roll it back and forth a bit to settle the suspension. Do your measurements Quote
Testament Posted January 8, 2018 Posted January 8, 2018 On 5/12/2017 at 23:15, The Bronze said: Have done before. Zero fucks response. what are ya on about, never had a complaint must be something you've done 1 Quote
flyingbrick Posted January 8, 2018 Posted January 8, 2018 Stupid comment i think but will say it anyway.. Isnt the sender supposed to turn a bit more in its seat and click over those bulges? Sorry if thats the dumbest thing ever suggested. Quote
Bearded Baldy Posted May 23 Posted May 23 Don't sell it, in another eleventy years when my XC is nearly done, i will need someone to cruise with that we can never tee up a date to do it. 1 Quote
