mjrstar Posted February 20, 2013 Author Posted February 20, 2013 I know of the MR2 as being a suitable donor for the P.S pump, i was wondering if there is much else out there possible a bit lighter / more compact and newer.. Quote
KKtrips Posted February 20, 2013 Posted February 20, 2013 Could try Rover MGF - they are fairly compact from memory Although they are British.. (cripes...) 1 Quote
Raizer Posted February 20, 2013 Posted February 20, 2013 The Rovers have the fully electric type that's part of the column aye? Quote
KKtrips Posted February 20, 2013 Posted February 20, 2013 The Rovers have the fully electric type that's part of the column aye? Yup Quote
mjrstar Posted February 20, 2013 Author Posted February 20, 2013 Googled the mazda 3 and it came up with millions if faults/complaints etc... Quote
AllTorque Posted February 20, 2013 Posted February 20, 2013 Googled the mazda 3 and it came up with millions if faults/complaints etc... In my defence, I didn't say they were good, just that they had them. 1 Quote
mjrstar Posted February 20, 2013 Author Posted February 20, 2013 Probably no worse than the suggestion of something from pomgolia.. Quote
mikuni Posted February 20, 2013 Posted February 20, 2013 About 1998 to 2004 shape Holden Astras have a bulky electric pump too. Can't comment on their reliability, but they are relatively cheap and easy to find and the reservoir is incorporated in the pump, so might be good to tuck away somewhere and just run high pressure hoses to the rack. I'm thinking of using an electric assisted column in my track car with a dial to adjust assist as mentioned above. They can be had in this country from later model Holden Barinas Quote
flyingbrick Posted February 20, 2013 Posted February 20, 2013 Wow, did not know those existed. There must be some kinda tq sensor on the column to work out how much assist to give and in which direction??? Quote
KKtrips Posted February 20, 2013 Posted February 20, 2013 MGF Column - If you want one or want to ask some spec details you could ring www.mgparts.co.nz and talk to Paul Walbran Or try Ray Hartley here in Wellington but I would doubt he has anything.. It looks from the picture it may only have 2 or 3 wires which should mean it is ultra simple which I would guess is power and earth, it could all be load related from the column or if there is a third wire then that is possibly a resistance relative to speed which may be controllable via a switch with a couple of resistance values.. . Quote
jakesae101 Posted February 20, 2013 Posted February 20, 2013 ray does have some parts he did a bit of work on my step dads when he stupidly brought one then sold it to buy a mx5 haha Quote
mjrstar Posted February 21, 2013 Author Posted February 21, 2013 Interesting to see there are a few options other than the MR2 setup.. Quote
mjrstar Posted February 23, 2013 Author Posted February 23, 2013 Can i successfully shorten this? Place your bets now. Quote
flyingbrick Posted February 23, 2013 Posted February 23, 2013 I reckon so. The ends must just be pushed in and bonded? So will ya just cut one off, clean up then re glue in???? Propeller shaft.... Hmmmmn Quote
mjrstar Posted February 23, 2013 Author Posted February 23, 2013 Hit it with the hacksaw and the end was not resined or glued at all. Just a real fine spline pressed in with a bead of sealant on the very end to stop moisture getting in... Its looking like win so far.. Quote
DB8-TypeR Posted February 24, 2013 Posted February 24, 2013 Regarding power steering pump, some model of Citreon has electric power steering pump, they are using one in a Honda Cup Race car build, can see it in this pic: http://iforce.co.nz/i/d4n1dlnc.m3a.jpg Quote
Truenotch Posted February 25, 2013 Posted February 25, 2013 Was this car manual? If so, do you still have the engine and box? We're on the lookout. 1 Quote
