Truenotch Posted July 26, 2012 Share Posted July 26, 2012 So close to hitting the wall! Was the sound more mellow than it used to be? It's hard to tell from videos. Gutted about the strut and tower! Quote Link to comment Share on other sites More sharing options...
Toucan Posted July 26, 2012 Share Posted July 26, 2012 Man I love this thing, the work you do to it is amazing, makes me wish I still had a starlet! Quote Link to comment Share on other sites More sharing options...
kpr Posted July 27, 2012 Share Posted July 27, 2012 muffler pretty much sounds the same as the old one. sounds a bit poo's exhaust wise tbh. need better reso/s up front. will rebuild the center part with better reso's sometime. make it from mild steel, rather than stainless Quote Link to comment Share on other sites More sharing options...
MACKAZ Posted July 27, 2012 Share Posted July 27, 2012 Pity you cant find a swaybar with a threaded end and use that to adjust your caster. Either that or move the swaybay front mounts back and machine existing bar? With your skills its possible.....dunno whether the spring steel would thread though? Or different swaybar and adjustable caster rods? Quote Link to comment Share on other sites More sharing options...
kpr Posted July 28, 2012 Share Posted July 28, 2012 ive got some plates on the chassis that move the sway bar mounts forward 20mm or so. and a little bit of adjustment on the mounts. still doesn't have that much caster though. camber plates are getting a bit sloppy. so got some more on the way, might mount new ones at 45 deg, to do caster as well. Quote Link to comment Share on other sites More sharing options...
ryanfels Posted July 28, 2012 Share Posted July 28, 2012 Do a ke70 front end swap Quote Link to comment Share on other sites More sharing options...
kpr Posted August 4, 2012 Share Posted August 4, 2012 ^ yeh nar, messes with geometry. I'd make custom lower arms and caster arm setup, retain current struts. if was going to go that far. found out cause of front end destruction. water made its way past the seals in top of struts. then down into the bottom of shock body. running bilstiens so are inverted type. so when hitting a decent bump, it was like the shocks were bottoming out, or hitting a steel on steel bumpstop. shit broke since water does not compress so well. i drilled a 2mm hole in bottom of shock case to stop it happening again. also welded up the strut tower and bunt off all the nice new paint! fake edit: left shock, white bit was full of water. Quote Link to comment Share on other sites More sharing options...
ProZac Posted August 23, 2012 Share Posted August 23, 2012 Uhhh, yeah, so I submitted your build thread to build-threads.com... Love your work man Quote Link to comment Share on other sites More sharing options...
zep Posted August 23, 2012 Share Posted August 23, 2012 Uhhh, yeah, so I submitted your build thread to build-threads.com...Love your work man I saw this! Awesome, you're more internet famous that before! Quote Link to comment Share on other sites More sharing options...
kpr Posted August 24, 2012 Share Posted August 24, 2012 cheers dudes. would be good to see a few more os projects up there! Quote Link to comment Share on other sites More sharing options...
kyteler Posted August 24, 2012 Share Posted August 24, 2012 Well deserved recognition of your awesomeness. Quote Link to comment Share on other sites More sharing options...
NaN Posted August 25, 2012 Share Posted August 25, 2012 Dude, your on the main page of Build threads.com http://www.build-threads.com/build-thre ... 0-starlet/ Quote Link to comment Share on other sites More sharing options...
kyteler Posted August 25, 2012 Share Posted August 25, 2012 Psst, Nigel. Look 4 posts above yours. Quote Link to comment Share on other sites More sharing options...
NaN Posted August 25, 2012 Share Posted August 25, 2012 Is there a hole I can crawl into nearby ? Quote Link to comment Share on other sites More sharing options...
Simon Posted August 25, 2012 Share Posted August 25, 2012 Haha ^ Quote Link to comment Share on other sites More sharing options...
sr20Escort Posted October 17, 2012 Share Posted October 17, 2012 Love your work man, intake and exhaust manifolds lookin great! Quote Link to comment Share on other sites More sharing options...
k2dori Posted December 24, 2012 Share Posted December 24, 2012 great stuff, great driving too! Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted December 24, 2012 Share Posted December 24, 2012 fuck yes- sweet skills there alright. it looks rad with the stretched wheelbase. I'm not a fan of super stumpy cars myself. applause etc Quote Link to comment Share on other sites More sharing options...
Stu Posted December 26, 2012 Share Posted December 26, 2012 Looks good on the pointy's! Got a full set? Quote Link to comment Share on other sites More sharing options...
kpr Posted December 26, 2012 Share Posted December 26, 2012 nar, only got the pair Quote Link to comment Share on other sites More sharing options...
