ratt
kpr's starlet
Hey dude, you got the plenum manifold and brakes etc off me. I have a spare set of covers in kamo if you wanna grab them, text my brother (di0n) 021 02702099
Jesse
Share this post
Link to post
Track time soon? Mines nearly ready to rock and roll, hopefully get it on the rollers next week. On the ground tomorrow.
We go sliding?
Share this post
Link to post
the engine bay is looking nice and tidy - much better than the busy mess under the bonnet of my kp.
good work
Share this post
Link to post
Dun dun duuuun. Looks mean.
I went to see Skews and Gills last night, they proceeded to spend the next hour and a half trying to convince me to turbo my car with the big cams in it....
NA skids?? Lend me some wheels?
Share this post
Link to post
hah, would be terrible with a turbo and those cams.
mjrstar: cheers, bit easyer when you dont have 6 cylinders and a turbo to stuff in there! will get some decent pics up once it together properly.
wound the ignition timing up to where it should be tonight. pretty happy how its going, thought it would be a bit of a sack. but goes way better than a standard smallport kp, i tuned awhile back. must have got something right this time..
Share this post
Link to post
Did you get the VVti up and running and working on this motor in the end? What you reckon about it, was it worht the effort?
Share this post
Link to post
not yet. once everything else is sorted, will get back to it. probably use an adjustable cam wheel to see what there is to gain/ find out where the vvt pulley needs to advance and retard to. advancing the inlet cam should gain midrange, make it idle shit & lose power in the last 1000rpm in top end. so vvt off till 2000rpm ish so idles good (not that i care) then back off at around 7000rpm to extend powerband.
Share this post
Link to post
aluminum. we'll see if it melts or not. have seen straight through mufflers made from ali. but not this design which will likely retain more heat.
Share this post
Link to post
