  • Replies 7.6k
Number plate is not a wof thing, only the light is.
Here is what NZTA say
“All plates must be fixed securely to the vehicle in an upright position. They must be displayed so that all the characters (numbers and letters) are clearly visible at all times.
A motorcycle, moped, tractor, trailer or trade plate must be fixed on the rear of the vehicle.“
https://www.nzta.govt.nz/vehicles/licensing-rego/number-plates/
Link to post
My Zephyr brake rotors have some fairly deep rust pitting. I have tried to find new rotors, without any luck.
I have spoken to someone who could machine some for me from billet steel. Would these be legal, for re-vin and WOFs?
Apart from accelerating wear to the discs, would there be any issues from remaining pitting if I got my existing rotors machined to at or near the minimum manufacturers tolerance?
Link to post
Custom made brake rotors are a no-no under WoF VIRMS.
Aftermarket brake rotors
  • the substitute rotors are:
– the same size as the OE rotors, and
– catalogued aftermarket items for that make and model of vehicle (and can include cross-drilled and/or slotted types), and
– attached to unmodified OE parts.
Link to post
Might have to spend some time with the Brembo (or similar) rotor catalog. If lucky, you might find some that just need the diameter machining down or similar. What sort of size are they? Do they share brakes with any other models that you know of?
Link to post
From my research, it seems capri rotors are similar. The height of the rotors is off by 2mm and the centre bore is a bit too small, but could probably be machined to fit. Unsure about the PCD, but the Zephyr discs are also 4 stud so could be redrilled if necessary.
I think I'll get the existing rotors skimmed and see how bad they are, should be good enough to get me through revin at least.
https://www.nzautomotive.co.nz/products/disc-rotors-ft-ford-capri-cortina-escort-mk1-245mm
Link to post
Can get the discs overseas by the looks, just not cheap. Only had a quick look, so quite possibly more options.
https://www.mevspares.co.uk/FRONT-BRAKE-DISCS-x2-Ford-Zephyr-Zodiac-and-Consul-Mk2-Mk3-Sep-1960-66.html
That said if you plan to repower it later, you may upgrade the brakes so a skim could last you till then.
Link to post
I'd be asking these guys, they are set up to do custom work as well.
http://www.znoelli.co.nz/
Link to post
What are the legalities with Air Assist suspension for leaf springs (replaces the bump stop with the airbag) on a WOF vehicle? is cert required?
Ford Transit Mk7 Campervan 2008 FWD 2.2L
And on the other end of the spectrum, any crowds is Auckland do replacement and uprated leaf springs?
Think they have relaxed after being constantly loaded
Link to post
Archers springs in takanini for leaf spring upgrades
Link to post
Just now, Esky_addict said:
Cert required for changing from auto to manual box, currently certed for auto? Not according to the the thresholds if using all OE
Yes will need cert for 2 potential reasons,
1. Car needs to match what the cert plate says
If it didn't have a cert already,
2. Threshold says it's ok to swap auto to manwell, if you use optional oe parts....the kicker is if you change to a manual brake pedal or modify the oe pedal, that needs cert
Link to post
There was a thing earlier in the year that they were going to modify the brake rules. Have you got any info on this?
Link to post
