Bling Posted May 28, 2020 Posted May 28, 2020 Can get the discs overseas by the looks, just not cheap. Only had a quick look, so quite possibly more options. https://www.mevspares.co.uk/FRONT-BRAKE-DISCS-x2-Ford-Zephyr-Zodiac-and-Consul-Mk2-Mk3-Sep-1960-66.html That said if you plan to repower it later, you may upgrade the brakes so a skim could last you till then. Quote
sr2 Posted May 29, 2020 Posted May 29, 2020 1 hour ago, Benno said: My Zephyr brake rotors have some fairly deep rust pitting. I have tried to find new rotors, without any luck. I have spoken to someone who could machine some for me from billet steel. Would these be legal, for re-vin and WOFs? Apart from accelerating wear to the discs, would there be any issues from remaining pitting if I got my existing rotors machined to at or near the minimum manufacturers tolerance? I'd be asking these guys, they are set up to do custom work as well. http://www.znoelli.co.nz/ 1 Quote
discostevew Posted May 29, 2020 Posted May 29, 2020 What are the legalities with Air Assist suspension for leaf springs (replaces the bump stop with the airbag) on a WOF vehicle? is cert required? Ford Transit Mk7 Campervan 2008 FWD 2.2L And on the other end of the spectrum, any crowds is Auckland do replacement and uprated leaf springs? Think they have relaxed after being constantly loaded Quote
AllTorque Posted May 29, 2020 Posted May 29, 2020 They need cert as the height can be adjusted. 1 Quote
Esky_addict Posted June 2, 2020 Posted June 2, 2020 Cert required for changing from auto to manual box, currently certed for auto? Not according to the the thresholds if using all OE Quote
cletus Posted June 2, 2020 Posted June 2, 2020 On 29/05/2020 at 13:18, discostevew said: What are the legalities with Air Assist suspension for leaf springs (replaces the bump stop with the airbag) on a WOF vehicle? is cert required? Ford Transit Mk7 Campervan 2008 FWD 2.2L And on the other end of the spectrum, any crowds is Auckland do replacement and uprated leaf springs? Think they have relaxed after being constantly loaded Archers springs in takanini for leaf spring upgrades 1 Quote
cletus Posted June 2, 2020 Posted June 2, 2020 Just now, Esky_addict said: Cert required for changing from auto to manual box, currently certed for auto? Not according to the the thresholds if using all OE Yes will need cert for 2 potential reasons, 1. Car needs to match what the cert plate says If it didn't have a cert already, 2. Threshold says it's ok to swap auto to manwell, if you use optional oe parts....the kicker is if you change to a manual brake pedal or modify the oe pedal, that needs cert Quote
Carsnz123 Posted June 2, 2020 Posted June 2, 2020 33 minutes ago, cletus said: 2. Threshold says it's ok to swap auto to manwell, if you use optional oe parts....the kicker is if you change to a manual brake pedal or modify the oe pedal, that needs cert There was a thing earlier in the year that they were going to modify the brake rules. Have you got any info on this? Quote
cletus Posted June 2, 2020 Posted June 2, 2020 The modification threshold got updated, new or different info is in yellow https://lvvta.org.nz/documents/suplementary_information/LVVTA_LVV_Cert_Threshold.pdf 1 Quote
Esky_addict Posted June 2, 2020 Posted June 2, 2020 So to the letter of the law it would require recert solely because the pedal box has been swapped. Even though the brake system hasn't been modified as the brake side of things is like for like, only difference is that one pedal box has a clutch pedal attached to oneside and one doesnt? Seems abit odd, what's the difference in replacing a master cylinder? 1 Quote
cletus Posted June 2, 2020 Posted June 2, 2020 Do you mean changing the master cylinder size? Or just replacing a worn one for a new one? I think the intention is to prevent people swapping parts that there may be differences between manual and auto spec which might be a safety issue that doesnt get picked up by a wof inspection Quote
Esky_addict Posted June 2, 2020 Posted June 2, 2020 Just can't see how one clutch pedal being installed automatically results in requiring a cert. If you swap pedal boxes and the brake side of things are identical then you aren't really modifying the brake system. Thus shouldn't require a cert for a gearbox swap. I mean I think you should need a cert for gbox swap but according to the threshold the only issue is that the braking system IS modified by fitting a pedal box with a clutch. Not having a go but its the whole interpretation thing Quote
Yowzer Posted June 2, 2020 Posted June 2, 2020 That is correct. If however your clutch pedal resides on it's own independent pedal box and you don't touch the brake pedal box, you are fine. So long as the clutch pedal doesn't hit the wider auto brake pedal. The issue is, people in the past have modified their factory brake pedals to fit around their newly installed clutch pedal, they did a shit job, their brake pedal broke and they no longer got stoppers. Hence blanket rule to make sure muppets haven't stuffed anything up. All it takes is one mounting point to be in a different location and someone going "meh, doesn't need it" and then eventually the frame fatigues and things go wrong. 1 Quote
Esky_addict Posted June 2, 2020 Posted June 2, 2020 Let's say I have a vehicle which was originally manual but has been engine swapped and auto is stated on cert plate, then it gets changed back to manual. I go for a WOF and the man says no deal as its not certed for the manual, however if the braking system is not modified it doesn't need a cert. Then i would have to get a cert for something that doesn't need certified lol Quote
AllTorque Posted June 2, 2020 Posted June 2, 2020 @Esky_addict Do you realise that @cletus answers all these questions for free to help out old schoolers? I’m sure he doesn’t need his time wasted with hypothetical questions. Also remember that he does not make the rules. 2 Quote
tortron Posted June 2, 2020 Posted June 2, 2020 It would already be Certed and not match the cert plate. Simple eh My clutch pedal is still there, it's just unpinned and ziptied up under the dash lol 1 Quote
Yowzer Posted June 2, 2020 Posted June 2, 2020 6 hours ago, Esky_addict said: Let's say I have a vehicle which was originally manual but has been engine swapped and auto is stated on cert plate, then it gets changed back to manual. I go for a WOF and the man says no deal as its not certed for the manual, however if the braking system is not modified it doesn't need a cert. Then i would have to get a cert for something that doesn't need certified lol Yes you would, because you are changing your car from its certified state. The same applies to anything else on the car. Once certified, you can't change back to factory wheels either. If you don't like the rules, don't modify your car. 1 1 Quote
Popular Post Shakotom Posted June 2, 2020 Popular Post Posted June 2, 2020 Have you seen the competency of some of the diddle fingered people that work on cars that think they know what they’re doing? Have you seen the pics that Cletus has posted in design disaster thread of cars that people have presented for certification? There are monkeys out there that can barely tie their shoes, let alone undo some bolts and reassemble something with the same number of bolts / pins that they removed. I’ve seen people put a headlight bulb in upside down. I feel like cert rules are easy enough to justify that something’s been done correctly / safely. Also Cert process Is easy and painless from my experience. Take car in, pay some money, fix what cert guy says, acquire plate. Some stuffs a bit of a PITA, but standardised and easy enough to see why there’s a blanket rule when you think about it. 9 2 Quote
Yowzer Posted June 2, 2020 Posted June 2, 2020 There's really no point in debating the rules as LVVTA can say "nah bowl" on whatever, regardless of your interpretation. It's not like they're gonna be like "oh gee you're right, if you read it that way then yes you can slide through, we'll allow it", they'll just amend the rules. Quote
Shakotom Posted June 2, 2020 Posted June 2, 2020 Also think about it, ol mate with diddles for fingers only puts half the amount of bolts in when putting a Gearbox in, -not ideal but probably not a big issue yet half the bolts on a brake pedal or being a potato and forgetting to install the Clevis pin correctly / heating / cutting brake pedal may result in brakes failing in an emergency stop and that’s sort of important. 1 Quote
