Showing content with the highest reputation on 23/12/19 in all areas
Got a little bit more adventurous yesterday and went for a longer drive out on the 80k zone so I could open her up a bit. Goes so much better, who would've thunk that efi and an 60mm Tb would make this sort of change. Finally found some info on this particular iteration of the f/ma, came out 82 the 1982 luce 2000 sg-s and not the cosmo like I previously thought, no wonder I couldn't find anything.. Was pretty healthy too really, considering they "upgraded" to the fe, 120hp/167nm vs the 12v fe 120/178. I was always of the opinion that it was a total boat anchor at only 90hp, I've done bit of work to them in the past and they've gone pretty good but efi is hands down the best modification, shits all over the 45dcoe I had on my 626.. Just don't remember it being this quick sans turbo.. Anyway like I said took for a spin, got it up to about 5500rpm a few times.. Once it hits about 4k you can really feel the vibration through the pedal compared to the carb, think it comes down to the way the linkage is orientated so at wot the cable is sitting at almost right angles to the linkage (kinda hard to explain without a pic) might need to adjust it round a bit. All went good till (luckily) I got home and it started running like a bag of dicks again, but this time an electrical miss, down a cylinder. Checked leads and they were definitely firing, pulled off an injector plug.. ahhh. 4 and 2 not pulsing so inj pinout #1 and sure enough when I wobbled the cable it came back. Ended up being some dry solder joints on the main plug, resoldered them and bob's. Also managed to get a viscous hub of an fe, was pretty loose so I topped it up with some silicon oil. They work a bit different from the Asian hubs on the toyotas as they unbolt and come apart in half whereas these don't come apart at all, instead the of a bimetallic coil they have a strip that when hot bows out releasing a little plunger type pin underneath which in turn somehow activates a valve inside. To top it up you have to get the oil through that little hole whilst letting air out (it was a cunt) works anyway and is much quieter than the fixed fan that was previously on there. Got a new oil pressure sender as well, the old one was leaking like a mofo.. No wonder the bottom half of the engine is covered in shit.. Ended up getting an aem wideband. Reviews said it was the best but more expensive than the innovate, trademe disagreed and someone had them for about 60 bucks less. I'll weld the bung on in the new year and get about tuning it a bit. Here's a great pic to prove I actually did something and didn't just want to talk shit, I forgot to take pics of everything else..13 points
Yay. So I started sanding and it became immediately apparent that there were a bunch of layers and lots of them are fucking nasty. There is a layer of black dulon in there which is fucking everything up. Nothing for it but to strip it all back to metal. Side sharn, I bought this car in 2006 but I'd seen the car in about 1999. At that stage it had a black engine bay and a 3T sitting in it. The rest was in primer. He must have primed over the black art some stage. So anywho, fast forward to today and most of the paint is gone. I'm feathering the edges where it's a real cunt to get to and hopefully the epotec will seal the nasties from coming through. Time will tell. On the plus side I'll probably get primer on it before crissy then it can sit for a while before I sand it. Give it some hope of settling down. Still got strut tops to do and the top of the firewall12 points
Couldn't stop there, went into overdrive and cleaned it with some simple green degreaser then a few go's with the wax and grease remover. Then finally got this in one colour, just used the rustoleum high temp paint from bunnings. It had a picture of a bbq on it so it must be legit. Looking pretty swish, almost like a brought one haha. I only had a few cans of paint and it didn't go very far so only got about 2.5 coats on it. It will be interesting to see if it lasts or not. All that remains is fitting the wood and making the grills. This will be tomorrow's job if all goes well. Chur10 points
Straight to the pool room! I had some scrap stainless steel that has been taking up room in my shed. The plan always way to make something furniture related, however I only had a limited amount of material to work with. After some careful thought, I realized that I could make a bench seat out of it, and not a scrap more... Cutting and tig welding it together along with some smacks from a big hammer...all this activity at 8am is sure to please your neighbors? *Insert bender joke* Folded and tig welded to keep it together. I had to do it this way due to the sizes of the scrap I had to work with. And finished. It's not perfect...but I had to work with the limited resources I had. Theres a few dia4mm holes in the left side that were in the material already, but hey you can hardly notice it and it was free...so calling it a win!8 points
Spoke to Evan Fray from Chevron Engineering today. he said they were only ever intended to run a lap belt from factory, and the laws support this configuration so ive got some lap belts to put in tonight. that should see it wofd. but we all know how dangerous that would be. even the wof guys agree the harness is much safer, so ill probably put the harness back in for actual driving, but fingers crossed itll be wofed tomorow.5 points
So, i did this again using the same coil overs and springs. 8kg springs 210mm long Front compressed 91mm adding both springs together. so 91mm x 8kg = 728kg Front Rear compressed 63mm adding both springs together. 63mm x 8kg = 504kg Rear 1232kg with almost empty fuel tank (60L), no idea how much fuel it had when weighed it last time, but guessing would have been empty because it always is. worst case its about 100kg lighter than the 1376kg it was, All the weight come off the front. Which is what ive slowly been chipping away at. 59% front 41% rear with empty fuel tank. still not great but better than 64/36 Should be able to pull another 10kg out of the front if swap out the brake calipers and intercooler. Anyone got some fc/fd rx7 calipers hanging about ?5 points
So got the last bits sorted today. Cut some steel and made some grilles. Had to stuff around with the firebox grille to get it functional as the setup was different to the cooking chamber. Also because the rails I fitted to the cooking chamber weren't square I had problems getting the lower one to look right. Everything is kind of shortly but it is functional and looks pretty awesome. I've actually finished this and got it all together but we shall wait til xmas to get some better photos. Hopefully my brother is as stoked as I am with it haha.4 points
On a mission today. Rifle scope mount welded to angle iron. This will hold a solenoid valve, that in turn is connected to a timer switch. This will automatically drain the water out of my compressor... Test fit Yup, nice! This will work, so paint it and install it tomorrow. Small things...but makes life easy if you never need to think about it again.4 points
4 points
And the creme de la creme. Had a mate at one stop cutting shop sus this out. Did an awesome job and it adds that finishing touch. So happy with how it's looking now. Had also welded up the remaining holes and bent the firebox lid so it sits a bit better and tried to sand back the paint on the inside of the firebox. All that's left now is to sort the front bench, drill some mounts for the thermometers/temp gauges and paint! Home stretch! Chur4 points
Less wood burning hotter gives much better smoke, but will require more frequent refuels. Try lump charcoal with just a couple of lumps of wood instead.3 points
I had a huge smoker fail yesterday, omg. Smoked ham that makes your tongue go numb3 points
started cleaning/stripping the engine bay ready for paint. also started tidying up the wiring so its not in the engine bay. got a good chunk of it done, just need to extend the wires for the passengers side headlights etc and its done. ill probably start sanding today 2019-12-22_10-19-17 by sheepers, on Flickr3 points
Well shit, I put the body bolts in and took it for a skid or two up the driveway, it feels good. Only into third cos the drive isn't that long, but it does good skids on the gravel lolol. Doest feel bouncy or wallowy, steering is good seating position is good. It feels pretty lively too. Everything seems to be working as expected, brakes and clutch need another bleed but still. Fucking stoked, might need a crywank now. Neighbor took a vid, I will post when I can get it.3 points
Now you may be wondering how I achieved this engineering marvel... Well there's an entire chapter on health and safety written on the use of ladders... I ignored all of it, getting this 80kg colossus glass backboard all the way up there by myself. Its wose than you'd think, the glass backboard is one part, the hoop is separate again, and all of it is held in place by 4 M10 bolts with next to no room to access them. #suffersfromashorthose3 points
Put the other distributor in, now has vac advance again. Runs a bit better, I'll see if its more ecom on pertol over the holidays I managed to pull the ends off 2x leads swapping them over which is a pain in the bum, a couple looked a bit manky in the ends so ive ordered a new set off my favorite supplier of parts. Who, it appears, sort out the GST issue at purchase so no problems there.2 points
Yeah, that's a thought. Will think on it/do something when I am working on it/finishing it all off next. I pulled the electric motor off in order carry out some isolation works but got waylaid. I want to isolate it (electrically) from the rest of the structure and welder. I am not sure why except to say its an AC unit and I don't want the welder to earth thru it or fuck it in any way ... and turn everything electrically hot (if that's possible) I am not a electrician so don't know the intricacies of it all but just going to isolate the fucking thing so its not an issue. I am going to earth directly to the rim I think. It only does one revolution so don't need a fancy swivel or anything. Will see. Cheers.2 points
Looking good.. May I suggest that you get a fire going in it as soon as possible. You are going to need to set the paint well, before its first use.. the smell from the high heat black is pretty horrendous. It will burn off tho, and then you will be all good, till next year, when you will need to paint it again. Also check on the can, but with the pot belly black that I used from bunnings, it said that you have to recoat within 16 hours, otherwise leave for 7 days then recoat. I didn't follow the instruction when I painted my spit, and it all bubbled off in the first burn.2 points
motors all back together and pretty much ready to go back in the car. got a couple of little things left to tidy up but nothing major. and with that i started stripping out the engine bay for repaint. 2019-12-20_04-33-06 by sheepers, on Flickr 2019-12-20_04-35-02 by sheepers, on Flickr2 points
So a quick bit of back ground (sorry this is the first place I've had to keep 2 build logs going and I'm a bit slow on the follow up lol) I've had the car since 2007? Give or take. She had 80 thousand and was in speccy beautiful condition. Plan was always for a simple clean blacktop 20v and daily. We then moved to tas and fast forward to 2014, not much had changed. She had wheels and suspension but that was it. I started to gather bits, 3sge and 6 speed, ecu etc for a conversion before my first boy was born..... Then in late 2014 I was admitted to hospital for a mystery condition. Turns out I had had a severe reaction to a common medication. This admission lasted 6 months and left me permantly disabled. Im pretty lucky with the depth of side effects considering what it put my body through. So the last 5 years have been predominantly rehab, learning to walk again, and gain basic functions back. Over the last 18 months, things have progressed well, and ive been abke to start playing again and have made some solid progress. I'm under the pump a bit to get my car running by the time Leo my son starts school full time in the new year. So hence the recent burst of enthusiasm lol. I'll try and keep things clear and logical but feel free to ask for clarity in the discussion thread...2 points
Some encouraging news, after my last outing I was too paranoid to drive it to the Christmas meet. Took it out this arvo for a spin round the block and it seems to be going good. Did have a massive flat spot of idle but I fiddled with some of the settings regarding low rev accel and injector wake and it looks to mostly have disappeared. Fuck does it go better than the carb, doesn't run out of puff at 4k like it did and actually pulled way harder than I was expecting, had to back off the gas as it just kept going.. Good Times. Just have to tidy up the plumbing for the fuel pump at the back and get myself an air filter (and a wideband) I also need to sort a fan but I think I'm just gonna get a viscous hub of an fe that way it'll flow more air and I won't have to worry about wiring up a fan and overloading my alternator, then she should be good to go.. Speaking of wide band, not really sure which one to get. Was looking at this one But I guess I should let the link do all the boat cut etc since all the functions are the and just use it solely for tuning in which case I should just get this one, Or go analogue and get this.. Maybe a little Xmas present to myself, then I can tune other things..2 points
Here's the baffle/tuning plate setup. Used 3mm plate with an overlapping step to try and keep everything sealed half decent. Might look at changing to 5mm plate later and possible more plates to help with different heats. It's all removable for easy cleaning. It's not the tidiest but it should be functional, keep in mind a lot of this has been rushed as I don't have much time left and I'm not a precision engineer haha. And my minion/fiance gave me a hand with the sanding and metal prep which helped a lot! Gotta love the Samoan safety boots.2 points
Been going hard at work leading up to xmas but also managed to squeeze in more time on this. Made a stopper for the Fire box door. Sits pretty nicely now. Also drilled some holes and mocked up the gauges. Wanted to put them higher but there would be clearance issues with the top rack. I also welded in a little rack thing for the firebox grill to sit on and cleaned up the damper but forgot to take a pic.1 point
Goes again, everything seems to work a lot better so far. Main power feed from battery and fuse box now in passenger foot well. pretty much the only place it would fit Made catch can that fits where fuse box used to be. some fresh spraycan paint even1 point
Unlikely, there's about 300m2 of concrete with a purpose built turning bay facing the other way to back into. However if one of my wives friends comes for a visit...who knows, I wouldn't rule it out. Some of the fucked up positions they wedge their vehicles into always has me scratching my head in bemusement!??1 point
You best be putting a steel chain net on that1 point
Cut their pocket money for a month as punishment (assuming they are lucky enough to get pocket money)1 point
My kids keep hanging onto my house garage door like monkeys and getting lifted up by it as it opens...little fuckers@!!! No matter how much I yell or threaten violence (that's half true) they wont stop, until I hear "dad...dad...dad...!!!" Yup - door finally shit itself. Quick YouTube tutorial and I'm suddenly an expert on all things doors... Springs pretension set. New track with a belt drive to replace the now fucked chain track system...and viola...all sorted.1 point
Sounds like a sweet project and i like the idea of divining for water, giz a yell if you need a surface dude to pull up the buckets of clay while you shovel them out1 point
i divined for the water, used a post hole borer with 1.5m homemade extensions till i hit the water, i will put a submersible sump pump with float switch on it when i hit the water, i will stop digging at about 4m then lower the concrete rings down and keep digging and stacking the rings, if the pump won't keep up then I'm deep enough. the rings will stop the hole collapsing and the rings have been cured for more than two months. thats the plan anyway1 point
Thats some sweet primitive engineers Max but 2 questions, how you know where the water table is and how you gunna sort out water ingress once you hit the water table and still have 3 meters to dig?1 point
Fark that's impressive! Just watch it dont cave in on ya!1 point
I was thinking of adding a pivoting arm that I could hang my water blaster off, kind of like those washworld places. But yeah, it will be used for the above for sure, as current I hang the odd deer in our house garage much to my kids delight and my wife's disgust.1 point
Had a full day off, which is rear lately. So not being one to waste a minute of the day... I'll give it a day or more to cure...then attached the backboard to the pole. Ridiculous over engineering at its best, but it looks semi authentic. Stickers and all from its stadium past, as a former lighting tower from a sports stadium now repurposed to continue bringing joy to people in it's new form.1 point
Started making a mailbox for my dad as a Christmas present today. Another couple of days to coat it with heaps of polyurethane and then a layer of paint inside and it should be good. Made from recycled rimu so it has a few imperfections, I added a load of apprentice marks to it and will leave them in so I have a story to tell1 point
If anyone is after a cost effective Dial Gauge, I picked one of these up today and its shockingly decent for the price. Has a certificate of NZ calibration, and has a decent heft to it, doesnt look or feel cheap. https://www.saecowilson.co.nz/#/Product/info/M339A Same with the magnetic base, better built than the price lets on https://www.saecowilson.co.nz/#/Product/info/M3291 point
Personally i wouldn't bother with the water/ meth. For the more shit to go wrong and blow up your engine reasons. Have played with injecting water alone and isn't much to be gained. Meth yes, but if system fails all bad. Run an intercooler even if its small. Pulling some heat out is better than nothing. Just make sure it flows enough for the engine. If flows across the width make sure has plenty of height and thickness, so isn't a restriction. Tune on pump gas for best boost/ timing compromise. If want to go fast at the drags of the likes throw in some race gas and wind up the boost. Still goin to take the hit on the iat's / lower air density. But higher octane will deal with knock. As im sure everyone already knows, its just a big ballancing act with compression, fuel quality, heat and how much air your trying to jam in there.1 point
