Showing content with the highest reputation on 03/19/17 in all areas
Booked this in for a WoF today. Didnt quite make it all the way. (run out of gas) Lucky i had someone who thought it was flippin hilarious driving the support vehicle Looks pretty cool even busted on the side of the road, but "get the fuel sender working" is now at the top of the list! Ive put about 30l of gas in it since i put the tank back in, and ive driven it maybe 3km, so not sure where it all went! Cruising in traffic. Goes pretty good, but i think i will get the radiator swapped out for a newer one that doesnt leak and maybe a couple of pusher fans. Dash guage reads near the top of normal when its sitting, but the mechanical one reads normal (~90degC), but thats in the lower hose. Up on the hoist. Nice to see the underside from more than a foot away! Guys were pretty happy with it. !!!WOF AQUIRED!!! After that popped around to Mr and Mrs Grants to show off, and went to Burger Fuel for lunch in it, gets lots of looks and thumbs up, and 'what is its?' Swung by the beach for a surf check on the way home No surf, so then made a start on the post-WoF list of things to sort! - Fuel sender - wheel alignment - radiator + fans - door & boot locks (no key for any of them) - more driving!15 points
10 points
I ended up with this air pump from the shed tour. It's a Siemens 3 phase industrial pump and it caught my eye for the purpose of an extraction fan for my bead blaster. Initially I had thoughts of swapping the motor for a single phase 230v or even a DC motor with a controller so I can adjust the speed, I need the flow rate high enough to keep the cabinet free of dust but not too high so it starts sucking out all the media. Was just about to dismantle it for a clean up when wiped the dust off the top cap which showed the connection options and this is when it got a little more interesting, this motor can be wired in 3 Phase Star or 3 Phase Delta. (Obligatory warning, Dont ever try this unless you are qualified to do this as there's a chance of electrocution, explosion, fire, pestilence, flood and other nastiness) As you can see, in delta the windings are configured in a 240v config, but however if you did hook up a 230v source to say L1 and L2 the motor wont start, it'll just sit there and him and get hot! as there's no air moving to cool it down, you can get the motor running by spinning the shaft and eventually it will start but at a lesser power output and of course wont restart. Remembering a bit of my NZCE done years ago I know that adding a capacitor can have the effect of a phase shift or delay which is similar to adding another phase, there's a few calculations you need to do which I wont go into here in the interest of safety as things can go horribly wrong if you mess it up End result is a very use able 3 phase air pump on single phase, I have a Variac that can make this variable speed, win!8 points
Bit more progress, I was trying to get this done so I could take it to the grasskhana that the Nelson car club ran today, but didn't quite make it, part of the reason is this When I was getting the front panel lined up ready for welding a crack opened up about 50mm from the join, so while I was cleaning up the welds I had made I did a little bit of investigating and found this. Left side Right side So it appears that I was not the first person to chop off the front sheet metal, I was however the first person to weld it up properly.... apparently a few spot welds and heaps of bog was the order of the day for that particular repair, in fairness they had used heaps of underseal behind it which kept the rust away so it was just a matter of cutting the welds re-aligning it all and welding it back together. Next up fitting the fan to the radiator, I got a bit lazy and just used those push through tie things And engine back in, oil cooler and radiator fitted, fan re-wired with a digital controller as the analogue one was a bit huckory So all that work was basically just for this Before After I have some bits turning up for the exhaust tomorrow so have decided to build the new one rather than fit the old one back on7 points
well, the innaugral AGM for newly founded www.midschool.co.ng went fantastically. great turnout of enthusiasts with a passion for economic mid 80's japanese compact vehicles, and then some wankers with actual old cars turned up. first agenda item: banish all european vehicles and send them back to their country of origin via telegram second motion to be tabled: rummage some mega GC barry's shed full of awesome cars and bikes, and haggle some sheepskin seat covers. featuring glorious 2 tangs and 2m's once Mabel had listened to her favourite meatloaf tapes, it was off to the stoat and gristle with barbara for a drink. then, haunted speights were consumed in a haunted pub, and some delightful sharns were induced by locals who had never seen such an awful display of cars. after enjoying a bacardi breezer, ol man ky started breakdancing for the local patrons shit chat aside, what an awesome day. massive thanks to everyone who came, hope you all enjoyed it. see you for the next one!4 points
Shit that was a good day even with wagon playing up, after the bonnet poping open for about the 5th time we stopped in alex on the way home and stropped it shut. Thanks @gettinroundtuit For the strop. The wagon started missing and struggling slowly getting worse till we found the battery cable had come off easy fix with the help of @kyteler's trusty pocket knife. I brought my mate along and he said it was one of the best cruises hes been on. Just shows how many GC's are in OS.4 points
and as a bonus when you burn out a phase you have 2 more spare4 points
4 points
safety cletus says new seat belts are much better. In the front it had a diagonal belt, plus a lap belt so you had to put both on which was te dumb. It had no belts in the back, so I put the laps in the back, someone had cut off all the original old belts and left them bolted in for some reason. Put new lap and diagonal belts in the front, they have old style chrome leg burner buckles which look better than new plastic ones4 points
Unfortunately due to me being too lazy to change lenses, the tree and the stupid Toyota van being in the way, this was the only OK Vulcan shot I got.3 points
Fuck yeah, thanks to all the good cunts and good vibes of the people who showed up at various stages. Good times again. Got back into town about 9pm which makes for 12hrs of OS real life times. Good times.3 points
Bit more progress this week. Starting with getting the old trans tunnel brace drilled out (it must have had a different gearbox in it at some stage and someone had mangled the old one), then the new one welded in and sealed (Cheers Joe). Also Por15'd the cross-member and sway-bar so it's ready for the motor to go back in now. Pile of goodies also turned up from the UK. Cheers Matt3 points
super fucking great news man!!! well done, just in time to buy that AC 124 too.3 points
Top link mounts made and tacked in place. Next on the list is a brace/mount off the link mount, back to the chassis rail. will bolt it through the chassis with a few decent bolts. maybe something similar on the other side also, as the factory x member bolt locations are kinda limited, since the lower links take up the space needed to build something solid off them3 points
Further to this yarn. At this juncture, we encountered some drunken Alexandra locals, a pair of which seemed genuinely offended by my moustache, much to my entertainment, though I'm not sure a mulletted, leather vest wearing air compressor rider with a mulletted wife has much ground for such statements. Still, as I said, entertaining.2 points
By contrast I had a trouble free trip back. Found someone to race from ranfurly to Palmerston. Now I need to sort going back to retrieve mine and @Nick Ritchie's new projects. Cheers for an epic day guys!2 points
I don't think there would be many, I've seen 2 other Plymouth valiants here but they were 4 doors. When my mate bought it, it had been on trademe for quite a while so I thought there must have been something wrong with it, but I think it was because they were the sort of car your nana would drive in america so never had a following like a barracuda or duster etc If it was a red mustang with cragars it would have sold quick2 points
I had planned on being on the road by 7am yeah it's early, but that should leave time cruise along at 80kmh /to stop and pine over junk on the way down, stop and buy food/refreshments for nats/ pitch tent in day light ect/ I just wanna get to nats also for route would it pay to see if any other people further down country wanna jump on the convoy and route route around that?? my 2c2 points
Here's another rushed and average pic of my new carpet. its much darker than it looked in the auction pictures, I like it.. so I think I'll rock it as is, reminds me of my old valiant.2 points
Quickly took the car down for an alignment this arvo to try and work out the pulling to the left situation. Well have a look at the "before" spec below.. haha! As they didn't have a listing for hako on the system I figured Kenmeri woud probably be closest. One of the front caster arms is bent which is causing some of that issue and the toe adjust arms are a bit shit but managed to get them back in line. There is a lot of rust underneath so I'll be loading up on repair panels in this next container! Went to stop in at the compliance place on the way back but it was closed Also I think I need a GT-Kai badge.. everyone thinks it's a GT-R and are crushingly disappointed when I tell them otherwise haha Oh, so result of alignment car definitely feels like it drives a bit straighter, still pulls to the side occasionally but I think that may be as a result of my spring situation. I received a few more bits for it from Kevin san (the aussie guy previously mentioned) so one day I'll get to putting those in and see if that makes the difference.2 points
Brown car left on a trailer headed to dunedin on saturday, so spent the rest of the weekend cleaning out the garage and went and got the white one back from storage, so i could start getting this one ready for Nats. Had the radiator fixed, it had a couple of small leaks, I think the 16 pound cap probably didn't help, put a 7pound one on instead. Have ordered some new seatbelts from www.classicseatbelts.co.nz so just waiting for those to arrive. gave the brakes a once over, greased and checked the front end, and for now have borrowed the wheels off the vg, I didnt trust the tyres on a long trip. Also I thought it would be rude to not remove some of the height out of the front while it was jacked up, so I did.2 points
I picked up this a bout a month ago from Penrose (not Wanganui!) Ended up getting it sent from Ralph Moore Autoglass in Sydney who had one in stock, and they shipped it with an MG one for some other bloke to halve our shipping. This week i finally got it installed. Cracking the parts cats screen has not only been a very expensive fuckup but also meant ive pretty much missed cruising this summer. I reused the old rubbers, i cleaned them pretty good but they are a bit cracked and stretched in the corners so i hope they dont leak Sorting out the best surrounds, and had just enough unbroken clips, less 2 And on Pretty happy about the close fit to the opening given all the work i did around the screen top and bottom (not so much about the runs, but thats what accessories to hide them are for!) And paint run hider back on Too much or? Nothing like a pending >1200km road trip to procrastinate on sorting the list of wee jobs to sort and a few miles to put on, before hopefully a WoF Next weekend! If not then id better get the brakes on the 125 sorted! Here is a pic to remind me why I aught to pull finger:2 points
Right, so this happened then this Even managed to get it insured...... So yeah all done, well not really still needs an interior and some paint touchups but that can wait, its now time to put some kms on it, this has been a pretty long project so now all I am going to do is enjoy driving it. Pretty funny car to drive gets a fair few looks some good some not so good and mostly surprised, gas mileage is so bad, like next level bad, I took it out today and my average was about 4.4kms per liter but it is running really rich (yeah that'll be it, not the rotary under the bonnet ha ha), anyway combine that with the 30l Anglia tank and I am going to be spending some time at the gas station for sure! The biggest problem that I will have now is keeping it under 5000RPM (so hard to do when all it wants to do is rev....) for the next 1000kms which is what the engine builder recommended, work is about a 30km round trip so I only have to do that 34 times and at current gas milage it will only cost me about $500 ha ha ha Anyway it's all good And I will leave this as the last shot, and in my opinion the best angle of the car2 points
http://members.rennlist.com/tom86951/Speedometer Calibrator Page1.html Arduino based1 point
Sounds similar to mine then. Yeah seat time is good and you can only get better Just need a turbo now!1 point
Every man and his alsatian decided to rent a nissan tiida and drive like a toucher today. But we are enroute!1 point
Cheers guys, was a bloody awesome feeling driving this round on Thursday, and it's a great feeling to have something I've built get legal1 point
I had a look at the online destructions for that jaycar unit and I wonder if its unhappy as the gearbag sensor (I think is) 12v instead of 5 I probably have the schematic for the kitset one in a book somewhere if you wanted to try it that way - can just barry it onto strip board and try it out? Just had a look and it needs the micro etc etc so too hard. There isnt a option for a different speedo gear is there? I seem to recall there being a few options for a aussie barge of some description a while ago1 point
also have playlist sorted for my factory tape deck. Pining!!!1 point
Today's effort. New (half finished) gearbox/transfer case cross member. Lower links don't agree with the old one. new one will have a tower for the upper link with some adjustment holes. +50mm shocks look pretty short.1 point
Gone all Roman dave science with the link setup. plugged the numbers into a calculator Tricky to get all the numbers in the acceptable range while working around the chassis, engine and wheels that need to turn. main compromise is chassis mounts on the lower links will hang below the chassis rails a bit. but still will be a touch above the transfer case x member, so shouldn't be too much drama. had to do this to get enough up travel without the links hitting the chassis rails, and also to get the roll steer numbers down. The rear is pretty text book since there wasn't really anything to work around after cutting and modifying the chassis. Done it without using a calculator, just following a guide some geezer wrote. putting the numbers in the calc, looks like got lucky and nailed it. can dial the anti squat up to 100% with the adjustment holes. but this is how it's setup currently got some springs for the coil overs 175lb top 300lb bottom. both 14'" long. shocks should be at 50% travel with the weight of the truck on them.1 point
Depends what you want to model...definitely don't need a scanner. Fusion 360 is free for most...probably where I'd start. If you've never done any computer modelling at all TinkerCAD is a nice simple toy.1 point
well, after a successful brew i was in no fit state to go for a ride on any bike, order of the day was a drunken lunch time nap, last batch of hops added to the mash ton. doesnt look very appetising i admit but sunday was a good day, first i took pinky (b120) for a ride to find it was running out of gas at full throttle, so pulled the carb and adjusted the float, another spin and she was bang on, even managed to get to 55mph on the flat hehe next on the cards was wee red (bridgestone) had to replace a buggered exhaust gasket, then decided id take her for a spin with out the seat, ran like a champ!! managed 80mph on the clocks and pulled pretty well getting there, big red (vtr) got a start up a wee run, as well, just because it'd been such a fruitful day blacky (bandit) didnt get any love pics for thread1 point
So this happened, nothing too major, and the smaller parts of the list should be done by the end of the week, leaving only sorting the rear airbags fouling on the diff/ brake line, and reworking the front shock mounts should sort 3 of the issues on the list, Guess there is a few more late nights and weekends in the garage,1 point
Not a lot going on at the moment, have bought some bits like the MB cylinder, looking at a set of new shocks and may have a donor car shortly1 point
Small update. Have been getting all the bits and pieces ready for the cars return (which has been delayed, but more on that later) just got all the airbag brackets back from powdercoating, All my parts turned up from rockauto so should be able to minimise the leaks, get a decent supply of fuel, and get rid of the minor driveline shudder, New Grants steering wheel has turned up, just waiting for the bosskit to turn up. So exciting to have all the parts turn up. It's like Christmas all the time haha Like I said unfortunately we have run into problems at the metal workers, Clint has been out and feels that the rear floorpans are too thin and as such he won't cert the seatbelt mounts. Fair call obviously, so new floorpans are on their way to Custom metalshapers and all going to plan they will be able to start on them next week and have the car back to me by the end of next week. Then I'll paint the inside of the floor with POR15, etch prime and underseal the underneath. Then it's onto the airbags!!! Got to add one more picture and while it's not related I'm sure most of you will recognise Shakotom...... That's right it took 4 of them to get one silicone hose off of a piece of alloy pipe,1 point
So have done a bit of work on this old girl. Have replaced all the rear suspension bushes, the rear shocks and am just working on the rear brakes replacing the wheel cylinders and fitting a brake shoe self adjusting kit, no pictures of that as its boring stuff. Don't worry though I do have some pictures. Shakotom kindly loaned me a couple of Hundy spokes so I could gauge what size I wanted as you can get them in real OG 13x7 which will be too small in my opinion. You can also get them in 14's but they are only 6" wide so I'm thinking they maybe too skinny. Or they do them in a 15x8, which is what these are. The 15's seem to be the logical choice, they still have that huge guard/small rim look, but I cam still run a reasonable width tyre, but I think the 14's may look better/more traditional, Oh and here's a rough paintshop job that I did to give me inspiration Chur1 point
Got to work on doing the springs and shocks today, went with cut standards all round, cut one side of the cobra rears and the coil diameter was quite a bit thicker than standard coil. turns out by the time id cut to fit the short shocks it was so rigid because of such little weight in these cars that it hardly compressed more than 10-15mm when it was on the ground haha. so cut the standard rears to the same height and it slammed it down nicely. got a bit over-excited with the fronts and ended up cutting too much off... took it for a whip round the block and aside from the horrid sounds of mudguards scraping the ground the entire time, it was actually mighty comfortable, new shocks working a treat! thankfully i still have the cobra fronts to play around with to get the ride height mint.1 point
So the last few days have been spent sorting out the brakes, funnily enough with the master cylinders switched over it now stops like a champ so pretty happy about that. Drove the neighbors crazy running the car up and down the street slamming on the brakes but it had to be done. I also got the new shorter springs and threw them in and there is no heaps of clearance on the tyre so that will be all good now. So it is already for it's retest now. I had some time today so I sorted out something that has been bugging me for a while, there is a small cover at the top of the bonnet that I took off a while back to get some paint colour matched and then I left it out as the engine generates a bit more heat than the old crossflow and I thought it would be a good idea to let it escape, anyway it is a reasonable sized hole and it looked a bit messy with nothing on it so I did this. First holesaw some holes Then swage them with the tool I made a while back And fit to car and here is the car now that I have raised the back up by 25mm I can now get out of the drive without scraping but it still looks good I reckon. Fingers crossed that the next post will be to say that I have cert1 point
Well it's been a busy couple of days, had cert booked for Thursday and before that I took the 1" blocks out of the back to raise it up a little, it doesn't look as good but now I can actually get it out of the drive without scraping the crap out of the exhaust. So Thursday morning I drove it out to get a warrant then the garage let me borrow a hoist for the inspection. That all went pretty good, there were a couple of things but nothing major, then we went to do the road test and the car wouldn't start, stupid thing!! anyway I think what happened is the fuel pressure was too high and was overflowing the float bowl and flooding the carb, anyway I eventually got it going but only on one rotor and just couldn't get it to clear. So the certifier left to have a look at another car and I went off and got some new plugs chucked them in and wound back the fuel pressure and it was good to go. Here's the car on the hoist (kind of boring pic but I haven't posted any for a while) Then it was off for the bump steer test which it passed and I went home to fix some of the small issues that had come up on the inspection. The certifier came back at about 10pm so we could do the road test which unfortunately didn't go so well, the car goes good, handles good but wasn't so flash on the stopping so it failed the brake test. There was no fade or anything it just wouldn't pull up properly anyway I was a bit surprised by this as I had researched it pretty thoroughly but what can you do, so we headed for home and on the way back started talking about master cylinders and sizing etc. Then this morning I had a thought and went to check the cylinders and found that I had the front and rear cylinders swapped, so I had a bigger cylinder on the front which meant it was much harder to push the pedal and explains why it wasn't stopping as it should. So yeah my bad, what a dumbass. Still it's good to know what the problem is, I have swapped them over now so hopefully they will be sorted. There are a couple of other things as well, the coilover platforms sit quite close to the tyre so I will put some shorter springs in and wind the platforms up to get some more clearance, and I need to get some documentation for the driveshaft mods. So assuming that the brakes will now be ok it is pretty much sorted, unfortunately the certifier only comes to Nelson once every 4-6 weeks so I have a bit of a wait but hey it's taken years to get to this point so another month won't hurt, it's not exactly a practical winter car anyway..... There are a couple of other things that I will do while I wait like replace the 3.9 diff with a 4.1 and look at adding some interior (specifically some sound deadening, I reckon it's louder in the car then out.....) So yeah I guess that's a win1 point
Ok lets see if this works http://vid225.photobucket.com/albums/dd95/105re/TRIM_20160530_061135_zpsn99jdybk.mp41 point
