Those cracks are in a place that you could repair them, as they are seem to be with in the frost plug holes and and that fitting, a block seal would take care of them or you could weld them with a nickel rod, they cant really spread
  • Replies 135
Yeah I understand that.  But I would just prefer to start with a none cracked block
Back in the 80s dad worked at a place that owned a fleet of 6cyl holden utes. (Dad reckons they were unreliable trash,) one of them had a 202 black motor that threw a rod/punched a hole in the block.
They found some clever welding outfit who glued the block back together. (I would presume the bore would have needed a sleeve)
I brazed a hole up from a rod once, it has broken a bit off the bottom where the cylinder hung down into the crank cake but its still running
On 12/10/2024 at 20:35, d.p.n.s said:
That looks bloody cool...
I do need some spot lights
I’ve got a good pair of chrome Lucas spotties you can have for postage, they’re the type that mount off a bumper. If you’re interested I can get a pic.
I've got a set thanks mate.
It's done now, but how fast did you run the drill when honing the block?
Everyone seems to go too fast, which results in a too horizontal  hone pattern. (Verses the 60° hone pattern which is ideal) If you watch a video of a Sunnen honing machine in action, the rotational speed compared to the up and down motion is a lot slower than the your average drill at full jandal.
A pneumatic drill with the reg turned right down is a great way to sustain a lower honing speed
I don't go fast at all mate and slow up and done...
Think this is actually the 15th block I've done at home so far
Been honing your skills eh?
  • Haha 5
Battery drill works nice and slow for me. Old lower voltage one has a lower base speed than the late 18V jobbies.
Yeah it is an old as fuck drill I use just for that.
31 minutes ago, JustHarry said:
Yeah it's a tacho drive.
Not all of them have it.
Worth keeping there for one day
Definitely...I wouldn't mind a tacho
