Roman's 4GR V6 Carina discussion thread
Roman
  • Replies 660
1 hour ago, xsspeed said:
would be interesting to see if you could, I'm guessing either the cranks are mounted higher in a 4gr or the piston compression height is significantly different between the two (or both) to account for such stroke difference. solution is only a custom set of rods away if need be
probably just the usual shorter block height on the 4gr,   usually a toyota / most manufacturers move. save some material cost and make engine bit shorter.    so yeah  longer rods  would be needed.  probably giving a rod ratio well over 2.    bigger bore, bigger valves bit more capacity.  probably blow the budget, but would be pretty cool if the crank did swap over
1 hour ago, Roman said:
Ideal starting point is the 5GR motor.
Its 2500cc with 2GR sized bore and a crazy tiny stroke. But this motor was only available in China for whatever reason.
$5200 inc DHL shipping from AliExpress haha
  • Thanks 2
  • Haha 1
There are some other interesting short stroke contenders, will add in the Alfa 155 DTM motor for interests sake.
These are all 2500cc V6
Looks like 2MZFE is the closest in spec to the alfa motor interestingly enough.
MZ series motors suck though.
Bore size:
4GR:        83mm
VQ25HR: 85mm
2MZFE:    87.5mm
Alfa:         88mm
Stroke length:
4GR:         77mm
VQ25HR:  73.3mm
2MZFE:    69.2mm
Alfa:         68.3mm
Bore size:
4GR:        83mm
VQ25HR: 85mm
2MZFE:    87.5mm
Alfa:         88mm
Stroke length:
4GR:         77mm
VQ25HR:  73.3mm
2MZFE:    69.2mm
Alfa:         68.3mm
Wash your mouth out. VZ motors suck, MZ are at least alloy
Low compression.
No aftermarket parts.
Stupid scissor cam gear thing.
Dunga power as standard.
No vvti on the 2500cc
Cheap though. Likely all have a zillion km on them though.
If cams and valvesprings were available id consider it.
Would bolt to j160 is a feather in its cap.
Yeah theres a bunch of mark x at pickapart.
Id not be surprised if all of the motors are fucked and thats why they are there. My motor had not that many kms and its so absolutely full of caked up shit.
Id not be surprised if all these cars start going extinct around 200,000km.
Direct injection without port injection makes for a short lifespan.
I wonder if some periodic water injection would help?
My research into squishbands is that the sharp edge promotes a turbulent mix when it gets squished
My GN head had less detonation when I rounded them. But it had other things going on with the piston shape. Nothing negative happened, there was also less carbon in thrle head compared to stock sharp band
Interesting. Im guessing a lot of these things are necessary for stratified charge, but less relevant when youve got high up port injectors.
Will eventually buy another motor or 2 to try some other stuff too.
Not sure. I guess running a catch can would help, its probably a lot to do with oily buildup from that.
But the valves were almost road cone shaped with shit piled on top.
