Tiger Tamer Posted May 30, 2023 Posted May 30, 2023 Is it possible to remove the studs and just use bolts. Quote
Roman Posted May 30, 2023 Author Posted May 30, 2023 Yeah, I'd rather not though - I always hate threading into aluminium, so anything that gets done up / undone a lot, I usually wind studs in. On my previous motor I ended up stripping a few threads, on the intake and exhaust bolts. Then its a nightmare. I could probably cut them shorter though, they're quite long. Quote
tortron Posted May 30, 2023 Posted May 30, 2023 Cut a sloot in the flange holes? For slidability Quote
Tiger Tamer Posted May 30, 2023 Posted May 30, 2023 The Honda engine uses two studs and the rest are bolts. I know what you mean about bolting to aluminium as it feels very easy to cross thread it. Maybe a combination may help. Quote
GARDRB Posted May 30, 2023 Posted May 30, 2023 I'm contemplating doing bolts in 1uz land @Roman, not for all of them, but for enough to make it less of a ballache to get headers in and out Quote
CUL8R Posted May 31, 2023 Posted May 31, 2023 Why not run a die nut up the long ones, and roll pin - I assume you'll balance the flywheel and pressure plate anyway? Quote
HumberSS Posted May 31, 2023 Posted May 31, 2023 1 hour ago, CUL8R said: Why not run a die nut up the long ones, and roll pin - I assume you'll balance the flywheel and pressure plate anyway? They are a roll formed/forged thread rather than cut. Cut threads aren't as strong. I think you'd be fine finding yourself a nice high tensile bolt of suitable spec. Quote
BlownCorona Posted May 31, 2023 Posted May 31, 2023 if you get very stuck, i may be able to help with destructive testing one of the flywheel bolts to find out what its characteristics are. we certainly have all the gear to do this at work, but i would need to ask one of the guys who has the skills to help with the testing (and what exactly to test) but its all proper calibrated test equipment so might help in the unlikley outcome you cant verify what they are made of an easier way. Quote
mjrstar Posted June 1, 2023 Posted June 1, 2023 What diameter is the relief in the crank, can you start them flush by drilling and tapping to m12? Quote
Roman Posted June 1, 2023 Author Posted June 1, 2023 I'd rather not have to redrill the crank, because part of my development budget is blowing up an engine or three along the way... So ideally keep the motor stuff as standard as possible. Thinking about it some more, I'm thinking maybe I just need to give up on using the 3S flywheel. Adapting a spigot bearing into an aftermarket FWD V6 flywheel is looking like an easier options than all of the modifications requried to make this flywheel work. Also because the aftermarket flywheels are a lot flatter (as not trying to emulate the dual mass setup) they should end up a bit lighter too. Quote
mjrstar Posted June 1, 2023 Posted June 1, 2023 Does that then mean there is no faff about with starter engagement? Because non OEM starter placement can be a bit of a pain in the arse to get right as far as teeth engagement and throw out etc.. and if you can eliminate that hurdle it'd be worthwhile. Quote
Roman Posted June 1, 2023 Author Posted June 1, 2023 Yeah non standard starter isnt an option. As this starter motor is quite short. I tried 1NZ and 3S starters, but neither would fit because they hit the engine mount. I found a GR motor starter at pickapart. You're right, I guess that's another tick in the box for a different flywheel. So will add that to the list of things to buy after my house sells. If I get to the point where I can get the motor started up, I guess I can always just put the auto flex plate thing on it for the meantime. Whether or not I've solved gearbox issues. Quote
GARDRB Posted June 1, 2023 Posted June 1, 2023 2 hours ago, Roman said: If I get to the point where I can get the motor started up, I guess I can always just put the auto flex plate thing on it for the meantime. Whether or not I've solved gearbox issues. Auto flex plate and a sexy little Tilton multiplate clutch Quote
HumberSS Posted June 1, 2023 Posted June 1, 2023 Can the stock v6 flywheel be strategically machined to mount the clutch and still work with stock bolts? I'm guessing not. Quote
yoeddynz Posted June 1, 2023 Posted June 1, 2023 2 hours ago, Roman said: So I will add a machine shop to the list of things to buy after my house sells. Good boy. Quote
Roman Posted June 1, 2023 Author Posted June 1, 2023 9 minutes ago, HumberSS said: Can the stock v6 flywheel be strategically machined to mount the clutch and still work with stock bolts? I'm guessing not. Sadly I dont have a V6 flywheel, this was an auto engine. 6 flywheels / manual setups are exceedingly rare, to the point that aftermarket options are the only realistic option. But that's fine, because the OEM flywheel must be crap. cant imagine how awful it must be with a 40mm thick flywheel and how heavy it must be! I guess I've been trying to penny pinch a bit, but this is just an area that needs some $$ spent. But then it's also worth having a light setup to get that really snappy rev when the clutch is in. Quote
HumberSS Posted June 1, 2023 Posted June 1, 2023 Internets tells me 1mz is the one from manual Camry is that right? Quote
Roman Posted June 1, 2023 Author Posted June 1, 2023 Correct, but they also seem to be hens teeth in manual. If I could find a factory 1MZ flywheel, would be a good place to start. Maybe I'll have an ask around for one of those. Quote
HumberSS Posted June 1, 2023 Posted June 1, 2023 Potential vein to explore... https://www.trademe.co.nz/a/motors/car-parts-accessories/toyota/exterior/listing/4157424404 Deep interwebs tells me V6 surf will work with some machining... https://www.woodsport.org/forum/showthread.php?1402-V6-flywheel-info Quote
Roman Posted June 1, 2023 Author Posted June 1, 2023 Oh wow, thanks! Hadnt considered that anything like that would have a suitable flywheel. I bet it weighs about 85 million kg though haha. However, even so you've lead me down a rabbit hole that might be the right length bolts. Thanks for the help! I'll order some of these and see how they go. Quote
