mjrstar Posted May 12, 2020 Posted May 12, 2020 26 minutes ago, sheepers said: ah righto, ill have a look. cheers 1 Quote
Spencer Posted May 14, 2020 Posted May 14, 2020 Yup I used the KBS dark grey header paint. Stayed good for the 5 years I had the car. Quote
sheepers Posted May 14, 2020 Posted May 14, 2020 thanks for the tip. ive already painted the new zorst with the pot belly paint so lets see how that goes. Quote
Truenotch Posted May 21, 2020 Posted May 21, 2020 What brand of pot belly paint did you use? I painted my motorbike exhaust with a hot black paint from Mitre10. I think it might have been Plastikote brand? It cured nice and flat and stuck really well. I cured it for half an hour or so with a heat gun and it seemed to work well. I feel like it was this stuff: https://www.mitre10.co.nz/shop/plastikote-hot-paint-spray-paint-400ml-black/p/359061 Quote
Greenie Posted May 23, 2020 Posted May 23, 2020 https://www.facebook.com/groups/215650068521846/permalink/3013367258750099/ Quote
sheepers Posted May 23, 2020 Posted May 23, 2020 On 21/05/2020 at 14:04, Truenotch said: What brand of pot belly paint did you use? I painted my motorbike exhaust with a hot black paint from Mitre10. I think it might have been Plastikote brand? It cured nice and flat and stuck really well. I cured it for half an hour or so with a heat gun and it seemed to work well. I feel like it was this stuff: https://www.mitre10.co.nz/shop/plastikote-hot-paint-spray-paint-400ml-black/p/359061 It was white knight pot belly stove black. Down at the collector it didn't burn off, just up the top where it gets hot Quote
AllTorque Posted May 23, 2020 Posted May 23, 2020 I’m glad you painted the oil cap and air filter bracket black. Red was so wrong. 1 Quote
anglia4 Posted December 6, 2020 Posted December 6, 2020 How do you do this without getting paint on everything in/on/around your shed? 2 1 1 Quote
tortron Posted December 7, 2020 Posted December 7, 2020 3 hours ago, anglia4 said: How do you do this without getting paint on everything in/on/around your shed? wait till he sprays the red 1 Quote
sheepers Posted December 7, 2020 Posted December 7, 2020 12 hours ago, anglia4 said: How do you do this without getting paint on everything in/on/around your shed? I don't. I used to try and make "booth" with sheets but it makes no difference. The overspray gets everywhere. But, this primer dust doesn't stick and eventually it gets cleaned off everything. I don't spray much clear really. That shit sticks to everything but I don't seem to have to much of a problem with that. So, in summary, Shit goes everywhere. 7 2 Quote
yetchh Posted December 20, 2020 Posted December 20, 2020 Totally looks like you've just built a plastic model.. 1 1 Quote
myk00l Posted December 29, 2020 Posted December 29, 2020 Tried these guys? http://www.nags.net.nz/ Quote
Roman Posted December 29, 2020 Posted December 29, 2020 AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH That fucken sucks man. 1 Quote
rusty360 Posted January 7, 2021 Posted January 7, 2021 Looking good man! How do ya find the brunnox works? Seems to hold out the rust ok? Quote
sheepers Posted January 7, 2021 Posted January 7, 2021 Yea, works OK. I haven't re visited any over any long term to really know but the old Barry rust repair jokers i know swear by it. 1 1 Quote
rusty360 Posted January 8, 2021 Posted January 8, 2021 Forgot to ask but does epoxy go over it ok? Quote
piazzanoob Posted February 1, 2021 Posted February 1, 2021 I know you said this on your latest post but is it okay to wet sand expoxy primer? i would've thought that it isn't sealed and ends up wrecking the primer also what grade sand paper do you start and finish with? progress is looking good Quote
sheepers Posted February 1, 2021 Posted February 1, 2021 10 hours ago, piazzanoob said: I know you said this on your latest post but is it okay to wet sand expoxy primer? i would've thought that it isn't sealed and ends up wrecking the primer also what grade sand paper do you start and finish with? progress is looking good yea so epoxy primer is totally sealed and its no drama to wet sand it. they used to wet sand single pack primers back in the day and it was considered normal practice. as far as sand paper goes it very much depends on what your starting with and what your end goal is but for me, 80 grit to remove all the old paint then first coat of sealer/primer. 120 grit on the long board to shape first coat and also to sand any bog you need then another coat of primer. 220 grit on the long board to finish shape and make sure you've got everything straight. at this stage you can spot putty any little blemishes or pin holes, then final coat of primer. wet sand with 600, again with the long board. you have to use masking tape to join the sheets of wet and dry so they are long enough to fit on the long board - dont use 3M masking tape because it cant handle the water but most other masking tapes will last long enough to get the life out of the wet and dry. for some people 3 coats of primer would be to many but i have found using this process makes the wet sanding way easier as you're not trying to sand and bumps or dents out, you're only flatting the layer of primer and that makes a big difference to how long it takes and it stops you from rubbing through and having to go back and spot prime. 3 4 Quote
