cletus Posted October 20, 2018 Posted October 20, 2018 Well that's dumb. Is the piston ok? Fix valve and try again? At least it looks like your gasket goo made the head gasket stick good Quote
kiwi808 Posted October 20, 2018 Posted October 20, 2018 If only there was a motor choice that didn’t have valves. Or Pistons.... 3 Quote
kyteler Posted October 20, 2018 Posted October 20, 2018 31 minutes ago, kiwi808 said: If only there was a motor choice that didn’t have valves. Or Pistons.... Good point. ...he should do a Tesla conversion. 1 2 Quote
sheepers Posted October 20, 2018 Posted October 20, 2018 12 hours ago, cletus said: Well that's dumb. Is the piston ok? Fix valve and try again? At least it looks like your gasket goo made the head gasket stick good the piston is ok which is a bonus. i should get the head and a new gasket back on Tuesday. ill spray it with hope in a can (70$ for a tiny can of it, there isn't enough left in the can to do anther head gasket) and chuck it back together. Quote
sheepers Posted October 20, 2018 Posted October 20, 2018 11 hours ago, kiwi808 said: If only there was a motor choice that didn’t have valves. Or Pistons.... talk about going from bad to much, much, much, much worse........................ 2 Quote
Dell'orto Posted October 20, 2018 Posted October 20, 2018 What do you mean? EV is the way of the future Quote
oldrx7 Posted October 27, 2018 Posted October 27, 2018 On 21/10/2018 at 08:56, sheepers said: talk about going from bad to much, much, much, much worse........................ haven’t had to change the head on any of my rx motors once 3 1 Quote
KP_wag Posted November 1, 2018 Posted November 1, 2018 Glamour shots on trademe look so lush, are you happy or sad? Quote
sheepers Posted November 1, 2018 Posted November 1, 2018 wrong thread but im super happy to see the back of it. Quote
peteretep Posted December 11, 2018 Posted December 11, 2018 How do you get on with painting small stuff like your air filter housing? You eyecrometer the amount of paint you need then there is a bit of wastage on the paint? Then aim down so you dont need to mask off the entire area? Looks lush Quote
sheepers Posted December 11, 2018 Posted December 11, 2018 yea pretty much. colour you can put back in the tin what you dont use and once you've sprayed the colour you have a rough idea how much clear you'll need. im just using cheap clear for engine bits and that so its no drama if a tiny bit goes in the bin. i would say i mixed about 20mils to much clear so i got it fairly close. probably only had one instance that i can think of where i wasted a bunch of clear. 1 Quote
peteretep Posted December 11, 2018 Posted December 11, 2018 Ah its only single pack paint, and not thinned, so you can put it back? Quote
Mr Vapour Posted December 11, 2018 Posted December 11, 2018 Glad you are happy with it. always nice to do work for a GC. Quote
sheepers Posted December 11, 2018 Posted December 11, 2018 8 hours ago, peteretep said: Ah its only single pack paint, and not thinned, so you can put it back? The colour is thinned 1 to 1 but you can put a little bit back in the tin that's been thinned, it won't affect it. 1 Quote
sheepers Posted December 11, 2018 Posted December 11, 2018 7 hours ago, Mr Vapour said: Glad you are happy with it. always nice to do work for a GC. Yea man, thanks again!!! Quote
oldrx7 Posted January 8, 2019 Posted January 8, 2019 annoying news (back stuff) but 100% better to rest and hopefully sort that out before you cause permanent damage at least you've got other sweet wips you can take along to leadfoot 1 Quote
sheepers Posted January 9, 2019 Posted January 9, 2019 yea its not the end of the world. my legs pretty sore and its all a bit shit really but ill just have to do what im told until i recover fully then i can get back to building cars. 1 Quote
kyteler Posted January 9, 2019 Posted January 9, 2019 Live comfortably in the knowledge that even crippled and unable to work on cars you will still finish your projects before me. 2 Quote
yetchh Posted March 10, 2019 Posted March 10, 2019 Guts on your back bro, sucks when your body says no.. Is that the yellow boot cut? Quote
