piazzanoob Posted September 25, 2024 Posted September 25, 2024 With the oil pressure thing. my guess is not with the Ryco z9 filter used them plenty as common yankie v8 filter and definitely haven’t had that when priming oil pressure before starting. As was done before a start on a fresh motor. not something like running the pickup too high or not enough oil to maintain that pressure? could also be something like pump spring has lost its tension as guessing not a new one? im also not sure if I would want to run a new motor knowing that could be a issue even worse if it gets lower after longer periods of engine running Quote
RXFORD Posted October 4, 2024 Posted October 4, 2024 I feel like this needs an added element of danger to it, so gantry injection would be quite fitting. Quote
Snoozin Posted October 4, 2024 Posted October 4, 2024 Any moment with an M series is arguably fraught with danger.... danger to headgaskets. 3 1 Quote
Popular Post cletus Posted October 4, 2024 Popular Post Posted October 4, 2024 Just some ideas for you because I like to help 5 1 4 1 Quote
Yowzer Posted October 5, 2024 Posted October 5, 2024 On 24/09/2024 at 10:09, sheepers said: yea so HKS made an engine, or maybe dress up parts for an engine and they called it the 5M-GX. they were doing similar parts for the 4age (which was called a 5A-GX) at the time and the 4age stuff was fairly popular. the 5m stuff, not so much. they made a turbo kit for a 5M which there is a tiny bit more info about, but there is nothing i could find on the interwebs about the 5M-GX except a couple of photos. i have no idea what they did as far as engine improvements or anything, i just found a picture on the internet and decided to copy it. cool story bro. what's left is make some sort of ITB setup for this thing and a set of extractors. the extractors will be fairly easy but the ITBs could turn in to a bit of a nightmare. there is very little room around number 6 and the firewall has a hump in it that means i cant come out of number 6 in a straight line. time will tell. IIRC they had some stroker kits to whip them out to 2.9 or 3.1L depending on pistons, which you've done anyway with the 7M cranky. 1 Quote
