h4nd
  • Replies 1.3k
This is not something I have built, more like something saved.
Came across an old car dealer lightbox that had been painted over many years ago
It was in pieces so I paint stripped the aluminum frame, everything was covered in a thick coat or two of cream coloured house paint.
Inside of the lightbox looked good
Noticed when cleaning up after paint stripping that the ancient can of thinners I had softened the paint quite noticeably, not knowing how to remove the old house paint without damaging the plastic sign I decided to test a small piece, to my surprise it softened the paint nicely allowing me to gently scrap the paint off20230218_152334.thumb.jpg.59b4833d80e60f9f2dfc1cc71c3ae93f.jpg
After quite a few hours over a few weekends it was time to reassemble
On 01/03/2023 at 21:55, waspman said:
This is a really old sign! Clearlite was waaaaaay back in the day before they became Supalite.
Throw some edge light LED's around the outside and it should light up mint
Hit me up if you need anything as my business wholesale manufactures signs.
1 hour ago, Tele29 said:
That is awesome, tele style but with the arm contour like a strat? Does it have the belly contour as well? What neck will you use?
Thats it, it has the belly contour as well, should be comfy. It is 1.5mm thinner than a standard strat though, due to some dumbshittery on my part. Shouldn't be a problem though.
I have been looking at making a neck on the router as well, however it is a step up in complication in some ways. Although that body needed 15 different operations to get to that stage not including facing off the wood.
But a neck needs a truss rod and frets etc, plus probably some specialised tools. I will probably give it a go though.
If it goes pear-shaped you can always order one from Warmoth or somewhere, complete with truss rod and frets. 1.5mm thickness will make no difference, I wouldn't be surprised if the factory fender ones vary by even more than that over the years. I really miss my tele, had a nice MIJ 72 custom reissue in black on black with a maple fretboard, was a lovely guitar. Sold it to pay rent when my daughter was little, single income life :(
  • Sad 1
That would definitely be a regret. I do have a superstrat type thing that I made a long time ago out of a Rimu mantelpiece that has a neck I got from guitarparts.co.nz. That theoretically should fit, but it works pretty well as a guitar so I dont really want to pull it apart for no reason.
I am thinking about making a resonator so might end up ordering a bucketload of stuff from Stewmac, we will see what the total looks like before adding necks to the basket.
