Roman
  • Replies 6.1k
What are tow bars made from?  i thought it was mild steel but it was hard work cutting it and drilling it, can only go 2 mm deep before it turns hard like tool steel.   Chipped a piece off, it appears soft on the outside but the core is all crystallized.   Wouldn't have thought it would work harden but maybe it has?
Whenever you're around, have a look at it for me.  It's the bar, was drilled for the ball to go through, but it's nearly tool steel in hardness below 1.5 mm.  Drill bits turn to smoke.
You can try using my drill press or the oxyacetlene
perhaps it's behaving harder now you've given it some localised heating rubbin' it up with a dull drill? ie try a fresh drill and make it cut straight away
I've tried that.  I've tried the drill press at work, i've tried concrete drills, i tried test holes elsewhere, it's odd.
Diff oil.
I have an H190 for my 620 in a very hard to find ratio.
I just had to fuck around with it extensively as per my thrust block thread.
I want this diff to both live a long and happy life, and to operate quietly.
Should I
A) run some cheap shitty old EP90 like the book sez,
B) Slam a litre of Mooreys/Lucas in it's hole, (It's capacity is 1lt too btw)
C) Brave the barbed wire in my pockets and splash out for some redline heavy shockproof gear oil? (I think that shit is synthetic)
I'm not going to be going through four sets of rear tyres every weekend. But I am going to drop a few skids when the need arises.
Which oil has the strongest magic?
Discuss!
I'm looking for a generic aluminium radiator - about 500mm wide and 400 high. Had a poke around Trademe and staparts but didn't seen anything that suitable. Bonus points if it has 39mm outlets.
Anyone have a link to a good generic catalog?
Diff oil.
Should I
Discuss!
moryes in a diff or gearbox dilutes the ep additives and it will blow up or shorten it's life.
