SOHC Posted August 30, 2016 Share Posted August 30, 2016 I had them round the other way and they didn't work as well as they should. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted August 30, 2016 Share Posted August 30, 2016 The smaller contact area generally creates a bit more grab and pressure then transfers to the rear larger shoe. If that makes sense. Science. 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted August 30, 2016 Share Posted August 30, 2016 It dose, the side with the shoe that didn't make contact in the middle worked better then the side that did. Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 1, 2016 Share Posted September 1, 2016 I am replacing some Jag inboard disks and re setting the camber, what a cunt of a job, I got one caliper off and the nuts for the half shaft, I wish I owned a trolley jack. Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted September 1, 2016 Share Posted September 1, 2016 I am replacing some Jag inboard disks and re setting the camber, what a cunt of a job, I got one clapper off and the nuts for the half shaft, I wish I owned a trolley jack. You can have one of mine. You'll need to put seals in it /lingpost 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 1, 2016 Share Posted September 1, 2016 You can have one of mine. You'll need to put seals in it /lingpost  Cool thank you, I have never owned one, even scissor jacks are thin on the ground at my place 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted September 1, 2016 Share Posted September 1, 2016 All I can say is fuck that 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 1, 2016 Share Posted September 1, 2016 All I can say is fuck that  I all ways use stands, those jacks tip over way too easy. Quote Link to comment Share on other sites More sharing options...
japawagons Posted September 1, 2016 Share Posted September 1, 2016 Still, Fuck that.You must spend hours just doing simple shit, messing around with scissor jacks. 1 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted September 2, 2016 Share Posted September 2, 2016 If you welded a socket to a scissor jack, you could use a rattle gun to make it go up and down more faster. 3 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted September 2, 2016 Share Posted September 2, 2016 If you have a compressor and a rattle gun, you probably should have a proper Jack too. 5 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted September 2, 2016 Share Posted September 2, 2016 Touche` 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 2, 2016 Share Posted September 2, 2016 My workshop had a dirt floor until last year Quote Link to comment Share on other sites More sharing options...
SiRge Posted September 2, 2016 Share Posted September 2, 2016 If you welded a socket to a scissor jack, you could use a rattle gun to make it go up and down more faster. Have done this, real good to put under subframes etc or between arms to separate joints (y) Quote Link to comment Share on other sites More sharing options...
Roman Posted September 2, 2016 Author Share Posted September 2, 2016 You can also weld them to your car, for a poor mans air jacks 3 Quote Link to comment Share on other sites More sharing options...
sentra Posted September 4, 2016 Share Posted September 4, 2016 its been degloved? looks sore any ideas or just a manufacturing defect? ethanol turbo motor Quote Link to comment Share on other sites More sharing options...
sentra Posted September 4, 2016 Share Posted September 4, 2016 edit double post Quote Link to comment Share on other sites More sharing options...
UTERUS Posted September 4, 2016 Share Posted September 4, 2016 So is the top picture an OK plug and the bottom is the bad one? Quote Link to comment Share on other sites More sharing options...
UTERUS Posted September 4, 2016 Share Posted September 4, 2016 Meow Quote Link to comment Share on other sites More sharing options...
sentra Posted September 4, 2016 Share Posted September 4, 2016 oh yeah, it is the same plug with its foreskin pulled back and forward, the others are all ok Quote Link to comment Share on other sites More sharing options...
