1 minute ago, ajg193 said:
They have RUC though, which are a minimum of $6.20 per 100 km. You'd need to be using like 3.5 L/100 km or less to come out ahead
the speedos in older cars can be pretty worn out and not keep up with the actual wheel speed....
  • Haha 1
  • Replies 6.8k
However my issue with lpg is having to know pretty much where ever gas station with lpg is in the country.
I know its a shitty pic, but would anyone have a clue what the bellhousing on my spare LT77 gearbox is? Looks to have an adaptor plate and no obvious markings. The biggest give away for me would be the hole in the top, and the two studs which i presume are for the slave cylinder. Its not RV8 or 2600/2300. My google-foo isnt working on this one.
Yes that's what I was thinking maybe earlier 12a/ 10a ???
clutch fork and starter hole looks similar to mine but I'm not an expert just thought bolt location and clutch slave location looked rotary
ding ding ding, early rotary of some sort. This is an RX-5/121 gearbox
file.php?id=38861
Now, what sort of saddo whacks a Vitesse V8 LT77 box behind a rotary?!
Maybe some saddo slotted a rotary into a Vitesse at some point, creating the British equivalent of the Roadpacer in the process.
Behold the Roadleisurelystroller!
Or if it has an adapter in front of that maybe the Rotang part was just the right length and easy to adapt between the 2 and has starter and clutch mount made easy ???
Paging @RUNAMUCK supercharger barry
Pickapart has a kompressor merc in the yard at the moment. 5 seconds of google says its an eaton m45. Your thoughts on such a device of crank driven forced induction please?
2.3? If so I'm pretty sure it's a M62, about 1000cc/rev. But then maybe not. I have a m45 off a mini that I was tempted to put on something silly.
They have some coating on the rotors which don't like drawthrough carby setups, but they are lots more efficient than the Toyota two lobe jobbers. I think ya can spin them up to about 14k if ya want to.
C230 sedan. Yeah I was thinking they would be more efficient than an SC14 so can make boosts with less heat/more boosts.
Getting it off the Merc looks real fun
The Eaton chargers have helical.rotors so they don't pulse as much. It was my understanding that the size is their displacement in cubic inches.  They're more efficient too or something.
I've got an Eaton m62  which was factory fitted to a 3.3ltr.
If it's a m45, drive it at 2:1. Your motors swept volume per Rev is 1000. Spinning 2:1 (assuming 45 cubic inches swept volume on the pump) you'd see 1500cc per Rev.  So you'd be jamming half as much air again in as the motor can breathe at atmospheric pressure.  Which shouldn't be crazy psi. Other factors include how efficient  (or how worn the coating on the blower rotors are/ it might not achieve its original rated displacement) and the VE of your engine. That is the intake tract restriction. Say  2zz when it's tec'n (or whatever Toyota call it)  will allow the incoming air into the cylinders much free-er than some other asthmatic engine with tiny ports/little valves/restrictive intake design. Same goes for the camshaft profile. A bigger cam (monster cams for everyone!)  Also helps allow more of that charge get into the cylinder too. It's not just jamming more air into a smaller space, but it's getting it into that space too.
Due to the zero lag with a blower monster port size/very free breathing heads aren't so shot as on an NA motor. Because instead of relying on the motors suck to draw in the charge (14.7psi at.sea level)  the blower is forcing it in. So the low port velocity often yielded by high rpm compatible/big cam engines is quickly.overcome.
Soz if.I'm. Repeating myself.
What flavor of 2ltr you gonna make.awesome?
