Seedy Al Posted June 13, 2018 Share Posted June 13, 2018 Alrighty then. Pretty sure I know the answer here, but the wipers on my 84 hilux do not self park anymore. I would assume the problem is going to be in the motor and not the switch? Cheers ladys Quote Link to comment Share on other sites More sharing options...
Transom Posted June 13, 2018 Share Posted June 13, 2018 Contacts in the motor gearbox that make it run til it hits park position when the switch is off - think brass tracks with bent or sprung loaded bits contacting you knew it Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted June 13, 2018 Share Posted June 13, 2018 Cool thanks. Its been a while and was thinking maybe technology had changed from the old bmc shit I was always repairing lol. Will add it to the list of things to do 1 Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted June 16, 2018 Share Posted June 16, 2018 Hello gents. I scored a mechpro jump pack. But it has no charger. It looks like I need a 15v 800ma charger. I don't have anything close. What do you think about just hooking my battery charger up to the clamps on the jump pack? My chargers a peak charger so no chance of over charging. What say you savage Quote Link to comment Share on other sites More sharing options...
Transom Posted June 16, 2018 Share Posted June 16, 2018 2 hours ago, Mr Vapour said: Hello gents. I scored a mechpro jump pack. But it has no charger. It looks like I need a 15v 800ma charger. I don't have anything close. What do you think about just hooking my battery charger up to the clamps on the jump pack? My chargers a peak charger so no chance of over charging. What say you savage Dump shops usually have a massive selection of 240- whatever voltage /ma adaptors Quote Link to comment Share on other sites More sharing options...
ajg193 Posted June 16, 2018 Share Posted June 16, 2018 Any normal car battery charger would put out 15 volt Quote Link to comment Share on other sites More sharing options...
smokin'joe Posted June 16, 2018 Share Posted June 16, 2018 35 minutes ago, ajg193 said: Any normal car battery charger would put out 15 volt ^^ the charger for my jump pack is 18v, even though it says 12v on the label Quote Link to comment Share on other sites More sharing options...
HighLUX Posted June 16, 2018 Share Posted June 16, 2018 4 hours ago, Mr Vapour said: Hello gents. I scored a mechpro jump pack. But it has no charger. It looks like I need a 15v 800ma charger. I don't have anything close. What do you think about just hooking my battery charger up to the clamps on the jump pack? My chargers a peak charger so no chance of over charging. What say you savage Kmart selectable voltage charger might do the job. Depends what the charging plug type is Quote Link to comment Share on other sites More sharing options...
Yowzer Posted June 16, 2018 Share Posted June 16, 2018 2 hours ago, ajg193 said: Any normal car battery charger would put out 15 volt And blow a SLA to bits Quote Link to comment Share on other sites More sharing options...
bigfoot Posted June 16, 2018 Share Posted June 16, 2018 5 hours ago, Mr Vapour said: Hello gents. I scored a mechpro jump pack. But it has no charger. It looks like I need a 15v 800ma charger. I don't have anything close. What do you think about just hooking my battery charger up to the clamps on the jump pack? My chargers a peak charger so no chance of over charging. What say you savage We just used to use the battery charger to charge the jump pack Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted June 16, 2018 Share Posted June 16, 2018 10 minutes ago, bigfoot said: We just used to use the battery charger to charge the jump pack So connected to the clamps? Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted June 16, 2018 Share Posted June 16, 2018 1 minute ago, Mr Vapour said: So connected to the clamps? Or through the charge plug. Did you have to have the master switch on so it would charge Quote Link to comment Share on other sites More sharing options...
bigfoot Posted June 16, 2018 Share Posted June 16, 2018 1 hour ago, Mr Vapour said: Or through the charge plug. Did you have to have the master switch on so it would charge Through the clamps. Switch on Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted June 16, 2018 Share Posted June 16, 2018 9 hours ago, bigfoot said: Through the clamps. Switch on Thank you Will do that today as the low charge beep is annoying me Quote Link to comment Share on other sites More sharing options...
SOHC Posted June 16, 2018 Share Posted June 16, 2018 I need a rocker cover gasket and sparkplug tube seals for a 2005 Nissan presage, that would seam like a simple thing to find but fuck me Quote Link to comment Share on other sites More sharing options...
bigfoot Posted June 17, 2018 Share Posted June 17, 2018 3 hours ago, SOHC said: I need a rocker cover gasket and sparkplug tube seals for a 2005 Nissan presage, that would seam like a simple thing to find but fuck me Replace entire rocker cover. Spark plug seals on some the nissan ones are not removable 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted June 17, 2018 Share Posted June 17, 2018 25 minutes ago, bigfoot said: Replace entire rocker cover. Spark plug seals on some the nissan ones are not removable I would like to replace that brittle heap of shit but carnt find one Quote Link to comment Share on other sites More sharing options...
ajg193 Posted June 20, 2018 Share Posted June 20, 2018 Woo the LPG Corolla now has a working fuel gauge. I jerry rigged an arduino nano with a linear hall effect sensor (sensing the magnetic float gauge on the tank) and a mosfet to drive the gauge. It's mega whorey though as all my electrical tools are up in Auckland and I'm taking power from the rear defogger to power the nano. And all of the wires are just out of a stripped extension lead so have mains AC colouring. I gave it a rough calibration by just moving the sensor around to get approximate levels (2/3 full tank), then went and filled the car up and the gauge dropped straight to empty - the analogWrite value went over 255 and looped back to zero. A quick fix in the code to limit the output to 255 and it was away laughing. Now to drive the car until the tank is almost empty and confirm the calibration at the lower end / I'm not sure if the gauge response is even linear. Definition of jerry-rigged : organized or constructed in a crude or improvised manner a jerry-rigged plan a jerry-rigged heating system [\spoiler] 4 Quote Link to comment Share on other sites More sharing options...
tortron Posted June 20, 2018 Share Posted June 20, 2018 Maybe I should do similar with my guage Hmmmmmmmmmm Quote Link to comment Share on other sites More sharing options...
ajg193 Posted June 20, 2018 Share Posted June 20, 2018 Total cost would be about $20. The hall effect sensor I used was the most expensive bit: https://www.jaycar.co.nz/ugn3503ua-hall-effect-sensor/p/ZD1902 Quote Link to comment Share on other sites More sharing options...
