Hemi Posted May 12, 2012 Author Share Posted May 12, 2012 cheers for all the copmments guys , keeps me motivated! . Today i had work in the morning so after that i decided to have a go at making the flange for the turbo , lucky for me there was some substantial steel in the scrap heap that i could use , so i cut it out drilled , grinded to shape then used a hoesaw to make the hole in the middle . its a bit rough and two of the hole have been made for 'bonus tolorence' heres some pics : i then welded it to the reducer and then TADA!! the turbo mounted ! neat aye! bet you can guess what comes next eh? .... yes thats right a video with the turbo running! im soo stoked i got this far i was oiling the turbo manually for the time being but im going to make a pump because the sound of it is incredible and im pretty sure a squirt of oil every now and then is just not going to cut it. here is a vid were i was preoccupied checking leak and did not notice the flame coming out the turbine it lost alot of heat between me turning it downa and getting the camera it was literally a bright orange . another video this one is more for lols. when the fuel pressure is reduced too low you get a sort of surging chuffing out the intake . this turned into an outright backfire while i had the camera running . just watch till it goes black nothing interesting happens after i dont think . IvjDxcbpU40 K-ABDnIj4KQ muqsQzPhWpo and just another fun one with no turbo and just cranking up the fuel just to give you a better idea of noise , look etc 3mlVKq17K_k so yeah thats where im at . gonna make a oil pump setup for it next as i reckon that more important as i will stuff the thing real quick if i dont . i also need a turbo with much more flow and this one spool up WAY too quick and im worried ill wreck it . Quote Link to comment Share on other sites More sharing options...
felixx Posted May 12, 2012 Share Posted May 12, 2012 OK so it is boss as but pardon my ignorance, What purpose does the turbo have? Will it replace the vacuum cleaner in time? Quote Link to comment Share on other sites More sharing options...
Ned Posted May 12, 2012 Share Posted May 12, 2012 You'll start it with a leaf blower which will spin the turbo. Spinning the turbo will put fresh air in the combustion chamber with lpg. This will burn and the exhaust gasses will go through the exhaust housing causing it to suck even mire air in, more burning, more exhaust gas, more turbo speed and even more fresh air in. It's a never ending loop that provides max awesome Quote Link to comment Share on other sites More sharing options...
felixx Posted May 12, 2012 Share Posted May 12, 2012 I suspected it was something like that. Will be an awesome heater, will the gases coming thru the turbo provide enuf thrust to propel something. I have a diesel patio heater that works a bit like a pulse jet. I will fire it up and take pictures one day Quote Link to comment Share on other sites More sharing options...
Ned Posted May 12, 2012 Share Posted May 12, 2012 It should do. Google turbo jet on Google. There's a few sweet things about. Its nice how it has a continuous flame in the chamber unlike a pulse jet. You hoping to actually use it to propel some thing hemi? Thrust or shaft driven? Quote Link to comment Share on other sites More sharing options...
Yowzer Posted May 12, 2012 Share Posted May 12, 2012 Turboshaft drome bike? Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted May 12, 2012 Share Posted May 12, 2012 Hemi, you're a fucking madman! Keep up the good work. Quote Link to comment Share on other sites More sharing options...
Hemi Posted May 12, 2012 Author Share Posted May 12, 2012 yea the turbo will provide more then enough airflow to run by itself , i was just being impatient haha . the turbo on this will provide no where near enough thrust to move anything just makes heaps of noise and heat turboshaft would be sweet but i dont have a lathe to spin up sweet bearings and fans etc Quote Link to comment Share on other sites More sharing options...
Ned Posted May 13, 2012 Share Posted May 13, 2012 Please find a lathe and then instead of making a drome bike with it, turn it into a lathe! Imagine a turbo jet lathe! Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted May 13, 2012 Share Posted May 13, 2012 Please find a lathe and then instead of making a drome bike with it, turn it into a lathe! Imagine a turbo jet lathe! at 80,000 rpm too Quote Link to comment Share on other sites More sharing options...
sheepers Posted May 13, 2012 Share Posted May 13, 2012 i don't want to sound like a dick but i reckon that turbo is already fucked. without constant oil pressure shorely it would have fucked both the shaft bearings and the thrust bearing? anywhwo, apart from that i heartily endorse this product. Quote Link to comment Share on other sites More sharing options...
DodgySam Posted May 13, 2012 Share Posted May 13, 2012 Hemi...get a HUGE truck turbo for max awesomness! Quote Link to comment Share on other sites More sharing options...
Hemi Posted May 14, 2012 Author Share Posted May 14, 2012 i don't want to sound like a dick but i reckon that turbo is already fucked.without constant oil pressure shorely it would have fucked both the shaft bearings and the thrust bearing? anywhwo, apart from that i heartily endorse this product. Yeah I def wouldnt endorse such things! Its still sweet as a nut atm no thrust an minimal radial.play. Currently dreaming up what to use for an oil pump. Oh man totally wish I had a much larger turbo but they dont seem to come up unless they are fucked haha God this is painful on a ph Quote Link to comment Share on other sites More sharing options...
cubastreet Posted May 15, 2012 Share Posted May 15, 2012 That is awesome. Sit the gas bottle in a tub of water, fill with beers, then you have a combination workshop heater, beer chiller and sweet noise machine. Quote Link to comment Share on other sites More sharing options...
SOHC Posted May 16, 2012 Share Posted May 16, 2012 I always wanted to build a setup like this, I started in 2005 but had most of the half finished parts and the turbo stolen when my car was parked on the side of the road over night. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted May 16, 2012 Share Posted May 16, 2012 Quite keen to build just a flame tube as a waste oil heater for the garage... How cheap was it to build the flame tube again? Quote Link to comment Share on other sites More sharing options...
felixx Posted May 16, 2012 Share Posted May 16, 2012 trunotch I run a frostpot I liberated from a vineyard, runs sweet on oil and / or diesel this time of year they begin to put them out Quote Link to comment Share on other sites More sharing options...
danger Posted May 16, 2012 Share Posted May 16, 2012 You still have eyebrows, You're doing it wrong. Quote Link to comment Share on other sites More sharing options...
Hemi Posted May 18, 2012 Author Share Posted May 18, 2012 Quite keen to build just a flame tube as a waste oil heater for the garage... How cheap was it to build the flame tube again? Quote Link to comment Share on other sites More sharing options...
Hemi Posted May 18, 2012 Author Share Posted May 18, 2012 The flametube didnt cost bugger all $40 for the endplate nada for tube or injector $40 for the regulator . It chews gas, like no tomorrow though Quote Link to comment Share on other sites More sharing options...
