sentra Posted May 18, 2012 Posted May 18, 2012 bleed some pressure off the output into an oil drum to feed the churbro, then dump the oil drain output back into the inlet? Quote
KKtrips Posted May 18, 2012 Posted May 18, 2012 Oil coming from a pressurized vessel and returning to a pressurized vessel = static oil?? Quote
Raizer Posted May 18, 2012 Posted May 18, 2012 I read a blog where a guy in the states made one of these, I'm pretty sure he used a car power steering pump for the oil on his, with some form of pressure reg and a trans cooler with a couple of small fans to cool the oil. Quote
Steelies Posted May 18, 2012 Posted May 18, 2012 bleed some pressure off the output into an oil drum to feed the churbro, then dump the oil drain output back into the inlet? damn, you're full of good ideas! what oil pressure do churbors require? Quote
Hemi Posted May 18, 2012 Author Posted May 18, 2012 that would work fine till the turbo start sucking too much oil ..ala runaway turbo Quote
Hemi Posted May 18, 2012 Author Posted May 18, 2012 also the motor that run a big end was a 16l so i dreamt of putting that on there. it is fucking huge only bigger one i know of *might* be the holset item off a 600 siggy Quote
Hemi Posted May 30, 2012 Author Posted May 30, 2012 Had some spare time during the week so i decided that i would have a play with making some new injectors . i wanted to makes one that would try and mix the fuel and air alot better . While i was sitting there i thought why not use a system like a car or other engine where the fuel is mixed before it hits the combustion chamber (flametube). so i drilled tapped and made an injector (out of copper bundy WOO) and put it aside, i also though about the failure of my center injector (it failed to ignite the engine at all) , and decided that it was pushing too much fuel down the tube and not enough outwards against the airflow into the flametube, so i made another injector with hole around the circumfence with a carby jet drillkit i had bought a week earlier ) #70 drillbit whatever thats in refrence to) , also out of copper bundy, had a bit of a stuff up as i was joining the brass and copper together i had what i thought was 34t silver solder after swearing and getting pissed about the finished product i went to grind down the mess i had. it took FOREVER! i let you guys guess what it was *note it was FUCKING hard as in the file was just about sliding over it *. anyway i let my fiery temper settle and assembled the bits and pieces to make it a working piece again. the hole in the neck the injector i made for the neck sitting in its home new fuel regulator setup (i did not want the one in the neck running fulltime incase the fuel mixed real well then hit the spark = BOOOOOM i then run the thing up the new center injector i was well impressed with it instead of the boom i was used to at startup it just came to life (the only reason i knew to was running was the change in vacuum cleaner note). I then started to open the new injector , woah lordy it started ok just tone change then went FOOOMP and everything started glowing orange really quick pic of one of the later runs as you can see that is well inside the flametube , but its cooking the outer combustor wall . which means the flame has gone form the tube to the outer space DAMN. So now that injector might be moved to water injection duties later on down the track . i also had a think about the oil supply problem for the turbo and decided until i come across a nice small gearpump that i would use the workshop oil prelubricator as a oil source and went about setting that up , its a mess but you get the idea! . i also reassembled the vgt part of the turbo that i had pulled to bits thinking i couldnt use it after clocking the turbo. turns out i can, holy shit man vgt is the way of the future you can literally have it idling at x rpm and x flow from exhaust and then move the ring and wham full boost without a change of exhaust flow . fucking cool!. anyway this post has way too much of a attempt at story telling so here you go more bandwidth! the look of the flame with the neck injector on pgZmWkJaAE4the engine being started and then the neck injector being turned out, the second FOOMP is the flame retreating into the space between the flametube and combustor wall eCd5Z_yf9yI this is how i figured the flame was retreating outside the flametube r30CtH9mwhA and a nice vid of oil supply some increase in revs and the turbine wheel getting warm 6wTVjctphyM so have learnt a few things . #1 copper is much better at heat conduction then steel (was hoping the lpg would cool the copper enough , it does not, this resulted in smoking rubber fuel line). and #2 the turbo is MILES too small it reaches full spool at very low fuel openings so now im after a bigger turbo , ideally one with 1 a/r or something Quote
Ned Posted May 30, 2012 Posted May 30, 2012 Nice! What about just making the combustion chamber smaller to suit the smaller turbo as a test unit before making super MkII? Quote
Hemi Posted May 30, 2012 Author Posted May 30, 2012 hah fuck that it works swell as it is just the turbo runs out of puff/sounds like its going to explode before the combustor stretches its arms/, and seeeings as more fuel burnt = more thrust, bigger turbo it is! Quote
toyabusa Posted May 30, 2012 Posted May 30, 2012 haha this is awesome! With your injector in the inlet there wasn't the flame always going to end up in the outer space? Quote
Hemi Posted May 31, 2012 Author Posted May 31, 2012 Yeah had this hope that the flow would stop the flame retreating . made a new injector today too ,mk1 version of a liquod injector. I used an old diesel injector and whipped the end off, waiting for end of day to test! Quote
toyabusa Posted May 31, 2012 Posted May 31, 2012 What's left before you can get a vid up of it running with the turbo not the vac? Quote
DodgySam Posted May 31, 2012 Posted May 31, 2012 "borrow" a turbo off a truck in the workshop. No one will notice. Quote
Hemi Posted May 31, 2012 Author Posted May 31, 2012 What's left before you can get a vid up of it running with the turbo not the vac? the hose btween the turbo and the inlet , i was trying to find some 50mm tube or pipe the other day but there is none anywhere so i might actually have to go buy some . fuck yeah hemi R&D so went to use the liquid injector but unfortunatley my fears came true as there must be some crud in the pipe and it blocks the injector immediatly . so me being smart and all was like ' hrmm well if i use a lpg injector withn the smallest hole and low pressure it might work sweet . dear mother of god what a ammature mistake. i turned the tap on and a flame no less then 3m long full of burning diesel droplets got sprayed EVERYWHERE. keep your napalm that shit was scary and no fire extinguisher in the workshop would have been big enough to put it out . i gave up after that as i think i sucked my pants , overalls and the trucks door behind me up my backside. Quote
Hemi Posted June 1, 2012 Author Posted June 1, 2012 well bummed around with liquid fuel stuff today and have come to the conclusion that introducing liquid fuel into an engine like this is just silly as they amount of vapour you get is phenomenal and waayyy too hard to control . started with a normal ball tap and that was pretty much binary , i then added a pressure regulator but even then a 1/4 turn was the difference between nothing and 3 foot flames . so im going to work on getting the diesel into a vapour state before it enters the chamber prob by wrapped some copper bundy around the end of the combustor. some pisc of today developments. i had made another injector with one hole point straight out the end of the tube. i then made a plate for the jet to hit , the idea is the plate will get red hot and when the jet hits it , it will vapourise and become sweet sweet diesel fog . pic of where it sits in the flametube just a pic so you can see the injector and a pic of it running at a idle on just diesel , got real hot , this is where im thinking of running one or two coils of copper the vapourise the fuel and just a bum vid to show you it running on diesel by itself, shit is just waayy to hardcore and would melt the turbo in minutes/seconds c0_lDvUIMlo Quote
Hemi Posted June 1, 2012 Author Posted June 1, 2012 will just sneak this is but the mirror you can see in the background got so hot it was boiling water. oops Quote
