Ned Posted October 31, 2011 Author Share Posted October 31, 2011 So is your mum. So, anywho, the flywheel that was catching was not the one that was seized... it was the one next to it. It came undone eventually but have no idea why it was fucked. Am thinking i may have been a bit too liberal with the loctite and some possibly got into the bearing? Swapped the catching flywheel over anyway etc and tried to start it but no dice. So wanted to upload the vids i took and got carried away with using windows movie maker haha Quote Link to comment Share on other sites More sharing options...
sheepers Posted October 31, 2011 Share Posted October 31, 2011 if you spent as much time working on this thing as you did making that video it would be running by now............ pull your finger out. Quote Link to comment Share on other sites More sharing options...
Ned Posted October 31, 2011 Author Share Posted October 31, 2011 No it wouldn't. Video took 20min lol but i see what you're getting at. After it didn't unwind itself while trying to start it, i got a large amount of motivation back so don't worry, shit will happen! Quote Link to comment Share on other sites More sharing options...
Beaver Posted October 31, 2011 Share Posted October 31, 2011 that chain looks so seriously tight this. sure it would be better to slacken it off a tad and run a tensioner/follower for it? Quote Link to comment Share on other sites More sharing options...
10Speed Posted October 31, 2011 Share Posted October 31, 2011 time to check for spark? Quote Link to comment Share on other sites More sharing options...
tortron Posted October 31, 2011 Share Posted October 31, 2011 ratchet crankstart ruled me i hope you set something like that up permanently Quote Link to comment Share on other sites More sharing options...
grunta Posted October 31, 2011 Share Posted October 31, 2011 mean bro , that will sound sick when running! Quote Link to comment Share on other sites More sharing options...
Ned Posted October 31, 2011 Author Share Posted October 31, 2011 I will run the car starter motor to start the lot as it's awesome Chain is tight because that massive top bit is actually the tentioned part of the chain, not the slack bit. Plus it will stretch a bit still once it has run for a bit. Will try everything again tonight. Got hot exhaust gasses coming out of some of the exhausts so it should work... Quote Link to comment Share on other sites More sharing options...
Jase Posted October 31, 2011 Share Posted October 31, 2011 prime the carbs more, weedeaters love it when you push a little fuel down the gullet, also are you running all on choke with aircleaners etc on? Quote Link to comment Share on other sites More sharing options...
Ned Posted November 1, 2011 Author Share Posted November 1, 2011 No air cleaners and with choke. I had them all running individually before bolting them to the plates so they do go Quote Link to comment Share on other sites More sharing options...
keltik Posted November 1, 2011 Share Posted November 1, 2011 Might need a flywheel or something similar to get them to start up? To my completely inept ear - the cranking speed sounds a bit low so your not getting enough inertia for the engines that ARE firing to get the rest running. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted November 1, 2011 Share Posted November 1, 2011 run the starter on 24v to get mo' speed Quote Link to comment Share on other sites More sharing options...
Ned Posted November 1, 2011 Author Share Posted November 1, 2011 That started is cranking well fast enough. Pull starting is nowhere near as fast as this car starter haha. All of them still have the standard flywheel plus the huge rear sprocket that weighs about 3Kg (estimate) Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted November 1, 2011 Share Posted November 1, 2011 Make a 10 point engine start injection system to help start them/finish them off. Quote Link to comment Share on other sites More sharing options...
sheepers Posted November 1, 2011 Share Posted November 1, 2011 bit of petrol down the carb and they will be away. probably wont run to good with the air cleaners off. these bastards are super sensitive to changes in intake air. Quote Link to comment Share on other sites More sharing options...
tortron Posted November 1, 2011 Share Posted November 1, 2011 yea, two stokes no likey no airbox Quote Link to comment Share on other sites More sharing options...
Yowzer Posted November 1, 2011 Share Posted November 1, 2011 I wanna see 10 x tuned exhausts on the finished product Quote Link to comment Share on other sites More sharing options...
Steelies Posted November 1, 2011 Share Posted November 1, 2011 i had problems the other day starting with a drill. the motors were firing up first pull (ish) but wouldnt do anything with drill starting.. didnt have a freewheeling starter attachment so it kind of seemed like they would pop but the drill was knocking them back and they wouldnt spin up.. +1 for airbox too. Quote Link to comment Share on other sites More sharing options...
Ned Posted November 1, 2011 Author Share Posted November 1, 2011 Car starters have sprag clutches so thats fine plus i had them all running without exhaust without cleaners etc individually and started with the same car starter motor so the exact same setup i'm using works individually. Not saying you don't have good points, just saying i'm confident the fucker will start tonight when it's not 11pm when i'm trying to figure out whats wrong when all i want to do is go home and sleep haha Quote Link to comment Share on other sites More sharing options...
Yowzer Posted November 1, 2011 Share Posted November 1, 2011 Fill whole room with engine start. Should work a charm. Quote Link to comment Share on other sites More sharing options...
