NicT's Pansy mx5
NicT
You will also need to do a reverse sump (bulge at back) and some major cutting of the subframe. Its easy to do and will look good and work well if done right. Best to remove the subframe and mount it to a jig. Otherwise it WILL warp out of shape when you weld it back up and WONT bolt back into the chassis. Failing that you can modify it while its still bolted to the car. Its a bit harder to get in there and get in all the angles, if you do choose to leave it in be sure to tape up the winscreen, grinding sparks will make a mess of it.
  • Replies 137
I called them gilmours for years (seeing they are a must have any kind of rotary) then one day someone had a big rant and explained it all as being gilmer etc which made sense at the time but now i cant remember it.
either way it makes fuck all difference
