oldnrusty Posted October 16, 2013 Share Posted October 16, 2013 no you dont, you like MX5s! 2 Quote Link to comment Share on other sites More sharing options...
Shaz Posted October 17, 2013 Share Posted October 17, 2013 BUUUUUUUUUUURN! Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted October 17, 2013 Share Posted October 17, 2013 I dont feel any burning sensation, just lovely haircuts at mates rates. 2 Quote Link to comment Share on other sites More sharing options...
Steelies Posted October 17, 2013 Share Posted October 17, 2013 the burning will come once the virus takes hold. be smart russel, LYC 2 Quote Link to comment Share on other sites More sharing options...
e30-323ti Posted October 17, 2013 Share Posted October 17, 2013 See, I told you to get started on that sump.Then your discussion thread wouldn't be plastered with homosexual inuendo and haircuts..... Build something like this beauty from MRP should keep the harasment at bay: 2 Quote Link to comment Share on other sites More sharing options...
J-W-G Posted November 20, 2013 Share Posted November 20, 2013 Dibs on any fe parts if you go BEAMS Quote Link to comment Share on other sites More sharing options...
sr1600 Posted November 20, 2013 Share Posted November 20, 2013 Fits like it was meant to be there Quote Link to comment Share on other sites More sharing options...
xsspeed Posted November 20, 2013 Share Posted November 20, 2013 oh yeah 1 Quote Link to comment Share on other sites More sharing options...
e30-323ti Posted November 20, 2013 Share Posted November 20, 2013 Looks right at home in there!! Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 20, 2013 Share Posted November 20, 2013 THAT'S NO LS!?!?!? But I approve, forest flared Escorts need 2l twin cams bouncing off the rev limiter... 2 Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted November 20, 2013 Share Posted November 20, 2013 Looks ideal in there !! Quote Link to comment Share on other sites More sharing options...
M_C Posted November 21, 2013 Share Posted November 21, 2013 Nice! More pics please! Sides, front, back and under please! How did sump fit? Your firewall is chopped. How do you think it would fit against standard firewall? Possible, or do I need to get angle grinder out? The other Mk1 with 3sge beams I know already had huge firewall chop, but sits forward for sump. -Does 1.21 at Hampton, 120rwkw on link, standard unopened engine. Cheers Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 21, 2013 Share Posted November 21, 2013 No probs will get some better pix. At this stage its just slapped in the hole as i currently have a bung shoulder and was difficult just getting this far. So the other escort you spotted had it mounted up the front like mine? not half a doz feet back. No dizzy on back rules for clearance. Front bowl looks like it will sit nicely in gap, worst case go compression strut. Engine is quite tall, not sure how its going to go fitting with cover on. If it wasnt for that pesky steering rack i would just chop stright into the crossmember. Width is nice. standard mounts look like they can be made to work nicely. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 21, 2013 Share Posted November 21, 2013 Just trying to work out how to do the fuel side of town and few bits n bobs then drop the loom of to be sorted. might try get it running on the ground. anyone got any good examples of these settup sunning of std comp? Quote Link to comment Share on other sites More sharing options...
M_C Posted November 21, 2013 Share Posted November 21, 2013 Marks mk1 beams had severe firewall chop when he got it. But 3sge sits up front over the cross member, otherwise was likley going to be dry sump to get under windscren and definitely remote linkages for gearstick. He ran the standard computer to start with but only had 80rwkw. We think it was missing some sensors or not done right as putting a link and tune on it turned it into 120rwkw! Ill PM you his number. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 21, 2013 Share Posted November 21, 2013 Hmmm the darn ECU had a rattle, opened up and has bloody dry mud in it! What has this engine / ECU been up to. (crate motor, gearbox, loom from japan) I'm starting to wonder if i need the other half of the loom also? Few ports are empty. something like this work? with a bosh 044? Slurp Quote Link to comment Share on other sites More sharing options...
Truenotch Posted November 21, 2013 Share Posted November 21, 2013 Pm'd. Great choice by the way. Quote Link to comment Share on other sites More sharing options...
Spencer Posted November 21, 2013 Share Posted November 21, 2013 You going aftermarket ECU? Quote Link to comment Share on other sites More sharing options...
danger Posted November 21, 2013 Share Posted November 21, 2013 Easily one of my favourite cars on here Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 21, 2013 Share Posted November 21, 2013 You going aftermarket ECU? See how things pan out, the plan was to try to keep it completely standard for some reliable track time to get everything else sorted and worry about powa later on. Oh cheers Danger . . . would be nice to use it a bit more. 1 Quote Link to comment Share on other sites More sharing options...
