sheepers Posted February 10, 2015 Share Posted February 10, 2015 yea boy. mustang. crown aint as much fun round the twists and the hills. plus you two kids will be acting the goat and getting up to shenanigans and the crown aint no place for that. Quote Link to comment Share on other sites More sharing options...
Spencer Posted February 10, 2015 Share Posted February 10, 2015 I was going to be on my best behavior in the crown. But yea sounds lush I like shenanigans. Quote Link to comment Share on other sites More sharing options...
sheepers Posted February 10, 2015 Share Posted February 10, 2015 I was going to be on my best behavior in the crown. yea for about two minutes. nek minute broken plates all over the place. 4 Quote Link to comment Share on other sites More sharing options...
slacker.cam Posted February 10, 2015 Share Posted February 10, 2015 I can't wait to see what this does when you head back to the dyno! What's your goto tool for cutting sheet ali? Quote Link to comment Share on other sites More sharing options...
sheepers Posted February 10, 2015 Share Posted February 10, 2015 im using a jig saw with a medium TPI blade. one that designed for steel. seems to work fine. the box section that im using is 3mm wall and the plate is 2mm wall. Quote Link to comment Share on other sites More sharing options...
e30-323ti Posted February 11, 2015 Share Posted February 11, 2015 Catch tank looks good! Did you use -10 or -12 and connect to the stock valve cover vents? Is a real tidy setup! ps. Where are you taking the IACV inlet too? Around to the inlet pre-turbo? I was contemplating just putting a little K&N filter onto the IACV. Quote Link to comment Share on other sites More sharing options...
sheepers Posted February 11, 2015 Share Posted February 11, 2015 thanks man! the two fittings for the oil catch can are matched to the pipes that come off the cam covers so one is -8 and the other is -6. the idle control valve just has a little filter on the end of the pipe down beside the bellhousing starter motor area. so pretty much the same as you say. Quote Link to comment Share on other sites More sharing options...
Roman Posted February 11, 2015 Share Posted February 11, 2015 I Rikey Quote Link to comment Share on other sites More sharing options...
beachlander Posted February 11, 2015 Share Posted February 11, 2015 I quite enjoy being able to perve on this when I go to pick up parts for work Quote Link to comment Share on other sites More sharing options...
Stu Posted February 26, 2015 Share Posted February 26, 2015 Awesome work on the numbers - saw you guys heading out. Did B or Glenn twiddle the dials? Are there lots of un-intended 11's on the roads around here now? Quote Link to comment Share on other sites More sharing options...
Snoozin Posted February 26, 2015 Share Posted February 26, 2015 Man I cant wait to giggle while travelling in this car. Quote Link to comment Share on other sites More sharing options...
sheepers Posted February 26, 2015 Share Posted February 26, 2015 theres a single legger in my undies i can tell you that. Glenn did the tune with Brendon helping. i stood around and said stupid things - as is my habit. man does this thing lay 11's now. even when you trying not to. Brendon said i should stop in an see you on my way back but i completely forgot. i had other things on my mind as you could imagine. 1 Quote Link to comment Share on other sites More sharing options...
Rookie Posted February 26, 2015 Share Posted February 26, 2015 Those are pretty good numbers for your setup Sheepers, you should be stoked. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted February 26, 2015 Share Posted February 26, 2015 That's epic. Keen for passenger poos at some point. 1 Quote Link to comment Share on other sites More sharing options...
Roman Posted February 26, 2015 Share Posted February 26, 2015 Epic! Cant wait to see some trackday hoonage in this thing. Quote Link to comment Share on other sites More sharing options...
Nominal Posted February 27, 2015 Share Posted February 27, 2015 That is serious power - good job! Quote Link to comment Share on other sites More sharing options...
Sparkle Posted February 28, 2015 Share Posted February 28, 2015 can i has passnger 1 Quote Link to comment Share on other sites More sharing options...
Stu Posted March 1, 2015 Share Posted March 1, 2015 Haha man I'd be the same - I'd want to drive the pants of it rather than stop anywhere, will be other times. B sent me the numbers from the GTZ too. Duels on the way home? theres a single legger in my undies i can tell you that. Glenn did the tune with Brendon helping. i stood around and said stupid things - as is my habit. man does this thing lay 11's now. even when you trying not to. Brendon said i should stop in an see you on my way back but i completely forgot. i had other things on my mind as you could imagine. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted October 26, 2015 Share Posted October 26, 2015 That T1R business sounds pretty strange... How many K's have you done on them? It's common for tyre shops to warn you that the car will feel funny for the first 300km or so until the mould release wears off. That's all I can think of. The difference in profile can't have made that much difference. Quote Link to comment Share on other sites More sharing options...
fuel Posted October 26, 2015 Share Posted October 26, 2015 I found the same with the T1R's in 205/50 R15 I bought for the Eterna those years ago. I think the issue is that in smaller sizes, the T1R's just don't cope with the weight of the car. Quote Link to comment Share on other sites More sharing options...
