cletus Posted October 7, 2010 Share Posted October 7, 2010 some stuff needs to be welded by a ticketed welder and crack tested but its only parts considered "critical" eg brake caliper brackets, loaded suspension arms etc. engine mounts and things like that are ok to be welded by joe bloggs as long as the welds are ok Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 28, 2010 Share Posted October 28, 2010 To run airbags it says thety must not operate when the vehicle is moving - is having a relay operated off the handbrake light enough or does there have to be some speed sensitive switch? Also any idea on what crack testing would cost for welded struts and suspension arms like these below? Is a magnaflux check enough or do they need to be x-rayed? Quote Link to comment Share on other sites More sharing options...
Simon Posted October 28, 2010 Share Posted October 28, 2010 To run airbags it says thety must not operate when the vehicle is moving - is having a relay operated off the handbrake light enough or does there have to be some speed sensitive switch? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 28, 2010 Share Posted October 28, 2010 ah yeth - I did not see that.. I wonder what I would be able to use with a mechanically operated speedo in a manual transmission.... Quote Link to comment Share on other sites More sharing options...
cletus Posted October 28, 2010 Share Posted October 28, 2010 you could use a relay to just make the system work when the engines not running eg a switching relay off the + side of the coil cant remember how much crack testing costs, depends where you get it done i spose. magnaflux is fine usually Quote Link to comment Share on other sites More sharing options...
karmagedon Posted October 31, 2010 Share Posted October 31, 2010 2 things : 1) number plates - is there an exact law that states dimensions a plate has to be? 2) what is the law in regards to headlights? Ie those repco "driving lights", can I use them in place of my factory lights? Thanks for any help Quote Link to comment Share on other sites More sharing options...
Simon Posted October 31, 2010 Share Posted October 31, 2010 2 things :1) number plates - is there an exact law that states dimensions a plate has to be? Yes, those set by the NZTA. It is illegal to have any numberplate on a car that is not issued by the NZTA. I have tried for a stick on one for the MR2. Even if it's reflective and in the same font... they say no. Quote Link to comment Share on other sites More sharing options...
karmagedon Posted October 31, 2010 Share Posted October 31, 2010 2 things :1) number plates - is there an exact law that states dimensions a plate has to be? Yes, those set by the NZTA. It is illegal to have any numberplate on a car that is not issued by the NZTA. I have tried for a stick on one for the MR2. Even if it's reflective and in the same font... they say no. ok, because I went through the legisislation (albeit it was from 2007) and all it had on there was that it had to be reflective and the backing had to be aluminium, so i was after the actual legislation involving this topic. Quote Link to comment Share on other sites More sharing options...
JoKer Posted October 31, 2010 Share Posted October 31, 2010 rarer that rockin horse faeces I did get an email once from them re: same thing BUT the kind lady could not point me in the exact direction neither.... Quote Link to comment Share on other sites More sharing options...
Guest Posted November 1, 2010 Share Posted November 1, 2010 Fun fact: You do not require a front numberplate for a Wof, only rear Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 1, 2010 Share Posted November 1, 2010 Funner fact - you do not require a number plate at all for a WOF if you can prove the vehicles identification - it is not a safety item so therefore it is a matter governed by the police.. kind of like not having a rego - you don't need rego for a WOF either.. Just like you do not require a seat for a WOF - only if it is fitted does it have to be safe and secure.. But any WOF place with common sense should refuse to check a car for a WOF presented in this state.. Quote Link to comment Share on other sites More sharing options...
Raizer Posted November 1, 2010 Share Posted November 1, 2010 An over zealous WOF man failed my old Legacy for the front plate not being in the stock location once (but he was just a cunt who failed me on a whole list of stupid shit that were not WOF issues) Quote Link to comment Share on other sites More sharing options...
JoKer Posted November 1, 2010 Share Posted November 1, 2010 I passed a few with no plate on my leggy for shits and giggles Quote Link to comment Share on other sites More sharing options...
BS5620 Posted November 5, 2010 Share Posted November 5, 2010 needing to modify an escort x-member to fit into my cortina. Stated slotting holes and old mounts have got messy. Now have figured I need to mount x-member a tad further back so have drilled out the welds to remove old mounting brackets. I plan to get new tidy ones made up that fits. Will this be ok for a cert?? My engine mounts are off the chassis rails so not attached to the engine x-member!! Cheers Quote Link to comment Share on other sites More sharing options...
Testament Posted December 1, 2010 Share Posted December 1, 2010 I'm not sure if I asked this earlier/somewhere else - Is it possible/required to have removed ABS certed? does it amke any difference if the car was available with and without ABS from new in NZ? Quote Link to comment Share on other sites More sharing options...
cletus Posted December 1, 2010 Share Posted December 1, 2010 needing to modify an escort x-member to fit into my cortina. Stated slotting holes and old mounts have got messy. Now have figured I need to mount x-member a tad further back so have drilled out the welds to remove old mounting brackets. I plan to get new tidy ones made up that fits. Will this be ok for a cert?? My engine mounts are off the chassis rails so not attached to the engine x-member!! Cheers should be ok this is a situation where you should get your local certifier involved so they know what you are up to Quote Link to comment Share on other sites More sharing options...
cletus Posted December 1, 2010 Share Posted December 1, 2010 I'm not sure if I asked this earlier/somewhere else - Is it possible/required to have removed ABS certed? does it amke any difference if the car was available with and without ABS from new in NZ? yes does require certing and yes it can be certed, needs to have all ABS components removed properly Quote Link to comment Share on other sites More sharing options...
twosmoke Posted December 1, 2010 Share Posted December 1, 2010 . Quote Link to comment Share on other sites More sharing options...
MrMcdoll Posted December 1, 2010 Share Posted December 1, 2010 What's the deal with half cages (a roll over bar with 2 back stays) in 1) a bolt in situation 2) a weld in do they need to be homologated or certed? I head that bolt in ones are fine as is. Quote Link to comment Share on other sites More sharing options...
zep Posted December 1, 2010 Share Posted December 1, 2010 I have a welded in 1/2 cage with main hoop, 2 back stays, harness bar, an X between the back stays, and side intrusion bars from about 300mm up the main hoop to the bottom of the A pillar. Only needed certing, no homologation. Quote Link to comment Share on other sites More sharing options...
