BS5620
Everything posted by BS5620
Cheers for the help guys. Anglia4= Champion Thanks for the offer UJ but I'll just tax some from the tin at work. Plus get some grinding paste and lap the shit out of it!!
You understand the situation completely. Mk2 cortina struts I have been told are Imperial and Escort/Starlet ones on the TCA are metric. But with my rudemetry mathematics (SOH CAH TOA) and measurement I make the angle of the two tapers to be the same... Shim stock is a boomer idea. Will be a cost effective fix, cheers for the suggestion. The R&P is good, just small hold ups like this, I'm so close I can smell it.
Hey UJ Putting Rack in pinion in my Mk1 Cortina. Have used starlet gear, with mk2 Struts. Luckly certifier picked up on movement where Starlet lower arms go into Mk2 Struts. Need to sort this issue but having problem between Imperial and Metric tapers.. Want to run some of those adjustable escort TCAs that are on Trademe. So might see wether engineers can bore out tapers to suit!!! Mission continues
Would be cool if you could thanks. Cheers I'll try there too Thanks
I'm after a favour here. I'm looking for the lengths of both Anglia and Mk2 Cortina Track control arms if anyone is able to help with either! Measurement from centre of where it mounts in crossmember out to the Ball Joint pin. I have done the googley searchs but have revealed nothing yet!!! Does anyone know what uses the same ball joint pin taper as a Mk2 Cortina?? I think they have an Imperial Taper
Did you get your vibration fixed? Was it the diff? In my Mk1 cortina the o2 sensor pick up on the extractors were hitting on the engine x-member and a bolt from the g-box was touching against that x-member to. Create clearance vibration gone. Just putting it out there for other ideas or areas to check if the diff wasnt the problem
Cheers kritta that was my next thought. So all Robinson did was to replace the insides of your smiths one to one that would accept the 4age set up?
yeah just one coil. there is a wire that runs from the neg on the coil to the tacho and then I have one wire that runs no where. How would I figure what one is the ignitor switched wire?
Is it possible to connect a Smiths rev gauge RVI type to a blue top 4age. Have been searching the net all afternoon and haven't found a solid answer yet. I'm coming to the conclusion that it won't be possible!! Here is a wiring diagram I have managed to find. Mine is the middle one. Cheers
Alex's 1968 'oldman special' HB Viva discussion....
BS5620 replied to yoeddynz's topic in Project Discussion
Well done. Awsome to hear when cars get certed. Will keep my eyes out for it around town -
Could try Safe Air at Woodbourne, they do heaps of NDT. Not sure about private jobs but worth an ask!!
bricon are good guys. out towards the airport. was around $100-$130 for one
yeah this hits on the side at the back end so 3-5mm i think i wont touch it with a file!! Having the flange milled down is a good idea but dont think it would remove enough!! Probably have to add a spacer to 1 engine mount to to put engine on a lean!!! Cheers
For all of you that have cut and shut a 4age inlet manifold. Can you remember how thick it was???????. Got pulled up on my cert for the brake M/C hitting the manifold so want to file some meat off to give some clearance!! Cheers
Iv been putting one into my mk1 cortina over the last few years. Its been a big, slow job, but i have learnt a heap along the way. Would be heaps easier if you were a good welder!! To get it wired up was around $500. Good luck
realised that. This was a full vinyl wrap not stickers
My flatmate who used to be a sign writer did one of our tutors bonnets in a carbon fibre vinyl. Turned out real nice, didnt take long either. Sign writer would be the best person to see
A lot of wires cause a lot of fires!!! Very lucky to find................Don't worry I think there a few of us out there that the car gods hate!!! Keep with it
Am I correct in thinking I saw this at the McDonalds/New World car park in Blenheim on friday??. If so mint car mate nice work.
sorry was unaware cheers for the pointer
edit: Oldschool does not condone the selling of cut springs.
Does anyone have some datsun 1200 tops they can measure for me please??
nah i'll just chuck them on the lathe again to get them captive. I'm thinking of this so I dont have to have cutties!!
^^ yeah have cut down original springs to just on captivity, but still no luck. Also the red lowering springs are just captive to, so this spring idea was the plan B
Cheers for that wil look into it. Anyone have other ideas k series toyota/mazda?? If anyone can measure and post there spring dia and what the top cup looks like that would be awsome cheers
