cletus Posted January 3, 2011 Share Posted January 3, 2011 Whats it got written on the plate/whats weird about it? there is some paperwork that comes with the plate, but its not really important, the plate covers it all. ie if its not on the plate then the cert doesnt cover it. Quote Link to comment Share on other sites More sharing options...
twosmoke Posted January 4, 2011 Share Posted January 4, 2011 . Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted January 4, 2011 Share Posted January 4, 2011 On the plate it is certed for a 2 Litre Nissan Inline 6 Non-Turbo (RB20DE?) but I cant see any evidence to say it has been anything other than a factory SR20. Also, why would you bother converting to a gutless non turbo motor and get it all certed etc? Doesnt make sence. error? i know of a a couple of cars certed for engine that arn't in them, and for adj' suspension when its just lowering springs Quote Link to comment Share on other sites More sharing options...
cletus Posted January 4, 2011 Share Posted January 4, 2011 is probably a mistake.... if you go see your local certifier he could probably organise a re printed plate for you. nostalgia motors in hamilton Quote Link to comment Share on other sites More sharing options...
KKtrips Posted January 12, 2011 Share Posted January 12, 2011 Just found this.. is AWESOME!! http://www.lvvta.org.nz/ most probably been posted here before. Oh Well.. Quote Link to comment Share on other sites More sharing options...
Josh Posted January 19, 2011 Share Posted January 19, 2011 I have a question. Being lazy etc/whatever. Instead of hooking up speedo cable/getting custom one made etc, have heard can mount up a gps unit and use the speed thing off that? I don't see why not however what is the cert man likey to say? Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 19, 2011 Share Posted January 19, 2011 pretty sure you need a working odometer? maybe not.... Quote Link to comment Share on other sites More sharing options...
Corbie Posted January 19, 2011 Share Posted January 19, 2011 nah don't 'need' odometer but you do need to have speedo.. also has to be permanently mounted. Quote Link to comment Share on other sites More sharing options...
Josh Posted January 19, 2011 Share Posted January 19, 2011 Sweet, think I may mount up one then as will be way easier/cheaper. Quote Link to comment Share on other sites More sharing options...
cletus Posted January 19, 2011 Share Posted January 19, 2011 yes have certed a couple of cars like that, there is no legal requirement for an odometer. Not sure what happens in the case of a diseasel though. gps must be permanently mounted and wired in. www.speedhut.com sells proper gps speedos Quote Link to comment Share on other sites More sharing options...
Josh Posted January 19, 2011 Share Posted January 19, 2011 Ah yes you are who I was looking for confirmation from, thanks buddy. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted January 19, 2011 Share Posted January 19, 2011 engine mounts these bolt to the engine then to the rubber block, thus avoiding cross member mods do i need to crack test these? im 98% sure i dont Quote Link to comment Share on other sites More sharing options...
cletus Posted January 19, 2011 Share Posted January 19, 2011 nah dont need to crack test them visual inspection is ok or demonstrate your welding skillz to the certifier if he requires looks good from here Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted January 19, 2011 Share Posted January 19, 2011 best to leave bare metal for cert then? Quote Link to comment Share on other sites More sharing options...
drivekp60 Posted February 5, 2011 Share Posted February 5, 2011 rumor has it in a couple of months you cant cert coilovers. is this true? anyone know anything about this? Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted February 5, 2011 Share Posted February 5, 2011 adjustable height is poos for road use anyway how often do you actually need to adjust it to drive your nana to woolworths im sure converting to a 65mm spring and using different spring length/spacers/shims with adj' dampers will still be legit if people feel they MUST have them then they will just need to get a 'go racing and collect your coilovers' card Quote Link to comment Share on other sites More sharing options...
cletus Posted February 5, 2011 Share Posted February 5, 2011 Ban has been discussed but not decided yet as far as i know. For most people its a good way of lowering a car properly without having to spend $$ on custom stuff, (which is quite hard to find someone who knows what they are doing) Most people adjust it to the height they want and leave it there. Its the same old story, 2% of people have (potentially)fucked it for everybody else. Quote Link to comment Share on other sites More sharing options...
twosmoke Posted February 6, 2011 Share Posted February 6, 2011 . Quote Link to comment Share on other sites More sharing options...
karmagedon Posted February 10, 2011 Share Posted February 10, 2011 In regards to scooter bike frames. If it was originally made out of steel, can I make one out of aluminium tube? Does it need to be certed or anything of the sort. For a 50cc engine Quote Link to comment Share on other sites More sharing options...
