Snoozin Posted August 16, 2016 Share Posted August 16, 2016 //oldschool.co.nz/index.php?/topic/53734-gx71-bc-golds/ Can you please shed some light on if this mention of change in the permissible way to weld a coilover on is still acceptable? Quote Link to comment Share on other sites More sharing options...
cletus Posted August 16, 2016 Share Posted August 16, 2016 //oldschool.co.nz/index.php?/topic/53734-gx71-bc-golds/ Can you please shed some light on if this mention of change in the permissible way to weld a coilover on is still acceptable? Nothing has changed, the way yours is done is still sweet. Quote Link to comment Share on other sites More sharing options...
cletus Posted August 16, 2016 Share Posted August 16, 2016 Just received updated standards mail out, the suspension one has changed and says how ^ has to be done now. Same as its been known to be for a while but official now. www.lvvta.org.nz is worth a look at, most of the standards have been updated with more info, and a lot of the changes are in an effort to make things easier. Some of the standards haven't been updated on the website yet but should be soon 2 Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted August 17, 2016 Share Posted August 17, 2016 Hi Clint I have a coil over question I have a set of Fortune coil overs that were fitted to Berjjs e21, made at the same time as the ones Sparkle has fitted to his car. They are all welds are tested and certified, and the correct build process followed to make them legal. They have only done a couple of thousand Km. Its still going to be a while before i will have my car driving, is there a time restriction/expiry for the work to allow them to be used and get the car certed. When you cert the car in the unknown future, is there a chance that the coilovers will not be up to standard as they were inspected X years ago?? Thanks. Quote Link to comment Share on other sites More sharing options...
Nominal Posted August 17, 2016 Share Posted August 17, 2016 A friend of mine had to get all his suspension bits retested (crack tested) because the previous place was no longer acceptable. Quote Link to comment Share on other sites More sharing options...
63Ragtop Posted August 18, 2016 Share Posted August 18, 2016 Just wondering, we can't narrow/widen alloy wheels/mags in this country can we? Quote Link to comment Share on other sites More sharing options...
cletus Posted August 18, 2016 Share Posted August 18, 2016 Hi Clint I have a coil over question I have a set of Fortune coil overs that were fitted to Berjjs e21, made at the same time as the ones Sparkle has fitted to his car. They are all welds are tested and certified, and the correct build process followed to make them legal. They have only done a couple of thousand Km. Its still going to be a while before i will have my car driving, is there a time restriction/expiry for the work to allow them to be used and get the car certed. When you cert the car in the unknown future, is there a chance that the coilovers will not be up to standard as they were inspected X years ago?? Thanks. if they are the same as sparkles then they should be ok, i dont think there is a time limit on the crack test, it will probably be a case of proving they are the same parts...worst case you may have to get them tested again Quote Link to comment Share on other sites More sharing options...
cletus Posted August 18, 2016 Share Posted August 18, 2016 Just wondering, we can't narrow/widen alloy wheels/mags in this country can we? not 1 piece wheels, no. wheels with unbolt-able lips can be Quote Link to comment Share on other sites More sharing options...
SOHC Posted August 18, 2016 Share Posted August 18, 2016 Wen re registering a car that has custom made front coilovers and arms etc do they need to be crack tested? Edit: I gess if you could prove they were fitted before? Quote Link to comment Share on other sites More sharing options...
cletus Posted August 18, 2016 Share Posted August 18, 2016 cert time would be when you have to get that done, so if it already has a cert, nope 1 Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted August 18, 2016 Share Posted August 18, 2016 if they are the same as sparkles then they should be ok, i dont think there is a time limit on the crack test, it will probably be a case of proving they are the same parts...worst case you may have to get them tested again Many thanks. Good to Know. Quote Link to comment Share on other sites More sharing options...
SiRge Posted August 18, 2016 Share Posted August 18, 2016 Reregistering a car, and have replaced the brake master cylinder with something more modern and larger (old one shagged and done its dash). Does it require a cert or is that maintenence? (Will be getting appropriate one based on advice from brake shop) Quote Link to comment Share on other sites More sharing options...
cletus Posted August 19, 2016 Share Posted August 19, 2016 Yes that would need cert. Quote Link to comment Share on other sites More sharing options...
SiRge Posted August 19, 2016 Share Posted August 19, 2016 So would you reregister first then go for cert or the other way around, even though the car doesnt have a registered number plate... Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted August 19, 2016 Share Posted August 19, 2016 that is all a bit tricky Local cert man said its better to go for cert first, as he normally allows 2 months, instead of 28 days for compliance. however, not sure how that works with a Vin number. Quote Link to comment Share on other sites More sharing options...
SiRge Posted August 19, 2016 Share Posted August 19, 2016 More to the point, how easy is it to trick the WOF man of said master cyl upgrade on a car he's probably never seen before, that it was always meant ot be like that Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted August 19, 2016 Share Posted August 19, 2016 probably fine to be honest I would just not mention it, and if it gets pulled up on it, then deal with it then. 1 Quote Link to comment Share on other sites More sharing options...
fletch Posted August 19, 2016 Share Posted August 19, 2016 More to the point, how easy is it to trick the WOF man of said master cyl upgrade on a car he's probably never seen before, that it was always meant ot be like that Wipe it with greasy hands then half clean it with a rag/throw some dust at it. Quote Link to comment Share on other sites More sharing options...
cletus Posted August 19, 2016 Share Posted August 19, 2016 Best way IMO is go get Vin assigned to car, proceed with cert etc, then get the actual re reg inspection done after cert is done. Get heaps of people get all panicky and shitty cause they are running out of the 28 days you get for re reg inspection recheck, it's not easy to get it all done in that time if it needs repairs and a cert check then repairs for that as well, and get a cert plate in time 3 Quote Link to comment Share on other sites More sharing options...
crownin round Posted August 20, 2016 Share Posted August 20, 2016 Hey just a quick not that old school but do extended ball joints require certification. Iv got a wof twice before with them (vtnz and toyota) but my latest wof they want me to get a email/pice of paper from a certifier to say they don't need a cert otherwise I can't get passed? Just wondering about the logistics of it all. Ps it's a press fit style ball joint. Made by Amada Extreme for a KUN26R Hilux. Quote Link to comment Share on other sites More sharing options...
