tim13 Posted February 14, 2016 Share Posted February 14, 2016 wouldn't hurt to have a hard copy of your booking with you , if you wanted to be extra cautious maybe even run it through a wof check first so you have the fail sheet that says cert requires update ........... of course you may pass given the amount of wof inspectors who think if it has a cert for anything it covers everything ! Quote Link to comment Share on other sites More sharing options...
cletus Posted February 14, 2016 Share Posted February 14, 2016 Clint oh oracle of knowledge im looking at putting some side flaps on my rally car can i drill and put riv nuts in the underside of my sills like 4 or is this a no no my other option is to make them longer and bolt through the floor like what you see on the side of this car cant see a problem with that 2 Quote Link to comment Share on other sites More sharing options...
madmitsi Posted February 14, 2016 Share Posted February 14, 2016 Just a quick one, are we allowed to make our own spacers/adapters looking to go from 4x114.3 to 5x114.3. Cheers 1 Quote Link to comment Share on other sites More sharing options...
bigmatt4 Posted February 15, 2016 Share Posted February 15, 2016 booked my van at the end of the month for certs do i have to have a wheel alignment sheet? I do my own alignments with stringlines and camber gauges and never had an issue with tyre wear or handling issues. Quote Link to comment Share on other sites More sharing options...
Beaver Posted February 15, 2016 Share Posted February 15, 2016 booked my van at the end of the month for certs do i have to have a wheel alignment sheet? I do my own alignments with stringlines and camber gauges and never had an issue with tyre wear or handling issues. Most likely yes. If you have played with the suspension then you need a wheel allignment sheet to prove it is within 0.5 degrees of factory spec. Quote Link to comment Share on other sites More sharing options...
cletus Posted February 15, 2016 Share Posted February 15, 2016 Just a quick one, are we allowed to make our own spacers/adapters looking to go from 4x114.3 to 5x114.3. Cheers you can make your own if you have the equipment and skill. however the tricky part is 2 studs interfere with each other http://lvvta.org.nz/documents/standards/LVVTA_STD_Wheels_&_Tyres.pdf Quote Link to comment Share on other sites More sharing options...
cletus Posted February 15, 2016 Share Posted February 15, 2016 booked my van at the end of the month for certs do i have to have a wheel alignment sheet? I do my own alignments with stringlines and camber gauges and never had an issue with tyre wear or handling issues. yes need a wheel alignment sheet. Quote Link to comment Share on other sites More sharing options...
NickJ Posted February 15, 2016 Share Posted February 15, 2016 Whats the dealieo with that rule where you can drive your unwarranted vehicle if you are driving it to a place to get work required for the warrant? My Starlet has rego on hold(last rego was 2014) and wof expired. It needs a new cert because I have changed from a sohc to a dohc. My cert guy is in carterton(Julian Cheer), I am in Upper hutt. Technically, getting the cert is "work required for the wof".... If I drive it to carterton, and I am stopped by "the man", would I get away with it? I would probably be stopped because my car has panels that are not all the same colour, rather than for speeding or whatever. Whenever i've been pulled up without a wof (usually checkpoints) they look at the wof sheet and still write a ticket with a 28 day compliance, just have to write in with proof the wof was attained and they withdraw the fine. Quote Link to comment Share on other sites More sharing options...
R100 Posted February 16, 2016 Share Posted February 16, 2016 Whats the best way to do a drive-shaft loop on an MX5 ? Anyone done one or a series 6/7 RX7 Im guessing you just could just use a bit of flat bar and bend it around and attach to the PPF ? Cheers Quote Link to comment Share on other sites More sharing options...
mjrstar Posted February 16, 2016 Share Posted February 16, 2016 I have one on my mx5 but the ppf is looong gone. Quote Link to comment Share on other sites More sharing options...
R100 Posted February 17, 2016 Share Posted February 17, 2016 I also got rid of the PPF on my old mx5. Quote Link to comment Share on other sites More sharing options...
chris r Posted February 18, 2016 Share Posted February 18, 2016 Upgrading from front drums to discs - Is there a minimum size for vehicle size etc? If I make a bracket to mount the caliper is there a minimum thickness it needs to be? 6mm/10mm? What is the deal with the disc conversions from the states with the new spindles rotors etc? Quote Link to comment Share on other sites More sharing options...
Nominal Posted February 18, 2016 Share Posted February 18, 2016 Upgrading from front drums to discs - Is there a minimum size for vehicle size etc? If I make a bracket to mount the caliper is there a minimum thickness it needs to be? 6mm/10mm? What is the deal with the disc conversions from the states with the new spindles rotors etc? Yes, in the HCTM - can look tomorrow. I used 10mm. Probably OK if properly engineered. Some of the USA caliper brackets are sketchy, best if the are one piece, TIG welded spacers on the bracket are OK, but 2-piece welded brackets are undesireable. 1 Quote Link to comment Share on other sites More sharing options...
gambit120 Posted February 18, 2016 Share Posted February 18, 2016 Was sold a de-registered 92 FXGT and found it still has a current WOF. Seller said she wanted the car gone and was going to sell it to the wreckers so surrendered the plates. The engine looks to have done a timing belt which is the cause of it being sold (owner cbf'd). Am about to replace the timing belt but the engine bay is covered in oil so after another engine as its done close too 400K's. How hard is it to get re-certed? Everyone I've spoken too have said over 1K which I'm not sure is worth it. Esp if I have to tow the thing to the compliance centre. Quote Link to comment Share on other sites More sharing options...
Bling Posted February 18, 2016 Share Posted February 18, 2016 Read this, it should answer your question. //oldschool.co.nz/index.php?/topic/51700-my-re-registering-a-vehicle-experience/ The AE92 doesn't sound like a car i'd bother putting back on the road, but only you can make that call. Especially if you plan to put a silvertop engine in (other thread?) as it will require a cert on top of all the costs mentioned in the above thread. Quote Link to comment Share on other sites More sharing options...
gambit120 Posted February 18, 2016 Share Posted February 18, 2016 It already has a silvertop in it (factory) and its a ae101 Quote Link to comment Share on other sites More sharing options...
Bling Posted February 18, 2016 Share Posted February 18, 2016 Ah my bad! The link above should help in any case. Quote Link to comment Share on other sites More sharing options...
SOHC Posted February 18, 2016 Share Posted February 18, 2016 Where would I find a chassis number on a fiberglass t bucket built in the 80s? would they have stamped it in to the chassis or would it have had a riveted on vin tag? Quote Link to comment Share on other sites More sharing options...
Nominal Posted February 19, 2016 Share Posted February 19, 2016 Yes, in the HCTM - can look tomorrow. I used 10mm. Probably OK if properly engineered. Some of the USA caliper brackets are sketchy, best if the are one piece, TIG welded spacers on the bracket are OK, but 2-piece welded brackets are undesireable. Disc Brake guide sizing for heavy rod or fullsize USA car (1500-2000kg) (BTW Mercury is right on 2000kg) By Engine HP HP 150-300: 280x25 vented HP 300-450: 300x28 vented HP 450-600: 300x32 or 330x30 vented HP 600-750: 300x35 or 332x32 vented This is only a guide - proper brake test during cert still applies. 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted February 19, 2016 Share Posted February 19, 2016 Whats the best way to do a drive-shaft loop on an MX5 ? Anyone done one or a series 6/7 RX7 Im guessing you just could just use a bit of flat bar and bend it around and attach to the PPF ? Cheers yeah that. i think someone does a loop you can buy pre made for mx5 that bolts straight on, it uses that beam as one side of the loop Quote Link to comment Share on other sites More sharing options...
