Showing content with the highest reputation on 27/12/22 in all areas
Another few hours in the garage today, doors are assembled and hung properly. Almost forgot to spray underbody deadener in the guards! Smashed some more cavity wax in the doors and guard structure and my face. The guts of the fittings for the tail lights and rear panel are a bit flogged out so I’ll have to get a kit, half of them holding for now.28 points
I am genuinely humbled with my amazing friends. @Seedy Al@Goat@JasonK who all turned up this morning to help me do some stuff that my aging body just struggles to do, especially on my back (giggidy) . We did a solid 6 hours work, fitting gearbox, making brake lines, mounting fuel pump and filter plus a multitude of small shit I cannot even remember. Thank you so much to you guys for the motivation ♥♥♥, your enthusiasm, your getting shit done while I stood there and complained about my aches and pains. You have done in 1 day what would have taken me a solid 6 weeks of nights to do. For this, I am so very grateful. Love you guys and I hope your good ladies squeeze your buns and touch you in ways that I shouldn't. So now I have pretty much everything done under and outside the car that I need to get done and I move to doing the interior stuff and get as much of that in as I can before I ship it to the sparky for a rewire at the beginning of Feb. Some pics from today. Doesn't look like a lot from previous pics, but I can tell you that a metric fuck tonne got done. (2 olympic size swimming pools stacked to the top of an elephant on a double decker bus travelling to the moon to be precise) Dreamy Al.26 points
Quick update while there is some peace and quiet around here. Went for cert recheck and got the big tick / cert donut. May have already covered it, but spent a bit of time sorting the suspension travel to get it to comply. Just one of the joys of a light chassis, where half the weight in the rear is unsprung. Lots of maths and a bit of trimming here and there and I got it bang on. Pretty sure I could pull the rear suspension out with my eyes closed now. So yeah, cert man said I did a good job and I was on my way. Christmas period means it won't be in the system till next year, hopefully no hiccups in that regard. So i'll hopefully have it WOF'd by end of January. Carb still needs a bit of work, there is a local guy that rebuilds them, but i'm not sure he will be interested in determining what the actual problem is. So I may have to try sort that myself. Just likes to either run on, or stall at lights. So I currently have it fiddled to run a higher idle so that it doesn't stall, the less embarrassing option. So time allowing i'll potentially swap bits between the cars and see if I can isolate the problem, be it the dieseling solenoid or whatever other voodoo controls such things. Have been using my aliexpress claybar on the windows to remove all of the garbage left on them during the build, coming up nice. Have also been looking into sound options as that will make things a bit more pleasant in the cabin. Pretty raw, even with carpet, so looking to get a big ol' roll of deadening and laying that in places to quieten that up a bit. Sound wise, looking to put some components up front and amp them when money allows. I have a sub and amp from many years ago, but really don't know if I can be bothered installing that. So will see how the front speakers go and work from there. As part of cert I had to weld up the rear speaker holes in the parcel shelf. Didn't have to, but to keep the seatbelt anchorages in the rear shelf, they had to be filled, so that was my preferred option. I don't want to cut the rear panels to fit speakers. Box speakers to bolt on the shelf are silly money these days, so for now I have no interest in rear speakers. So yeah, front speakers are around the 4" mark from the factory, which isn't going to work. So I scanned my kick panels the other day and printed up some practice speaker rings. The idea being that i'll cut up a spare pair of panels and mount the printed parts (that won't be orange) to the kick panels and cut out in the inside. Currently has nice black panels installed, so they will be removed and put away for safe keeping. I'll then paint the spares, one of which is half brown half black, to be black. Will have a play with changing the angle of the speakers too, this first run was just to see if my theory was right. I was pretty sure while it was printing, that I had fucked something up as the profile of the ring did NOT look anything like the panel. It was though. So here are some pics, will update when road legal all going to plan. Panel to be scanned: Scan result, which I wasn't worried about accuracy so didn't bother scanning with my more accurate scanner, rough and ready will do the trick. Speaker ring, rough print as it's a concept print, not a final print to be used. Couple of photos of it on the panel, has the potential to make the install pretty neat and should look relatively factory IMO. /spent /fred for abuse advice:12 points
9 points
Alright so rather than trying to make this fit in a cramped space and get a compromised result. I'm gonna start with what I figure the ideal ram-air box would look like and I'll cut my spare bonnet around it. Then see what difference there is in a best case scenario. Will hook up a map sensor into the base of the airbox to see what sort of pressure gains are possible. Then if it works good, I'll try compare that best-case result to something that fits the car. So will have a base plate section that is 100mm radius around the throttles, and then 60mm long non tapered section (so this is high pressure zone) Then from here it's extruded with a 5 degree taper (may as well stay safely below maximum) Then a bellmouth on the entrance to try make sure flow stays attached. This thing will be absolutely monstrous, haha. About 525mm long so I cant print it all as one piece. However if I make the angle 6 degrees or 7 degrees then maybe it will be fine. The narrowest part of the slot has an area equivilent to an 80mm circle which is heaps. Could maybe go a little smaller. However I've also just assumed that the airflow direction will be perpendicular to the throttles which it wont be. Will go measure what sort of angle there is. then adjust it.9 points
so managed to get a little more advance out of it. another 5kw on the bottom end. power curve looking pretty sweet now. Rpm scale slightly off on this one. forgot change it when adding the stockish engine run (pink) Vs the 318/304 hvc cams, filled in the holes nicely. should drive heaps better. really nothing in it top end wise. Its even better than it looks on paper, since runs way nicer with the vvti and smaller cams9 points
Phew, that colour has a big range! Can’t wait to whack satin black on top. All in all it went well, got lots of crap in some parts and a water drip on last coat of last door..you always hope it comes out perfect but there’s a flat and buff in the future!8 points
Just for shits & giggles I acquired a 4x4 some years ago, which I dragged up to Hanmer Springs. Having tried wearing out the increasingly sad 2.7 ..... & failed so far its time to give it the setup I really wanted from the start. So, I obtained a factory flatdeck cos my pockets weren't deep enough to get 1 built specially & some of the aftermarket decks I didn't like how they are put together Yup, there's a catch, buy a deck & get the rest of it for free. Swap decks & sell again as a wellside. Apparently it's presold already, she with the battlescarred bitsamissin has now expressed an extreme interest to relieve me of this column shifted underpowered rolling roadblock6 points
I went for a drive with the new radiator setup. I dont have the radiator fully blanked off, but generally the radiator stays around 35-45 degrees when cruising at 100kph with no fan going. So doing some full throttle stuff, the engine temp still spiked even though radiator temp stays low. So that's interesting. Maybe the flow through the thermostat is the current bottleneck. After all its designed for 75hp maximum and tootling around at half that. I guess I can try take the thermostat out and see how it compares. The radiator temp did slowly creep up some time after a full throttle run, so ti will be a bit more punished with continous full throttle at a track day. But that's where finishing off the ducting will help.6 points
5 points
If you're not worried about cosmetics I'd leave it the way it is. A recently removed and refitted vin tag is much more of a red flag, they are not easy to make it look like they haven't been fiddled with once removed They are stuck on with adhesive so are easy to damage5 points
Made it through it's second certification relatively easy other than admin time. Missed a couple events I had planned to take it to but still went to the os drags. Best time was this 16.780. Before supercharger kit was 19.8 Was interested to beat a stock gz20 with a 1ggte Had one sketchy moment where a hose popped off the back of the head at the top end of third gear and the back stepped out but it corrected after I buttoned off. Put hose back on and tightened clamp and it was fine.5 points
Recently I decided that at some point next year I'd like to move this thing on. I never thought I would after wanting it for so long but I'd really like to track down an old supercustom or maybe even just pleb spec yh50/60 hiace with plans to 1gg swap. The liteace is a bit small for the family to enjoy especially since I changed it from 3 seats to 2 for engine clearance. This hasn't put a stop on mods at all. A custom winged sump has been made by a fellow OS member which should help get it on its guts again. A pair of bspeed cam covers are en route and I've also secured this bit of kit to test fit and see if it's viable It's an SK (sanyo-kiki) blow through carb turbo surge tank along with these early HKS cam gears I've sourced. I'd like to track down the hks cast turbo Manifold and some hks cams also. The shape of the plenum looks like it could be mounted upside down with elbow orientation moved and may clear the seat. If things get too messy I'll leave as is but it's worth a shot5 points
Now approaching 5000kms since being 4AG powered! I swapped out the 3.9 diff for the original 4.6 in anticipation for the OS drags and tool all tools and ply drawers for full race mode. My friend and i punched through 8 runs in the van and i did 8 runs in GX. Best time for van was 18.106 which my mate was able to grab. I actually feel like the 3.9 would have been better. We both felt there was an awkward place at 6-6.5k rpm in 4th just before the finish line where it was to close to shift into 5th where some taller gearing would have helped. However van ran flawlessly on the day and drove the 45 minutes each way before/afterm.5 points
5 points
I had a wof guy knock me back for a hard to read chassis number, I thought it was fine but his eyes must have had too much toe in or something. A clean and some black paint wiped into the stamping and we were all good.4 points
The VIN being painted is probably least of the worries (come WOF time) on that vehicle if masking it was too much work.3 points
It's a huge pain for cert. The correct, legal method for repainting an area with a vin number would be to take the vehicle to a place that deals in vin/compliance etc , they remove the tag and keep it in a safe place, you take the car home and do the paint etc, then once it's done 3 years later take it back to the same vin/compliance place who won't have changed inspectors/lost the tag/ gone out of business, and they refit the tag. In practice, this never happens because nobody knows about this until afterwards Then we have to send them to a vin/compliance place to get confirmation that it is the correct identifier for that vehicle, which can be easy, or a long involved process with forms and approvals from nzta3 points
Decided to do my own “over summer refresh” - I suspect it won’t be back together for some time, but I’ve made some progress. Have pulled everything apart, engine out, back to bare chassis minus the diff, brakes and a few bits Terminated everything on the wiring loom so it’s no longer just individual wire connectors, each gauge has its own plug which should make things easy if the dash ever has to come out again. There’s no doubt a better way to do it but I’ve enjoyed the process regardless, is good to actually understand how it works, even though it probably has similar complexity to the wiring loom found on a horse and cart… And yes all that blue wire should be purple for illumination on the gauges but I couldn’t find any purple in stock, so it’s blue. The connectors will go inside a waterproof box along with the main board. Tethered the whole loom to a board so I can map out everything properly this time. The loom itself was for a McGregor 7 and I never bothered to terminate anything at the right length- again I’m trying to do it properly this time. Fuse board had a crack in it so replaced that with one from burnsco. Once the engines back in I’ll fit it and check lengths etc before wrapping it up. Next step is to tidy up the chassis and remove any unnecessary brackets, weld up some holes. Maybe it’ll be back on the road by 2024…3 points
The rear brakes are more complicated due to the extra hand brake stuffs. The handle pulls a lever which pushes a pin down through the caliper and into a little freely-rotating bracket on the underside of the piston, forcing it down. No idea how common this method is. Bleh. Let's clean that up. Here's what it looks like all disassembled... not pictured is an extra retaining ring and a forgotten seal which is still inside the bore. The pin bearings also haven't been pressed out in this picture - one side's bearings were all rusted up and they cost $$$ for some reason so I hacked apart red's brakes. I fortunately was rewarded with another pair of good ones (and a pair of shit ones) for a total of four good bearings. Phew. As mentioned with the fronts, the rear pistons from the black car are fortunately in good condition and can be re-used So once again I went through the motions - except spread out over a month~: derusting solution overnight, a good scrub, let dry in the sun... ... fix the sandblaster, sandblast it all, rust preventative, caliper paint. We painted our house recently (still need to paint the garage) and I'm really over brushing things. But it's done - for now. Not pictured: I scrubbed all of the parts I was re-using in the parts cleaner, left in evaporust overnight, scrubbed again and they came out great. The aforementioned starion angel who gave me a bunch of rebuild link and advice pointed at these washers to replace the old crappy ones. They're slightly conical washers that provide resistance and springage for the brake lever. They're cheap so I grabbed a set (14 required to do both sides). Unfortunately they're a little chonkier than the originals Five will fit. Angelman went down this road and says he has no problems. However half of my original washers were perfect and after the evaporust the other half looked pretty good (red's ones were all trash), and should survive for a while covered in grease, so I decided to re-use them. Here's after the evaporust and before wire wheeling and greasing. Reassembly time! You can see the post-brush washers front and centre. Everything here has been slightly greased with brake grease. First I put the bore seals and pistons in with their boots. The rear boots have locking rings in place which I found extra scary. After a bunch of fiddling I got them in place and I think they seem to be operating fine - I tested with some compressed air. We'll see! For the hand brake stuff I will be following this guide by kev from the star quest forums as the manual calls for a special tool and press to squish the washers down for re-assembly, so there's a knack to it if you don't have it. The idea is to re-install the bearings in a particular order so that you have extra room to fiddle the arm into place. First bearing in on one side... The rebuild kit came with a new o-ring for the plunger so I put that on after greasing and placing all seven washers, then screwed it down into the piston and aligned it like thus: The key and spring then go into place. Now the bullshit starts. Put the other bearing on the lever arm and push it through, and use a screwdriver to push the key back. The problem we're overcoming is that the washers need to be pressed down to get the arm all the way through,. The idea is that with only one bearing in play, there should be plenty of angle to feed the arm through to it. In reality this is a massive pain in the arse; the arm still won't go in without pressing down somewhat on the washers and there's a lot of force required to do so. I'm not sure how but I managed to get it started with the first side. Then it's just a matter of pressing it home the rest of the way in the vise and locking it in place. However, the other side did not want to co-operate... so I found a much easier alternative. 1. Place the caliper in the vise such that the hand brake assembly is pressed up against one end. 2. Use your favourite chonkdriver to lever down on the arm; this is supremely easy to do thanks to l e v e r a g e. 3. With the arm lined up, give it a few taps with a mallet to get it started. Then pick up where you left off and press it home per above. Now I find myself in a greasy situation. A tiny sachet of brake grease is $20. I'd need many many sachets to fill up each caliper assembly per factory standard. The manual states which types of grease to use, but in an unhelpful way. "Orange" grease for much of the reassembly, and the hand brake area, and "pink" for some key spots. I couldn't find a translation for these on the net* but I'm guessing it's a combo of brake grease and then some kind of generic high temperature grease. (* something I'm picking up in the auto world is that everyone has an opinion on how something should be done right, and they get angry at the way other people do things and call them clueless muppets. However all of these people have functioning working cars so clearly it doesn't matter as much as these commenters wish it did) My compromise is to use a combo of a $20 sachet and the sachet the rebuild kit came with to fill the bearings and the cavity with the washers in it... ... and high temperature wheel bearing grease for the remainder of the space under the hat. This feels okay to me. The only mechanical action this area gets is when the hand brake lever is actuated. The part of the pin going into the piston is on the brake fluid side, no grease in that equation. And the wheel bearing grease is high temp so should be able to deal with the high brake caliper temps that make it to it. Then the hats get filled with more grease and snugged into place with the old retaining rings. I had some dramas with paint sneaking its way into the pin holes on the brackets but nothing a dremel couldn't clean out. Boom, rebuilt rear brake calipers! Nice to (a) tick these off, (b) clear my work bench and (c) delete this info from my brain ready for the next thing. There might be some more paint cleaning to do to fit little brackets and what not but calling this done for now.3 points
Probably a premature post on this considering I may not get started on it for a few months, but I did buy this off my mate a year ago and finally built a garage for it to go into last month so it was about time to pick it up! The day was an entertaining shambles from the start, one highlight was my winch crapping out so borrowed the boat winch.. then that popping off the trailer on the way home and went tumbling down the road. Amazingly it still works. Anyway, the car is safely tucked away in my garage.. some may recognise it as Ben’s old car originally. My mate has done a few little things in his 6 year ownership, notably putting on an Edelbrock manifold and Holley carb (I’ll find the details out later for reference), and buying a full exhaust for it which needs to be installed. Carb needs setting up also, it’s missing a spring for the kickdown, and I’m not sure what else needs doing but it’s not quite running right. Also installed a trans cooler, headers, some new shocks and bushes here and there. Barn find.. New home.. wish me luck2 points
Yeah it's running an electric pump, turned on full speed all the time. When the thermostat is out, it pushes water around like crazy. I dont think the pump itself is the issue, they use the same part number pump on the bigger hybrid motors too. Hmmm if it does fully open only by 95 deg then maybe it's not so bad, as it only got to 96. Will need to drive it for longer to see if that number keeps going up, so long as it's not over 100 then it's probably fine.2 points
I have done some testing regarding this, and at about the 20 year mark the adhesive doesn't offer much resistance. The main thing to pay attention to is the rivet spinning just as you break through the cap which will leave an obvious mark2 points
Managed to get it to start ok without putting a limiter in pulley. had to crack the throttles open quite a bit to let more air in. and messed with tune and cold start settings alot Only makes 70psi on compression tester when cranking. usually well over 250psi. can feel it blowing air back the throttles on compression stroke! so ive basically done the opposite of @Roman and turned my 4age into a prius engine. It actually idles best at full retard. like it has some weak little cams. The vvti is pretty slow it react. but 99% sure its just the oil feed line. i had to come off the oil pressure sensor hole. just used an an4 line had hanging around. will change to an6 see if fixes. Going to try get a little more advance out of it, piston to valve already pretty tight but, i'll gamble bending some valves for a little more, as it still gaining midrange with pulley maxed out. will also help with the prius engine issue. Good news is, its making good power on smaller cams. vvti setup is using 304/300 cams. Below is vs the 318/304 was running at os drags ignore the bump at end.. dyno being a diddle2 points
All set to Wipe everything down and apply paint! Front valence, rear endcaps and boot lid will go on the other side giving plenty of room to move.2 points
That will be for repair cert not lvv cert, LVVTA now runs the repair cert system. I believe they intend to run different rules for pre 90 vehicles, in an effort to help people who are restoring older cars as applying the same rules for an HQ holden and a 2020 kia does not make sense2 points
So yeah, where the fuck did that time go... Have been working on this a bit harder over the last few months, was supposed to be done before child number two arrived, but that never happened. Anyway, took it to local workshop a while back for them to tidy up quite a few loose ends that I just didn't have time to do. Had them check my timing belt job, set timing, tune what they could and put it through a WOF check. Funnily enough it didn't pass. The sheet was filled with many of the problems I had asked to be fixed lol... so they could have saved some ink and fixed my list first, but minor thing. So I got it back running a bit better, but on a knife edge between stalling when coming to a stop, or running on when shut off. I've fiddled with it so that I doesn't stall now, and will leave it at that. I have a rebuild kit for the carb, so at some point that will probably get fitted. For now it drives fine for cert etc, so it's down the list to do. Then I took it down for an alignment and made the technicians Friday well and truely, two hours later he was looking a bit out of patience haha. But I now had a failed WOF sheet and an alignment sheet. So it was time to book it in for initial cert check. Turns out they are busy chaps as the estimated 3-4 weeks turned into 7 weeks away. To be fair, it was a good few weeks between calls as I wanted to do WOF / alignment before booking as didn't want there to be any surprises. So 6 weeks later and with a week till check, I figured I better check everything was ready to go. Nope, carb had decided to play up quite a bit since it had been parked up. The battery I purchased to get the car shipped down had finally had enough so it was off to SCA to get a new one. Didn't fix the carb, but it sure made the time between firing it up and fiddling less than the battery charge it needed each time. Battery was always on the list as well as a full tank of gas, don't want to be that guy when dropping the car for cert. So anyway, dropped it in a week ago and it came back with a few things to sort. Nothing too major. Rear seatbelt mounts didn't exist they were just drilled through a single skin at compliance. So that was one item to sort, what a nightmare too, so little space to work with. Ended up laying in the boot for a few hours getting them to fit nicely. Suspension travel was not adequate in back, so I have sorted that now hopefully. Gained quite a bit of travel, while still meeting all of the cert requirements. Wasn't sure i'd be able to get it done with my springs, but certifier and Clint both had ideas to help with that. So got that sorted and gained around 30mm travel. Wheel studs up front slightly too short. I set myself up with this one as I had been using factory nuts for all my testing of turns etc. Then put on some nicer ones I didn't check the engagement, it's less of course. So hit up Mark at Toyota as 2+ years ago he had sent me a photo of the wheel stud options in case I needed new ones. They arrived next day, so they are on my list to fit now. Of all the jobs on the list, they are the easiest, so they will be done last. That was the list to rectify, along with sorting the exhaust to not hit the car. Exhaust wasn't too bad, but I had the front joint fixed and that involved them jamming the exhaust against the trans. So I pie cut the exhaust at the trans and rewelded it bent down. this lead to problems further down the exhaust where it hit a crossmember just above the diff. So I grabbed a mount from SCA on the weekend and welded a dropper from that to the exhaust. I have plenty of support stopping the exhaust from dropping, just none from stopping it heading upwards. Wasn't really on my radar at the time, but with it being lowered and a lot firmer than factory, something had to give. So that's all fitted now and so it's rubber on rubber with minimal distance for that travel. So it shouldn't stressed the rest of the exhaust, and it stops all noises. Sorting the suspension took me probably 1.5 days of solid head scratching and removing and reinstalling most of the rear end with small adjustments. Such a PITA with the limited space I have. I also wasted a lot of time forgetting to include droop in my travel calculations. Was getting pretty hard to get decent travel till I remembered that counts, duh. Some pics. Filling it up with the good stuff Studs that need to go in, as well as working out plate area vs the space I have to fit them. Got it sorted, trimmed them a bit, while staying within the requirements, zinc'd then painted. Still well and truely have the clamping area I need after being trimmed (not shown). They will be bolted into the car with 5mm bolts, one of which will pass through a sheetmetal packer. I'll then use the provided rivets to finish securing the packer between the plates and jobs done. Gave this side another tickle, I didn't want to fuck with the exterior look of the fenders on the car, front or rear. So that meant I needed to get as much space as I could on the inside. Rear is nice and easy to add clearance without compromising anything. Will give it all a paint up as some flaked off the inside. Don't want any rust forming in the now formed channel, so will sort that out too. Thankfully there were two threaded holes in the car above exhaust. So I cut some steel and made a solid as fuck bracket to bolt to the car. Then bend up some round bar and curved it around the exhaust. Zap zap later and with some molten steel in my armpit I was done. It's not supporting any weight in this setup, it only prevents or at least reduces greatly, the rate at which the exhaust can travel upwards. I had both ends of the mount enter it from opposite sites with the hope this will prevent it being able to physically come apart. Seemed to work in my head, time will tell. Didn't want to weld caps on the ends as it would make removing the mount impossible later. To remove it now you have to unbolt it from the car to slide it off the exhaust. And hopefully how it will sit when finished. So I now have till the end of this month to tidy up all of the list, when i'll drop it back in for recheck. Pretty sure I have all of the things sorted after speaking with certifier today. It's basically as low as I can get it with the 15x7s in this offset, with factory fenders and sufficient suspension travel. It's been 4 years of mostly struggles to get to this point, so the weight on my shoulders is finally starting to lift. That's all folks.2 points
After spending quite some time reading posts of other people's vehicles - I figured it was time that I got my shit together and posted my rusty junk up for the world to see. After developing an unhealthy penchant for 1969 - 1970 Toyota Crown's some time back, I have seemingly added a hobby to the list of hobbies - collecting Crowns. As was told to me after finding my first - 'You can't have just one!' - the collection has grown. The latest, being this RS56 Ute.... This old girl is the latest addition to the fleet, which currently comprises of 1 x MS55 Sedan and 2 x MS51 coupes (separate threads to be generated for those at a later date.....) Anyways. I get a message from a guy I have bought from before, and the conversation basically went like this; Him: 'Want to buy a Crown Ute?' Me: 'Yes'. It was made known up front that the vehicle was pretty rough, and that a sedan 'half cut' was available at a reasonable extra cost to support with rust repairs. And so it was done. Photos were sent after the agreement was made which did little to curb my enthusiasm. All collected one slightly miserable weekend. Stoked as. Of all the Crown shapes, the 50 series really do it for me. Of all the 50 series body types - the ute really gets me rigid. Once I got it home (and made some space in the shed) it didn't take long to work out just what shape it was in.... Uhhhhhhhh...................... Oh well. I sorta knew what I was getting myself into - so carried on regardless. All in all, the front half of the cabin is..... garbage. But that's why I purchased the front cut of the sedan. Beers were had, and plans formulated. *EDIT* Page of discussion here:1 point
Does the rest of the car look dodgy ? If you've take it off and painted the area and reattached with rivets in a tidy fashion. Why would it look dodgy. If it was a hectic r32 skyline going to vtnz you might have issues. But for most normal people with older cars going to a regular inspection place it's never going to be an issue1 point
Does it matter that, that might remove the black printing on it. Because that seems like defacing or altering it too1 point
It could be considered c) altered, or d) defaced, or e) obscured, End of the day it’s up to the inspector’s discretion. I would give it a lick of paint stripper to remove any doubt.1 point
I've been pondering what to do on the Muzzy from a fuelling point of view for a few months now. Allow me to set the scene: A previous owner had fitted a brand-new Holley 600 4-barrel carby to the mighty 289 small block. Although the car runs really well, it can be a bit "fumey". Chatting to a couple of folk more knowledgeable than myself, the general consensus was that she was over fuelled. This was supported by the fact that the car cold starts easy as with absolutely no choke required. Another clue is the fact that after a short drive with the windows down I smell like I've just been out mowing the lawn. Whilst "eau de unleaded" may appeal to some, it gets a bit tiresome after a while. Anyhoo, supplied with the car was the original 2-barrel intake manifold as well as two old carbs, a 2 barrel Holley and an old Autolite. Both look pretty manky and would need a full refurb. I'm not really keen to go back to a 2-barrel, so I discarded that option. My next thought was to look out for a Holley 465, but they are getting hard to find and are also pretty spendy. I tracked down a family run performance shop down in Victoria who specialise in refurbing old carbs and they were offering a reco'ed and bench run 465 without me having to supply a core unit for just under $900 delivered to me in Queensland. So again not exactly cheap. Now back in the day when I was playing around with my V8 powered Bedford van I ended up trying and discarding 3 different carbies before I was happy. First up was a Quickfuel, then a Holley and finally a refurbed Rochester Quadrajet. With the cost of each carby plus a few dyno tunes thrown in for good measure the spend was getting up there. I was never 100% happy with the van as even with the Rochy it guzzled the juice and at one point I even toyed with fitting EFI, but at that time the cost of off the shelf EFI kits was pretty eye watering. So, getting back to the Muzzy I decided that a bit more research was needed before pulling the trigger on the carby. Spent many a night with my good friend Google and Youtube. Even pestered a few USA based Mustang gurus for their advice and eventually ended up setting my sights on the Fitech EFI. Now it just so happens that my local Autobarn is a Fitech stockist and earlier in the week I dropped by and saw that they had one Fitech Master Kit in stock. Today they were having a 25% off Boxing Day sale so first thing this morning Mrs Flash, our wee dug and myself hopped into our trusty old Bongo van and headed through to town. Got there 10 minutes before store opening and I was second through the door. Literally bowled over the poor shop assistant to get my hands on the kit, but get it I did. This is my first foray into the land of aftermarket EFI, so I am on a steep learning curve. Let the fun commence.1 point
This brings us up to date. I'm just waiting for the top and bottom of the notch to be folded up then I'll get it welded in. Also moved fuel tank to the back of the chassis it fits surprisingly well so I think I will use it there but just move it bit further forward once notch is done and another crossmember is added.1 point
I stripped the ring gear off the stock open front diff and installed it with some new bearings onto a quaife torsen lsd. Lots of guys on the SAU forums rate it as the best mod to their GTRs. @Bistro came round for a few beers and gave me a hand to install the adapter plate and test fit the sump. Had to come off again as there was a bit of extra clearance required on some of the adapter plate bolt holes Its all on now, and i fitted all of the diff parts with new bearings and seals everywhere. I jumped ahead a bit and fitted the pinion seal before i measure the end float so that might have to come off again. Fingers crossed its ok. I got the crown wheel backlash perfect at 0.15mm. spec is .13 - .18 Pretty happy with that. Need to paint the gears next and hopefully the pinion is ok and i can seal it up. Its a prick of a thing to fit the diff in so im hoping it does not need to come back out again. The hardest part is waiting for parts. I can buy all the seals and shims i need, but they are usually 3 weeks from overseas. Once the head comes back i can fit that and do some plumbing and fit it back in the car. I might do the transfer case next. Maybe overhaul the gearbox.... Its a slippery slope1 point
Merry Christmas Oldschoolers! Sadly i got covid 3 days before christmas so im spending it on my lonesome. But on a positive note me and a friend filmed this music video for another friend! Featuring Celica!1 point
Well I was super happy about having a list and I loved the excessive noise… that’s because I cut out the muffler cause it had holes in it .so I went about putting a new muffler on and adjusted lights replaced lower control arm even though it was brand new but was rubber and had excessive play which they showed me so I cut the rubber bush out of it and replaced it with a Nolythane bush out of the old one I had and that seemed to make the caster much better got a new rack end for the steering rack and finished other jobs took it for retest and pow I got a WOF and then Registration so I’m on the road for summer ……… so happy so after 3 years it’s legal again of course there’s still bits and pieces to do but in the meantime I’ll just enjoy1 point
Mini update - I managed to SWAP my bench front seat for some averagely retrimmed bucket seats that appear to be mk4 zodiac ones Here they are mocked up in the car as I’m yet to have the centre bracket welded in. $1000 later, a full set of short Koni shocks are en route and I’m getting close to having the rear leaves reset 4” and removing 2” the blocks. I’m hoping the same place can reset my front springs 1” but that’s a 2023 problem. wrx type r sold yesterday so now I can relax for a bit and focus on this build. front and rear seat retrimming is $2400 via Tinwald canvas and upholstery Ashburton. I will get this done in the coming year along with new interior everything. They have the patterns and it’s a pretty basic replication job. They will be XYGT/GS spec trim. still after the lid for the dickie seat too (any colour)1 point
Took the mazdawg on its first major outing yesterday with a buddy I met up with Cambridge on the way Destination was @hoods place in Rotorua. Got burgers and went to the lake. Dog got treats and splashed around in a new environment so she was happy. Stopped at Karapiro for a bit on the way back. Truck ran like a top. Only issue was its fuckin gutless. It cruises sweet, but nothing home when ya stomp the loud pedal. Been a while since I have driven one so figured thats all it had to offer, but whilst stopped in Karapiro I did some checks. Felt like secondary throttle wasn't opening. Sure enough, accel pedal gets full dort on carb, but only off the primary. Might have a linkage missing. Will figure out this weekend, but other than that it was a great shakedown cruise for it. Bloody road closures on the way back added an hour to the trip so that sucked.1 point
Big thrash last couple days to get it Cert ready. Couple big things were the bumpstops. Front was easy enough as I had a pair of suitably sized rubber ones that did the trick. Rears were a bit trickier due to the notch. Needed to lessen the distance between bottom of C-notch and the top of bumpstop, to make them work before the shocks bottom out. Ended up making what resembles a model of the Harbour Bridge. I could have just welded something in, but wanted it removable incase I needed to tweak them.1 point
After getting the booster vac hose fitted I took it for a quick hoon on Friday night. Goes decent, needs a bit of carb barrying. Brakes work fucking awesome which I'm stoked about. Had a bit of an issue with the cam blanking seal at back of head. It fell oit somewhere when we where going round the block and it pissed oil all over the gearbox and my floor. Had a spare so pushed it into place. Maybe there was meant to be a retainer plate that I didn't fit way back when I assembled engine. Theres 2 bolt holes either side of it, so will take plug back out, glue it in, then make a retainer plate to hold it. My buddy Adam came over on Saturday and whipped out his buff. Got rid of the last of the chalkyness on the cab and doors, then gave the rest a quick run over. Big effort from him, farkin legend.1 point
