All Activity
- Past hour
Also, where did you get that sweet carb tray?
- Today
VjiupsLip joined the community
Hey guys I'm from the big smoke and working out how to collect a part from new Plymouth pick a part. The part in question is a silly part but fairly hard to come by. It's a pre facelift honda logo rear boot spoiler. If anyone is going there could grab it and I'll pay for it and pay for your help. Any help would be appreciated
Parrotts. They had an in-ground roller setup which I think was usable powered or car driven. Don't know if they moved it when they shifted premises. As the business changed hands at the time.
Thousand Dollar Supercar's 1988 Jaguar XJ-S 3.6
VitesseEFI replied to Thousand Dollar Supercar's topic in Project Discussion
This!! Injectors!! -
!!!!!!Hanmeet 2024 23rd-25th August - Entry Form is up now!!!!
RUNAMUCK replied to JustHarry's topic in South Island Region
Fingers crossed for a quality sharn over a cold one mate! (One of my highlights from Marahau nats was the quality discussions rolling over the Takaka hill, feeling like a US president no less) -
When rucs come in for all, Fitting a KPH faceplate to an MPH speedo (where both options existed for the same dial) would be stealing from the government, and the thought has never once not crossed my mind........
Place in christchurch had a machine that would count the turns while the the vehicle was driven a mile/km.
Hadn't really done much with this. Mostly because it was just rubbish to drive. Bit the bullet and got stuck into doing an engine transplant. Brought a well used ms123 crown for the running gear. Gave the engine a paint job rebuild and proceeded to fit it into the coupe. For the most part it bolted in. Had to modify the crossmember and make a new driveshaft as the transmissions are a different length. Lots of small things need modifying as the coupes engine bay is about 100mm narrower and a 100mm shorter then the doner crown. Biggest battle was getting the wiring loom intergrated into the existing car loom, definitely not one of my strong points but muddled my way through. Replaced the steering box with a new one I got off yahoo,so stoked, made all the difference to the feel of how it drives. Happy days
vivaspeed replied to KKtrips's topic in Lower North Island Region
I hope it hasn’t changed since 1994 when I last went… I’ll be there. -
ill come if i can get a ride down in a Mazda
Company ute
As expected something shat itself, I would have been incredibly surprised had my *stress testing* over the weekend not opened a few cracks. It turns out that the occasional non start I had been experiencing was not the battery going flat, but the starter not playing the game. I pulled it tonight, the starter that is, and it spun up no problem on the bench but less so firing it with the solenoid. But the solenoid was clunking so it must be the contactor. Shortly afterwards some crispy was uncovered; I cleaned those contacts up, soldered it back together and reassembled, then had the old girl firing into life shortly afterwards. Nice. I have also had the weird situation where the resting voltage of the battery(s) after a run has been over 13v. I suspect the alternator might be overcharging but when I had it running I was seeing 14v at about 3000 revs. This is kindof weird anyway as the alt light does not come on, which is either a poor connection or blown lamp, but this also has an LED not an incandescent fitted, and I now know that theoretically this isn't enough to excite the alt anyway. It was on my list to fix when I got a chance, so I will investigate. Obviously I'll do more testing about the charging, including fitting the voltmeter I have ordered.
You seem to be missing all of the mercedes diesels. Also curious as to why you wouldn't consider common rail diesels, they are better in every way? just fyi om648 fits mint in a chev truck.
Yeah, NP I think. I don't really need barry level, just an adjustment on the speedo indication
Is that the new plymouth jokers? They are down the street from work. We have had mostly good results from them at work. Have used Robinson instruments with success also. Seem like knowledgeable barries with poor website skillz
Finally got a new alternator, an Aeroflow AF4273-1100 100A I'll be hooking this up '3-wire' which uses the warning light as an exciter and removing the stock external regulator. This gives me more ergs for upgrades later and the 3-wire hookup apparently makes it come on charge quicker. I may need to check the warning light later to see if it has a bypass resistor as without this the alternator will fail to come online if the bulb is blown. I was originally going to use the stock wiring but decided to bin it as it was untidy and would not carry enough current if I start to draw more than the stock power. The car also does not have alternator or battery fuses so I might add them later too but I want to work out a tidy install before I do that. I got it wired up on the bench and then looked at the car. First I took out the old regulator so I could work out what wires to remove They were buried in the main loom and used a wired molded plastic thingo you can just see in the last photo. Pain in the arse as I couldn't separate the wires without cutting this off. The loom was wire spaghetti so I also removed all of the wires from the started solenoid which is pretty much used as a positive terminal for everything. the wires I have are Black and yellow - power supply to fuse box Yellow - ammeter red - ammeter Red and blue - Starter switch Brown - odd extra wire to the solenoid that shorts it out. Was disconnected but can't quite work out what it does. Something to do with the coil and starting but not needed Black and red - ? Orange - regulator (removed) I could have thing wrong, the info online is a bit iffy and it changes with the year. I think the red/green wire from the regulator is the warning light but I can't confirm that. Might need a battery and a spare pair of eyes.
Kiwibirdman replied to Thousand Dollar Supercar's topic in Project Discussion
I would start off with that new fuel filter, you may have sucked in a bunch of crap from the tank. If that is OK fuel pressure would be the place to look. The connection to the vacuum source is to help regulate pressure correctly when the vacuum is high. -
Another go at the fueling realised had base pressure wrong when I calculated it.... Re ran the calculation made very little difference to ms/g like 01ms so fudged it bumped it down 5ms. While i was In there I toggled off the EGR and set it run off a single narrowband sensor which I think I'll re fit next to the wideband as it's only 12 months old and car runs nice on these. Started up no longer stinks of fuel and started much easier. Now to let the car get up to temp and let the trims sort the rest out think im in ball park now. Also figured out a definition file glitch which was stopping me reading data on Tunerpro could flash in fine but information coming in was wildly inaccurate 28000rpm 1200c on inlet air temp. Pft
Only a Morrie, don't mention the hills
hope the car u gunna make her push, isnt too heavy
Thanks, talked to Auto Instrument Services who our mechanic suggested. I need to count the speedo cable turns while pushing the car 50 meters, wif is going to love helping with that,
Early jap nuter replied to Roman's topic in Tech Talk
Haven’t used them in 8 years but they they had a fast turn around and good price, they were really good at the digital speedos like in the soarers -
Shaz replied to KKtrips's topic in Lower North Island Region
This sounds terrible. Count me in!
