Gee
Gee last won the day on March 2 2024
Gee had the most liked content!
    Auckland
Gee's Achievements
Advanced Member
Advanced Member (3/5)
805
  1. Thanks mate.
  2. Got my seats back from the upholsterer, look a bit better now The rear seat back went in fine but the lower sits too high. It was always like that but I kind of hoped they'd see a problem and fix it. Might need some wire manipulation some time Can't tell unless you sit in it though Fronts were a lot more work. The rails slide independently when not fitted to the car so I thought they were not fitted correctly till I figured it out. Bit of a prick to line up through the carpet too Looks pretty mint now though and much more supportive.
  3. With the seats out I wanted to use the chance to add some more Dynamat. Pealing the carpet back is easy enough but I was a bit lazy and didn't remove the seatbelts which may have been a mistake. Got pristine 1960's Brittany blue under here, aways nice to see. Now to cover it up and never see it again. I left some gaps where the seat rails go just to make it easier. Underlay back in. not sure when this was first put in but it is in reasonable condition Then the carpet back. It is quite wrinkled due to the abuse of pulling it back. I'll have to give it a bit of a roll out before I put the seats back in. An in automotive archeology news, I found another durry under the carpet. Some previous owner must have had a habit.
  4. Finally got around to pulling the seats out. It's a bit of a pest as the floor is double skinned so you need a 1/2" long reach socket. Not a 5/8" the internet says, strange as google knows everything. Have to pop some very old bungs out too. I could get new ones but I think they'll do a few more years. Bolt is right up there and once 3 are out the whole seat moves making it a pig to keep on the last one. 4 nuts and bungs out. One of these things is not like the other one. Seats look really good unless you look closely. What's the problem? Oh, that.. Seat foam is toast too and a previous owner had jammed some foam in there to prop it up so will be good to get some comfort back. Car is a bit empty without the seats too. Might take the opportunity to throw some more dynamat under the seat base while I'm at it. Oh, and give it a vacuum.
  5. Cruised down to the hop, a day later than planned but managed to avoid the water. I did pick up a stone chip and crack that was rapidly moving up the middle of the windscreen so we had to make a pitstop in Paeroa for a repair. Tried to get a picture but it didn't show very well. Great service at Secure Glass Paeroa. Stop drilled the crack and managed to fill it mostly. Only charged $50 (normally $90) as he couldn't guarantee it and also gave me advice on the road closures. Stopped at the Waikino Tavern to wait for the roads to clear. Great place and I rate the local gin. Also chatted to the guys driving this cool Model A. Small block Ford and Jag rear end. Saw a really nice 67 fastback that I think was Brittany Blue, my original colour. Had a nice set of Classic Instruments gauges, 5 speed, and Baer Brakes but otherwise a fairly stock looking build. I'll just leave that here for inspiration. Mine ran well with the tune doing what it was supposed to except for one stumble leaving me stuck at the Bombay BP intersection and a light that didn't change for the next 10 minutes. Was hard to restart, possibly due to underbody temps, but ran fine after that.
  6. Road testing the carb changes showed the needle change made more of a difference than I thought. Drivability was the same but AFR sat on 13-14 in cruise. Nice having a temp gauge that works too. Was bloody hot but engine temps sat in the middle which I assume is good.
  7. Got into the carb tuning. Haven't tested but it was an easy swap as I just changed metering rods. The chart below is for a 1403/1404 carb. Position 1 is stock 1....................1423 (.086")............................1460 (.065" x .052") ..............................none - stock calibration I wanted to go one step leaner in power and cruise which on the chart is position 6 6....................1423 (.086")............................1463 (.067" x .055") ..............................Rod This means only a rod change with a 1463 rod. First step is to undo the torx fasteners, no need to remove the cover, it just swivels out of the way. I put rags down the throat of the carb to catch anything I might drop but one moved just as my torx bit fell out of the driver. Luckily it was caught on the booster venturi and I could grab it with a magnet. The numbers are hard to read but the needle was a P/N 1460 (labelled 65 62). The piston holds the step up spring which is left in the carb and the rod is held in by a tiny spring so a bit fiddly to remove. The new one was selected and fitted and all put back together. Just need a road test now to see if it worked or if another change is required, the next step is the stock rod but a different jet. Springs and rods are easy but I'm not sure about jets. I don't know how you get them down the hole and lined up so hopefully my change is all that is needed.
  8. The AFR gauge looks a little better now. I'm not showing a picture under the dash, it's embarrassing. The gauge comes pre-terminated which makes installation really easy for a novice but leaves heaps of extra cable you don't need. The cheap plugs on it are not easy to replace so there is a big loop to hide out of the way.
  9. Thanks. I assumed the value is a bit iffy at idle, especially cold as it is borderline useless jumping around and quite lumpy. I have no idea what cam is in it so can't say if that is having an impact but the idle is the one area that has been tuned. My auto sparky tuned the idle when swapping the dizzy for me and had a bit of trouble. I took it in as the idle was quite high, confirmed on my multimeter. The adjusted it and set the timing but said they couldn't get it to idle low, they said due to the cam. This was done old school, I assume, where you adjust the throttle screw down and then adjust the mixture so in theory the idle will be the leanest that can maintain an idle. It is quite rich, and the dyno confirmed that too, but it does not foul plugs so should not be too hard (hopefully) to lean out a few points even for a novice.
  10. Did some boring maintenance stuff: Replaced the crunchy radiator hoses. I never liked the braided cover on the top hose either, it achieves nothing and keeps pricking my fingers any time I get near it. Got some new OEM stuff which looks a lot nicer and nice and soft. Easier to fit than I thought but the lower hose clamps were a bit of a FAF. Topped it up with 5l of coolant and water, should end up 50:50 but I will need to check it after a drive. I don't think I got it up to temp in the driveway, it does take a bit of time so I'll need to drive it and make sure it gets all the air out. At least I have a working gauge now so I can keep an eye on it.
  11. I got a we delivery from the Mustang Centre. I have been chasing the temp gauge for a while and worked out previously that the sender was the wrong resistance value to indicate on the gauge so I had to hunt around for the correct one, harder that I would have thought. While I was at it I ordered some other bits to make the postage worth it. The sender is an easy swap but I did have to give the crimp a wee squeeze. I also swapped in a new air filter. I thought that was a good idea since it was probably quite a few years old. It was a bit of a pain. But old and new are 3" but I had to wind out the filter stud in the carb to get the nut to engage. Lucky it has a wee lock nut to tighten it in unlike others I have had which I needed to cut down some threaded rod. I took it for a drive and got a satisfying indication on the gauge. Previously it hardly moved past the C line. It even went up after shutting down which is a good indicator it is accurate enough as the temp would rise with no water pump or fan operating. Drop as soon as the engine starts again and water flows.
  12. Cruised to Coffee and Cars at the Auckland Showgrounds today and then afterwards headed east to Buckland Beach. Bloody hot in the car but nice with all the windows down. AFR sits a surprisingly lean 13-14 at idle and around 12ish cruising and back to 13-14 off throttle. Not terrible but could be better. Bit dodgy looking down at the gauge so will have to sort something out to hang it.
  13. I found an AEM AFR gauge at NZ Air Filter. I thought I'd give it a go as a science experiment. I had the O2 bung so I could fit the WB sensor easily I thought the angle was a bit odd as it faces the outside of the car but I think the exhaust shop chose this to follow the speedo cable so I zip tied it to that. I managed to keep plenty of clearance to the headers. I had to split the grommet to feed the wiring through but someone had already fed a dodgy grey wire around the grommet so it ended up being an improvement. The wiring under the dash is a 50 year old mess and the stereo install is just ok but I managed to tee into the switched power for that which should give me fused power. I need to get a gauge bracket of some description but it works Ignore the numbers, it fluctuates like mad at idle but settles in once the revs come up. I assume the pulses mess it up. Not sure if I can set a filter to slow it down.
  14. Thanks. The chepos do have narrowband sensors as far as I can see. I have a WB sensor as long as the gauge can be connected to the same plug, where did you get the gauge? BTW, the chat thread is here:
  15. Yeah thanks. I probably read that ages ago. I downloaded the manual and the tuning kit is around $150ish I think. I assume you road tuned it? My engine builder wan't keen on Edelbrock carbs, I assume he is a Holley guy, but the more I read the more interested I am in Edelbrock. For a crusier I think they are actually better. I blew the power valve out of my Holley street avenger.
