kpr 6,496 Posted March 30 Author Report Share Posted March 30 Yeah its pretty hard to find any clear results on the port filling thing. then there is pretty much anyone with "high power" / "atlantic" 4age's. that never show their dyno results. all the ones ive found are dead in midrange. I have played with the idea of straightening out the ports by cutting the port back and raising the roof up. but really cant go high/ deep enough into port, before breaking out into the valvetrain area. to get much advantage. 1 Quote Link to post Share on other sites
xsspeed 18,420 Posted March 30 Report Share Posted March 30 cast a new head 3 Quote Link to post Share on other sites
thegreatestben 2,695 Posted March 30 Report Share Posted March 30 4AFE 2 Quote Link to post Share on other sites
kpr 6,496 Posted April 2 Author Report Share Posted April 2 As i suspected answer is: c) wont do shit green no bits in port. pink bits in port Run with my smallport 47mm itb setup 2 1 1 Quote Link to post Share on other sites
Roman 14,397 Posted April 2 Report Share Posted April 2 Its amazing for what a drastic change has been made, how it makes almost zero difference! Quote Link to post Share on other sites
kpr 6,496 Posted April 2 Author Report Share Posted April 2 Yup. and i take back all the horrible things i said about bigport head. Its almost making the same power as smallport head, when they both have a decent intake manifold setup. 4 Quote Link to post Share on other sites
ajg193 9,640 Posted April 3 Report Share Posted April 3 Restriction must be on the other side of the intake valve now? How much difference do they have in the combustion chambers? Quote Link to post Share on other sites
kpr 6,496 Posted April 3 Author Report Share Posted April 3 small vs bigport? stock there is no difference in chambers. only thing that's different is the intake ports themselves. From the port divider onwards the early bigport head (head on engine now) actually has the smallest ports out of all of them. the choke area is smaller than smallport head. The smallport head im comparing it to has had some work done in chambers and exhaust ports. not much on intake side. 1 Quote Link to post Share on other sites
kpr 6,496 Posted April 3 Author Report Share Posted April 3 Single handedly devaluing smallport heads. so i can afford to buy one.... 9 Quote Link to post Share on other sites
kpr 6,496 Posted April 5 Author Report Share Posted April 5 Soo, turns out the tvis wasn't opening all the way. thought results seemed weird... vid has been fixed and reuploaded / heres the graph. 3 Quote Link to post Share on other sites
Testament 8,496 Posted April 7 Report Share Posted April 7 so governing restriction is the intake valve opening/curtain area rather than the ports smallest cross section? more cam lift or bigger valves needed to max out port flow? Quote Link to post Share on other sites
kpr 6,496 Posted April 7 Author Report Share Posted April 7 Port shape seems to be the difference between them. smallport best shape most power. early bigport 2nd best. worst is the late bigport. I just finished testing the one @kyteler sent me. its a few kw down on the early head in the top end. both with stock intake and itb's. It has the biggest ports all the way to valve out of them all, also has a shitty short turn radius. So yeh, thats why redtop bigport is such a turd. Not sure why mr toyota made the later heads worse, maybe the engineer behind it was like screw this fwd junk 2 Quote Link to post Share on other sites
mjrstar 2,964 Posted April 7 Report Share Posted April 7 6 hours ago, Testament said: so governing restriction is the intake valve opening/curtain area rather than the ports smallest cross section? more cam lift or bigger valves needed to max out port flow? I think someone in Australia did a bunch of work years ago on the old 1ggte cylinder head including cross sectional surgery.. Basically the outcome was the port area yielded next to no gain, small gains at the valve guide transition area, but it was really livened up once some larger valves were added to the equation.. I'm not sure if the same rings true of the 4age, although they would be of a similar Era to a boat anchor 1ggte so maybe the same dude from yamaha/ Toyota in Japan penciled down the initial design? Quote Link to post Share on other sites
Spencer 22,721 Posted April 7 Report Share Posted April 7 Yes I have heard many a barry yarn that they need bigger valves, not sure but didn't think there is much room for that carry on. Quote Link to post Share on other sites
mjrstar 2,964 Posted April 7 Report Share Posted April 7 14 minutes ago, Spencer said: Yes I have heard many a barry yarn that they need bigger valves, not sure but didn't think there is much room for that carry on. Yeah possibly not, if only there was some means of forcing air in there a bit faster, perhaps under pressure. 3 Quote Link to post Share on other sites
Popular Post cletus 40,367 Posted April 7 Popular Post Report Share Posted April 7 or perhaps adding an extra intake valve? 5 per cylinder for a total of 20 valves 4 3 3 1 Quote Link to post Share on other sites
Valiant 42,021 Posted April 7 Report Share Posted April 7 Why not both! Quote Link to post Share on other sites
kpr 6,496 Posted April 7 Author Report Share Posted April 7 1 hour ago, cletus said: or perhaps adding an extra intake valve? 5 per cylinder for a total of 20 valves Wash your mouth out with that 20v talk. 1 hour ago, mjrstar said: Yeah possibly not, if only there was some means of forcing air in there a bit faster, perhaps under pressure. same for that turbo talk From memory the 1g valves are really small. 4age isn't too bad but can go bigger. which requires new seats installed, so starts to get spendy. but yeah both oversize ports. I find it amusing how its the total opposite of what people think. bigport will be good for more top end power.. 1 2 Quote Link to post Share on other sites
UTERUS 18,999 Posted April 7 Report Share Posted April 7 2 hours ago, mjrstar said: Yeah possibly not, if only there was some means of forcing air in there a bit faster, perhaps under pressure. LPG? So keen to see petrol vs lpg. 16V vs 20V. More vacuum cleaner oil separator 4 Quote Link to post Share on other sites
Alfashark 91,519 Posted April 7 Report Share Posted April 7 8 minutes ago, Valiant said: Why not both! 2 Quote Link to post Share on other sites
