Otodat Posted November 10, 2019 Share Posted November 10, 2019 Welder review- for anyone interested. Ended up getting a weldtech 4015mp from an outfit in Christchurch and it turned up three days later. Had been meaning to get a 15A plug sorted out but new toy, so couldn’t wait. This is a multi process machine that does stick welder, plasma cutter and tig. Big part of getting this is the days of chucking the old young model b (pictured below) in the back of the wagon when I needed to weld something out of the workshop are fading. This thing is so light in comparison, and having a plasma cutter has been on my wish list for some years. First job was cutting out some new tilt linkages for the hedgecutter out of 10mm plate. It seemed to be approaching the limit of its capabilities as a plasma. It might be something to do with the way I’m using it (ie operator error) but I found it impossible to keep a straight cut. In the end I cut the shape slightly wider and ground the cut after to tidy it up. Was fairly slow cutting but this thing has a neat function where you can start it by depressing the trigger once and it will stay on until you lift the hand piece. After this I tried it on some 6mm plate and it cut through like butter, clean and fast. It works good enough for what I want to do, hopefully get better with practice. Next I tried out the welding function on some 10mm off cuts. Oh man, so freaking awesome, so smooth and heaps of grunt. Unfortunately at this point the 70 year old electrics in the workshop decided maybe to much grunt and the lights went out, which revealed around six power outlets in the shed were powered by a short extension cord near the toilet with going out one outlet then in another. so that’s all good, needed to get an electrician anyways. A week later some cracks started to appear on the head of the hedgecutter so threw the welder in the wagon the next morning. I was a bit dubious about hooking off the power from the farmers shed, running out a long extension lead and welding some fairly thick steel. I set the welder on 95 amps with some 3.2 rods and went at it. Job done-no problems. Pretty stoked, yeah it’s not weld porn but the thing stopped falling in half at least. In conclusion- this thing is pretty sweet. As a welder it’s probably the best one I’ve used. As a plasma it does what is says, but 10mm is definitely its upper limit. I’ve never done any tig welding before, for me it would have been absolutely ideal if it could be used as a mig. I asked the supplier before I got it if a spool gun type setup could be used on it, which would be adequate for my use, but they said it couldn’t be done. Bit of a shame. I may give the tig part a try one day when I have time just to satisfy my curiosity. At this stage would recommend to anyone looking for this type of machine. Hopefully it stands the test of time. 3 Quote Link to comment Share on other sites More sharing options...
SOHC Posted December 14, 2019 Share Posted December 14, 2019 I see alot of those Oxy petrol cutting sets for sale now, can you get a welding torch for them to? 1 Quote Link to comment Share on other sites More sharing options...
Cobranz Posted December 14, 2019 Share Posted December 14, 2019 just purchased a Boc 185i Ac/Dc tig welder off a mate whos moving to aussie. came with alot of stuff basically just get a gas bottle and go. time to learn how to tig 5 Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted December 24, 2019 Share Posted December 24, 2019 They're not a bad little machine, air cooled torch is a drawback though. I find mine gets uncomfortable after not long at 100 amps. But then it's duty cycle isn't great at high amperage either, so not the end of the world. Quote Link to comment Share on other sites More sharing options...
SOHC Posted March 10, 2020 Share Posted March 10, 2020 Needed a smaller arc welder that I could carry when doing jobs I need to travel to, got this Chinese welder for $30 including a shit load of rods and cable everything was brand new, it’s actually very good. 7 Quote Link to comment Share on other sites More sharing options...
cletus Posted March 10, 2020 Share Posted March 10, 2020 That looks very good for getting electrocuted with 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted March 10, 2020 Share Posted March 10, 2020 Woodnt think so Quote Link to comment Share on other sites More sharing options...
SOHC Posted March 10, 2020 Share Posted March 10, 2020 3 hours ago, cletus said: That looks very good for getting electrocuted with you can touch the terminals and nothing happens 1 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted March 27, 2020 Share Posted March 27, 2020 Anyone know how the power control switch works on a mig? My dads mig only run 37a whether it's set on one, or five. Hes just replaced a ton of other bits on it. (His sparky found some.shity connections on the board too) user serviceable parts, or buy a new one? (Whenever that might be possible) Quote Link to comment Share on other sites More sharing options...
SOHC Posted March 29, 2020 Share Posted March 29, 2020 On 27/03/2020 at 16:10, RUNAMUCK said: Anyone know how the power control switch works on a mig? My dads mig only run 37a whether it's set on one, or five. Hes just replaced a ton of other bits on it. (His sparky found some.shity connections on the board too) user serviceable parts, or buy a new one? (Whenever that might be possible) I have wondered that myself, if it’s not inverted dose it control the primary input into the main transformer? Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted March 29, 2020 Share Posted March 29, 2020 Wish i had some gas or gasless wire right now.. FFffff 1 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted March 29, 2020 Share Posted March 29, 2020 19 minutes ago, flyingbrick said: Wish i had some gas or gasless wire right now.. FFffff By week three a bottle of gas, and a roll of mig wire will be hot property. 4 Quote Link to comment Share on other sites More sharing options...
sr2 Posted April 1, 2020 Share Posted April 1, 2020 On 30/03/2020 at 09:03, flyingbrick said: Wish i had some gas or gasless wire right now.. FFffff Mate, I've got a spare roll you could have; difficulty is I'm at Milford on the North Shore. Hang in there and stay safe. 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted April 3, 2020 Share Posted April 3, 2020 I managed to buy some from welding supplies. Delivered next day 3 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted April 3, 2020 Share Posted April 3, 2020 51 minutes ago, flyingbrick said: I managed to buy some from welding supplies. Delivered next day Link or ban cunt. 1 Quote Link to comment Share on other sites More sharing options...
Raizer Posted April 3, 2020 Share Posted April 3, 2020 50 minutes ago, RUNAMUCK said: Link or ban cunt. https://www.weldingsupplies.co.nz/ 1 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted April 3, 2020 Share Posted April 3, 2020 Yup that's them. Were great to deal with. 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted April 3, 2020 Share Posted April 3, 2020 The gas shut off valve in my mig is leaking, it’s annoying as I have only done about 20 mins welding with it in 3 years Quote Link to comment Share on other sites More sharing options...
Sunbeam Posted April 23, 2020 Share Posted April 23, 2020 On 08/06/2018 at 09:47, kws said: Oops weldtech, one of these https://www.machineryhouse.co.nz/W1100 Cheaper than chips for a new player at home. Still happy with your purchase? Quote Link to comment Share on other sites More sharing options...
AllTorque Posted April 23, 2020 Share Posted April 23, 2020 I have one of those. I haven’t done a huge amount of work with it yet, but is going well with 1.1mm panel steel. I did have to fix a gas leak where it goes into the machine though. Quote Link to comment Share on other sites More sharing options...
