Testament Posted May 11, 2018 Report Share Posted May 11, 2018 22 hours ago, BobbyBreeze said: Rename thread to supercharger thread so I can post my awesome/junk DC3 cabin blower plz. It could be a thing. Would need to be a 2 lobe blower on a 4cyl running 1:1. I suspect no one has ever bothered as most blower development has been on v8's and 2 lobes are obsolete. p.s. @RUNAMUCK you want the pulse to arrive at the end of the intake valve event, not the start. Trapping 140% boost at end of the intake event would certainly be helpful. Hey I run a two lobe on a 4cyl haha 16 hours ago, Carsnz123 said: On a carb setup the release valve if for the case of a backfire so the 1L plenum of fuel charge doesn't turn into a grenade or damage the supercharger with a massive back pressure. I've seen a video of a type 35 Bugatti being given a good squirt at night. There was fire spitting out the exhaust and out the hole in the bonnet which the release valve pokes through. The Delage GP car that was out at the Skope classic apparently has hydrauliced on an occasion due to flooding and the fuel pooling in the blower. Yeah I have a tuning issue at present where there is a random intake backfire resulting in 2bar+ pressure spike in the intake manifold....and I removed that valve because it was in the way of installing the fuel injectors in the manifold...... Quote Link to comment Share on other sites More sharing options...
HighLUX Posted May 11, 2018 Report Share Posted May 11, 2018 Teach me about pulley sizes and making more boost plz Bart. I need smaller pulley on the s/c for more boost? Quote Link to comment Share on other sites More sharing options...
Alfashark Posted May 11, 2018 Report Share Posted May 11, 2018 I have a boost calculator thing on a hard drive somewhere, drop down boxes for blower choice/pulley size/boost target etc. I'll dig it out and upload it when I remember. Quote Link to comment Share on other sites More sharing options...
BobbyBreeze Posted May 11, 2018 Report Share Posted May 11, 2018 3 hours ago, Testament said: Hey I run a two lobe on a 4cyl haha. And a toothed belt too... Can you see any fluctuation in boost on your data logs? Interested to see if a normal MAP sensor has enough resolution to pick it up. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted May 11, 2018 Report Share Posted May 11, 2018 9 hours ago, HighLUX said: Teach me about pulley sizes and making more boost plz Bart. I need smaller pulley on the s/c for more boost? Or a bigger pulley on the crank. sc12/14 have a ghey tapered spline where the pulley attaches to the pump. Which isn't un doable, but is more cuntier to make. the online calculators require the VE of the engine, and of the blower to accurately calculate boost. however if you have an existing set up, you ought to be able to extrapolate (within a bulls roar) your effeciencies. 1 Quote Link to comment Share on other sites More sharing options...
bathcollector Posted May 12, 2018 Report Share Posted May 12, 2018 On 5/11/2018 at 12:22, Alfashark said: I have a boob calculator thing on a hard drive somewhere, drop down boxes for blower choice/pulley size/boost target etc. I'll dig it out and upload it when I remember. 1 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted May 12, 2018 Report Share Posted May 12, 2018 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted May 12, 2018 Report Share Posted May 12, 2018 If my k car wasn't fuel injected I would be all over this Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted May 13, 2018 Report Share Posted May 13, 2018 Duuuuuuude! Fuel injected engines are eleventy billion times more betterer. You can run a small intercooler, cos you have no fuel in the charge. And cos everything is so small you can upgrade your injectors to slightly larger ones using pretty much anything. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted May 13, 2018 Report Share Posted May 13, 2018 My next supercharged engine will be injected 100%. 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted May 15, 2018 Report Share Posted May 15, 2018 Sorry I probably should have stated engine already needs work lol. But that's good to know.! Quote Link to comment Share on other sites More sharing options...
Roman Posted May 15, 2018 Report Share Posted May 15, 2018 Shit these things are cool. Quote Link to comment Share on other sites More sharing options...
BobbyBreeze Posted May 15, 2018 Report Share Posted May 15, 2018 May be of some help. I believe the TX-04 is AMR500 but cannot confirm. 2 Quote Link to comment Share on other sites More sharing options...
Steelies Posted May 15, 2018 Report Share Posted May 15, 2018 also watching with interest, amr500 suits suzuki f8b, as per discussion with Boost Simpson. 2 Quote Link to comment Share on other sites More sharing options...
grunta Posted July 25 Report Share Posted July 25 just ordered a amr500 for work , going to use it with electric motor and VSD to control flow.. should be super fun project hopefully they dont leak as our furnace runs less than 100 PPM o2... have been using these crappy side channel blowers but they keep fucking out and leak 02 in... 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted July 25 Report Share Posted July 25 Check there's oil in it when it arrives 1 Quote Link to comment Share on other sites More sharing options...
grunta Posted July 26 Report Share Posted July 26 im pretty sure they are shipped dry.. do you have bad experience with no oil? Quote Link to comment Share on other sites More sharing options...
tortron Posted July 26 Report Share Posted July 26 13 minutes ago, grunta said: im pretty sure they are shipped dry.. do you have bad experience with no oil? Pretty sure this one didn't have any oil in it Quote Link to comment Share on other sites More sharing options...
grunta Posted July 26 Report Share Posted July 26 aw yeah donut rulz ! Quote Link to comment Share on other sites More sharing options...
