~Slideways~ Posted May 8, 2018 Posted May 8, 2018 I've recently discovered these, I've stuffed around with with SC12's but never knew about these little buggers. A bit of a search on here and it looks like some of you guys have played with them, stupid Photobucket has fcked the details from 5 or 6 years ago though, so I thought I'd start a topic specifically about them. $200 USD! https://www.aliexpress.com/item/mechanical-supercharger-car-gear-supercharger-Turbocharger-Roots-Supercharger-for-Displacement-1-2-2-2L-model-AISIN/32273573307.html It makes me want to buy one and think about possible applications later... An AMR300 might suit my Honda N360, it could even be a bolt on if driven off the cooling fan pulley. The carb is mounted with a rubber joiner so it would be easy to swap to something else. Maybe I could use a bike carb? It may not be a good idea due to rarity of parts but the idea is so tempting, surely it would be ok on 4 or 5 psi? Who has played with these and carbs? Quote
Guypie Posted May 8, 2018 Posted May 8, 2018 Mark had one on a velobike with a briggs and stratton. Was a bit of a beast apparently. Cant remember his screen name but you will probably find something in the two wheels section if you look hard enough Quote
~Slideways~ Posted May 8, 2018 Author Posted May 8, 2018 3 minutes ago, Guypie said: Mark had one on a velobike with a briggs and stratton. Was a bit of a beast apparently. Cant remember his screen name but you will probably find something in the two wheels section if you look hard enough Yep I found that, some info but most of the photo's were hosted by photobucket so are gone now. Quote
tortron Posted May 9, 2018 Posted May 9, 2018 Hey, i have an amr500 and a v pully. And the piping/flanges that came with it. A 1 1/2 or 1 3/4 su would suit pretty much anything that the super charger would 1 Quote
tortron Posted May 9, 2018 Posted May 9, 2018 There was a guy in aussie making flanges and pulleys for tgese. For datsuns i think Quote
~Slideways~ Posted May 9, 2018 Author Posted May 9, 2018 3 minutes ago, tortron said: Hey, i have an amr500 and a v pully. And the piping/flanges that came with it. A 1 1/2 or 1 3/4 su would suit pretty much anything that the super charger would The big amr500 might be a bit much for a 360cc two cylinder? Quote
tortron Posted May 9, 2018 Posted May 9, 2018 Possibly, you can under run it. 500 refers to 500cc of air per revolution Quote
~Slideways~ Posted May 9, 2018 Author Posted May 9, 2018 6 minutes ago, tortron said: Possibly, you can under run it. 500 refers to 500cc of air per revolution Cool, are you selling it? Quote
~Slideways~ Posted May 9, 2018 Author Posted May 9, 2018 10 minutes ago, tortron said: No, but you can test fit if you want Cool thanks for the offer, have you used one yet? Interested to know experiences with draw through carb set ups. Quote
tortron Posted May 9, 2018 Posted May 9, 2018 Iv stuck with twin carbs, but theres a couple of minors getting around with the amr500 and a suck through SU 1 Quote
RUNAMUCK Posted May 9, 2018 Posted May 9, 2018 Yes How many cylinder is your N360? What's the static compression ratio? Quote
Yowzer Posted May 9, 2018 Posted May 9, 2018 10-5s velobike was pumping over 20psi from the 300. It could have done with some meth to keep the temps down, but it worked well with the drawthrough setup. 1 Quote
HighLUX Posted May 9, 2018 Posted May 9, 2018 4 hours ago, ~Slideways~ said: Yep I found that, some info but most of the photo's were hosted by photobucket so are gone now. Theres an add on for chrome that fixes the photo bucket issue Quote
~Slideways~ Posted May 9, 2018 Author Posted May 9, 2018 1 hour ago, RUNAMUCK said: Yes How many cylinder is your N360? What's the static compression ratio? Two and 8.6:1 from what I can find. Quote
~Slideways~ Posted May 9, 2018 Author Posted May 9, 2018 47 minutes ago, HighLUX said: Theres an add on for chrome that fixes the photo bucket issue I'm at work and Chrome was locked down not that long ago, I've got admin rights but it'll just get removed again. Because: pissy. Quote
RUNAMUCK Posted May 9, 2018 Posted May 9, 2018 Perfect. You engine inhales 165cc per revolution. The amr 300cc. If you drove it at 1:1 the difference between what it can fit, and what the blower wants to ram down its neck manifests as boost. I'd nave to nut out what psi that would make. 2 Quote
~Slideways~ Posted May 9, 2018 Author Posted May 9, 2018 1 hour ago, Firetruck said: 10-5s velobike was pumping over 20psi from the 300. It could have done with some meth to keep the temps down, but it worked well with the drawthrough setup. Man, 20psi! I had a sc12 on 4agze which is basically the same thing but 1200cc. For a short time it ran 10psi and no intercooler, the outlet pipe got FCUKING hot real quick and the ECU must have pulled timing because it ran like a sack. Then intercooled and it was happy. (Then turbo'd and it was even happier lol) Quote
~Slideways~ Posted May 9, 2018 Author Posted May 9, 2018 2 minutes ago, RUNAMUCK said: Perfect. You engine inhales 165cc per revolution. The amr 300cc. If you drove it at 1:1 the difference between what it can fit, and what the blower wants to ram down its neck manifests as boost. I'd nave to nut out what psi that would make. Sounds like you are the man to know haha Quote
