RXFORD Posted October 23, 2023 Posted October 23, 2023 Is it spinning fast enough to throw little electric people where they need to go? ie; pulley sizing correct for idle speed of crank pulley diam? 3 Quote
mjrstar Posted October 23, 2023 Posted October 23, 2023 30 minutes ago, cletus said: Yes, it has one , in which I have tried 1w, 3w, and 5w bulbs Also has a battery sense wire which runs all the way to the battery on a separate wire Are you running a resistor in the sense wire? 1 Quote
cletus Posted October 23, 2023 Posted October 23, 2023 3 hours ago, mjrstar said: Are you running a resistor in the sense wire? No, just a bulb It worked in the previous setup with the China bosch , the light comes on and goes off as soon as I start it. Comes on if you disconnect the sense wire 3 hours ago, mjrstar said: I wonder if it's a winding issue which is only apparent when belt tension is applied. I'm assuming the bench test is driven directly on the front.. Test bench has a belt drive, it's a pretty cool bit of gear, it's huge 3 hours ago, RXFORD said: Is it spinning fast enough to throw little electric people where they need to go? ie; pulley sizing correct for idle speed of crank pulley diam? This has crossed my mind as the crank pulley is smaller than a normal sb mopar , it's off a marine engine. It is the same as it was with the previous alternator though. A big rev does not change it Quote
RXFORD Posted October 31, 2023 Posted October 31, 2023 Should send an Invoice to supplier for the diagnosing labour. 1 Quote
hood Posted November 1, 2023 Posted November 1, 2023 I had regulator issues on a newish alternator on my hilux recently. Alternator was just over a year old, and I only managed about 10tho Kms on it, and unfortunately out of warranty. I took it to Lance @ Autowire who pulled it apart and the regulator failed on it. Turns out the alternator itself was ok but the cheap Chinese regulator let go. He sourced and fitted quality genuine denso unit and it was good to go 1 Quote
piazzanoob Posted November 5, 2023 Posted November 5, 2023 is the regulator you talking about an external bosch one? re55 part number? Quote
cletus Posted November 5, 2023 Posted November 5, 2023 No it bolts into the back of the alt, has the brushes in it Quote
RUNAMUCK Posted March 15, 2024 Author Posted March 15, 2024 On a recent trip to mexico, i got to experience this machine first hand. Hooooooo boy! Its quite jolly rapid! Not slow at all! 2 1 Quote
440bbm Posted April 14, 2024 Posted April 14, 2024 Looks BADASS on the draglites! perfect wheel for this thing 1 1 Quote
Roman Posted April 16, 2024 Posted April 16, 2024 Agreed, looks so good! Love this car. Going to come to the night speed final next Friday? 1 Quote
cletus Posted April 16, 2024 Posted April 16, 2024 Not sure yet, I usually struggle to get there on time after work/traffic/probably overheat in the southern traffic jam 1 Quote
RUNAMUCK Posted April 16, 2024 Author Posted April 16, 2024 Do you have a pair of front runner tyres? I once asked on a forum filled with clever people , " how fast do you need to go before you need front runners? They answer was, youre thinking back to front. Its not how fast do you go before you need them, they help you to go faster. /every bit helps. 1 1 Quote
cletus Posted April 16, 2024 Posted April 16, 2024 Probably should have them, because of bias ply Hoosiers on the back, but when those are worn out I might try some drag radials , so would need a radial on the front 2 Quote
Roman Posted April 17, 2024 Posted April 17, 2024 Ahh ive always wondered what the point of those drag specific front tyres was. (For rwd) 1 Quote
RUNAMUCK Posted April 17, 2024 Author Posted April 17, 2024 5 hours ago, cletus said: Probably should have them, because of bias ply Hoosiers on the back, but when those are worn out I might try some drag radials , so would need a radial on the front Is this a thing? I know absolutely nothing about tyres, except that drag ones bite hard out of rhe hole. Quote
cletus Posted April 17, 2024 Posted April 17, 2024 Yeah it's not great to mix radials and bias ply tyres, it can make for some interesting handling Nzdra rule book says 2 1 Quote
igor Posted April 17, 2024 Posted April 17, 2024 I ran a Mini 1275GT with 12" radials on the front and 10" crossplies on the rear for a while when I young and silly, and too broke to buy two more radials. Never drove it fast thouigh cos it felt too weird. Quote
RXFORD Posted July 25, 2024 Posted July 25, 2024 Hubbies are a bit too plain. Could make up a press tool with some sort of mopar/plymouth emblem and stamp them to be less boring? 1 Quote
